Question about Sharp AR-5316 Advanced Digital Imager Copier
Sharp 5316 toner Indication
How to get rid of Toner indication after replacing toner also?
  • Anonymous Apr 03, 2008
    how to remove the toner indication after refill toner cartridge
My copier can not print from my pc
Posted on Jul 07, 2008
  • 3 Answers
Go into your menual bottom on display and go to clare count and selecte( yes ) and it will go off or selecte new toner.
Posted on Mar 31, 2008
Sharp AR 5316 Maching Toner LED Light 3 Min. Blinking, and them start. Please Toner Curm reseting code.
Have you tried to replace the toner???? Are you sure the light that is blinking for the toner?????
Jan 13, 2013 | Sharp AR-5316 Advanced Digital Imager...
My sharp ar5316e is showing a red triangle blinking light and no key is responding nether the start button
That indication is Toner Indication.You should change the toner,Now May be the toner chip also damaged. whether the machine worked after changing the toner then no need to change the toner chip,other wise the same indication still, then you change that one also.
Jul 08, 2011 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316
The toner cartridge comes with on-chip sensor that counts the toner life. If you allow it to go empty completely that is it gives red triangle which is steady to warn that toner is near empty. You should replenish toner at this time but if you allow it to blink red triangle, that means its completely over and can't be refilled. REPLACE A NEW TONER CARTRIDGE.
May 06, 2010 | Sharp AR-5316 Advanced Digital Imager...
Copier
The problem is that the toner sensor is not recognizing that type of toner. All toner is not the same you will cause more damage to the machine. Use the specified manufacturer toner.
Mar 26, 2010 | Sharp AR-5320 Black and White Copier
Ar-5316 showing error ch
CH steady means cover is open. Close either front or right cover well.
CH blinking means developer unit or toner cartridge not installed. Remove and return well and firmly.
Nov 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
AR5316 toner indication after adding toner what to do
was the toner cartridge refilled or replaced?
was the toner new or close to expiry date?
Jul 17, 2009 | Sharp AR-5316 Advanced Digital Imager...
Error F 2 (Blinking mode) appears in Display of Sharp AR5316,
Hello sir; F2 have a sub code, press print key to read the sub code, if the sub code is 04,then it means wrong cartridge,wrong country, you can try to reset it;
1, press "#", "interrupt", "c", "interrupt" keys.
2, enter 14 press start.
3, if it work, don't forget give me a good rating.
Feb 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
Add toner still blinking of sharp AR-5316
the best you can do is to replace the toner cartridge itself. It won't work if you just refill it.
Oct 31, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sarp
I'm assuming you already changed the toner.
1-defective toner
2-not inserted properly
3-wrong toner type
4-need to reset counter
Jul 25, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
118 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
