Question about Apple iPod nano 3rd Generation
Volume problem my new Nano is quieter than my old one. Even turning off the noise limiter makes no real difference
  • stewieC Apr 26, 2008
    No, that's not the answer. I have Bose in-ear phones. Top quality.
    Problem Solver:
  • 16 Answers
Maybe its your headphones, my old headphones did that to
Posted on Apr 26, 2008
SOURCE:
My vw polo is making a screeching noise when turning left and a quiter noise while driving straight (sounds the same just quieter) and when i parked up today it had a burning smell from front left wheel...
Sounds like a left front wheel bearing...a must check for safety...usually a free check at the best shops. Could also be a worn out brake pad/rotor dragging...again a free inspection but please have checked. The difference when turning sound points toward the wheel bearing:( Hope this helps.
Sep 30, 2013 | Cars & Trucks
I just bought the ipod nano 6th generation and it will not charge in the Bose docking system....my old one charges with no problem.....is there a fix for this? The nano plays fine it just wont charge
If it is a different model iPod then it is likely the Bose dock does not support the newer model. Quite often changes such as from iPhone 3 to iPhone 4, Bose had to release a new dock. The speakers and music will still always work, but the support will be limited for charging. Unfortunately you will not be able to fix this, other than upgrade the dock, or go back to your old ipod.
Thumps Up!
May 04, 2011 | Bose SoundDock Digital Music System for...
GE Harmony Dryer makes Loud Vibrating noise
If you can open the walls of the dryer up check all screws and bolts that hold things together. Some times they will vibrate loose causing parts to make a vibrating sound against the frame itself.. Eventually the loose screws will just keep getting looser. Even the screws on the walls of the unit should be tightened That could cause a lot of noise.
Apr 10, 2017 | GE Profile Harmony DPGT750EC Electric...
When i start my 1997 expedition i get a loud humming noise what is this
Most likely this is your power steering pump - check the fluid and listen again.
The ford power steering pumps are known for a loud noise and even new ones make plenty of noise - especially when you turn the wheels. Keeping them full of fluid helps them be a little quieter.
Jan 28, 2010 | 1997 Ford Expedition
How to properly install plenum limit switch
If this is the old style limit/fan switch. Turn power off
remove the wires and label where they got disconnected from and wire the new one in. Make note of the settings on the old limit switch so you can
adjust the new one. The limit switches come in
different lengths so get the right one.
If it is a flat bimetal disc, then I think you have only to
wires that have to be connected so hook up same
to wires from the old one. With Bimetal disc fan
limits you need to make sure you get the same
temperature reading as the old one
Jan 16, 2010 | Cozy Enclosed Front Console Heater 70,000...
I HAVE AN OLD PLAYER & WANT TO DOWN LOAD TO NEW NANO IPOD . i PUT SONGS IN MY COMPUTER BUT i'M USING REAL PLAYER & IT CAN'T SEE THE NANO !
The iPod Nano uses iTunes exclusively so just download iTunes and use that to store your music and transfer them to your Nano.
Jul 13, 2009 | Apple iTunes
Steering system
that is just the power steering trying to turn more than its limit. let off of the steering slightly and it should quit. this happens in all cars new and old that have power steering.
Apr 09, 2009 | 1999 Chevrolet Silverado 1500
Fan oven is noisey
needs new fan motor unless the old one is loose
Dec 11, 2008 | Tricity Bendix SE454 Electric Kitchen...
My fan alwayes on and noise. can u advice me how to turn off the fan
your fan needs to stay on to keep the board and devices cool but if it is making noise you may want to try to clean it with canned air and if that doews not make it quieter than you may want to get a new fan
Aug 14, 2008 | Computers & Internet
Apple iPod nano 3rd Generation Logo
Top Apple Audio Players & Recorders Experts
Ekse
Sean Cole
Sean Cole
Jeffrey Groves
Jeffrey Groves
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
