Question about Dell 1100 Laser Printer
Dell 1100 Laser Printer overheating
The printer gets very hot on the outside casing above the roller and smoke even appeared a couple of times. I cleaned it but to no avail. Thank you, MJ
  • musicalsnoop Jan 08, 2009
    how do you get the fuser out?
    Genius:
  • 1,913 Answers
Change your fuser asembly
Posted on Mar 31, 2008
I turned on my Dell 1110 printer and it keeps making the same noise over and over. The top "rollers" keep moving and I am not printing anything. I had to turn off the printer because it was getting so...
It does have a high pitched noise when it first starts up that is annoying, but after a few minutes it stops. If the roller is keep moving and non-stop, maybe you should contact dell.
Aug 20, 2010 | Dell 1110 Laser Printer
Tip
Replace Transfer Roller
If the printer still says to replace transfer roller even after it's replaced, then remove transfer roller and manually turn the gears on the transfer roller a few times. It must get stuck or something. Then replace the transfer roller and it should work.
on Feb 07, 2008 | Dell 5100cn Laser Printer
Paper is jamming during printing process. Gets half way round and jams. please suggest solutions
There are rollers that the paper has to go between to be pulled forwards. When the rollers get dirty with paper dust, paper starts jamming. So you need to clean the rollers with a moist (not wet) soft cloth, Keep rolling the rollers manually and keep cleaning them. Then allow a few minutes to dry them up. And no jam after that.
Dec 10, 2009 | Dell 1100 Laser Printer
Paper feeder stops after in about 2 inches
Have you tried cleaning the feed rollers with rubbing alcohol or soapy water? Just make sure to dry the rollers before trying to use the printer again. If this doesn't remedy the problem, check the paper feed path for obstructions (previous misfeeds or jams). Hope this helps.
Sep 03, 2009 | Dell 1100 Laser Printer
What is the problem when my printer overheats before it even starts to print. The red light comes on and the red roller is very hot. Thanks.
dear sir it is the problem your printer ntoner sensor or fuser unite thermostater ti over head toner dust clean it then solve your problem
Jul 16, 2009 | Dell 1110 Laser Printer
Dell 1815dn laser printer prints completely black pages
1. Charge – Print Quality (PQ) -- The charge roller evenly distributes a negative charge on the photoconductor (PC) drum. This evenly distributed charge acts as the film that is discharged (exposed) by the laser to create the latent image.
a. Print Quality effected: Faint, Entire Black background, Grey Fog/Haze
b. Parts Involved:
i. Drum -- A drum cartridge is coated with a photoconductive material that allows electricity to pass when exposed to light. As an example of why this can be the failure, if you leave a drum out in light long enough, you will get dark backgrounds or just black pages. However, drums do wear out over time too; specifically the photo material the drum is coated with. As this degrades, more of the positive electricity on the inside of the drum gets through and grabs toner, as if the laser wrote to every square inch of it. A damaged or defective PC drum can cause black streaks/lines, voids, speckles and various other print quality problems.
ii. Charge Roller Also known as the BCR or Bias Charge Roll. The charge roller pulls double duty. It energizes the outside of the drum with negative energy and as a result it cleans any previous latent images. If the charge roller were failing to energize either due to the HVPS or the charge roller itself, it wouldn’t clean any previous unused toner deposits from the last revolution would start to accumulate and appear on paper more and more causing haze. A missing charge roller causes completely black pages.
iii. HVPS – High Voltage Power Supply -- Responsible for charging components such as the inside of the drum, the charge roller, and transfer roller. If the HVPS does not give enough to the charge roller it can fail in erasing the drum, causing entirely Black pages to be printed.
Apr 16, 2009 | Dell 1815dn All-In-One Laser Printer
Dell 1100 laser printer stopped working
http://support.dell.com/support/edocs/systems/1100/en/OM/OM_1100_en.pdf
The link above is for the manual. See if there is anything in there that might help you out.
Mar 26, 2009 | Dell Laser Printer 1100
Dell 1110 Laser Printer Solid red warning light
Hi in this case the paper jam made some sensor through the paper road they are not in normal position or still tigger on by piece of something or error stander. you may try:
1) check paper input sensor near paper tray roller\
2) check margin sensor inside paper way before drum unit
3) check fuser sensor near fuser unit
4) check paper output sensor near output tray roller
sometime need sensor adjustment back to normal position
Dec 22, 2008 | Dell 1110 Laser Printer
Overheating
1.call service. it's dangerous becouse too hot fuser section can make open fire. teristor in fuser damaged, or temp.sensor can not detect temperature of heat roller. 2. clean pick up rollers with special fluid. If thats not help - replace rollers. 3. see fuser, laser and cartridge.
Oct 14, 2008 | Samsung ML 2010 Laser Printer
Dell 1100 Laser Printer Logo
546 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
