Question about Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television
Color is bad after installing color wheel in samsung dlp tv
How do I reset color after installing the new color wheel?
  • b1bjimbo Jun 10, 2008
    AFter replacing the color wheel on my Samsung HL R6168w dlp set, the facial colors are way off, especially on close-ups. The faces tend to turn from flesh colored to yellow pink.
    We've tried to set the color manually, however it seems there is no consistency between different channels.
    I've heard there may be a jumper cable that can be disconnected to improve performance. If anyone has done this, could you please provide some details?
    Thx.
  • handymantim Jan 11, 2009
    What does the jumper look like?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 208 Answers
Most times color does not to be reset. If you have a very ugly green or blue picture, then you did not pull the jumper on the dm board. This jumper must be removed when a bering type color wheel has be replaced with a new airless bering color wheel.
Posted on Apr 07, 2008
Put in a new colorwheel , now the picture is green and blue. I was told their was a jumper cable that neede to be removed. What does it look like and where is it. I don't know alot of the terminology. thank you, need help!
Posted on Apr 12, 2011
Pull the jumper.
Posted on Jun 30, 2008
Can someone help me adjuting my colors on my hlp5063w dlptv, I change the color wheel a the colors are way off everyone looks blue please help....
Posted on Nov 14, 2008
Samsung dlp the picture is all shadows with dark green/black colors after replacing with new color wheel..what is wrong? Is it a bad color wheel?
no you need to adjust the color wheel to factory specs by getting into the service software. The color wheel has to be timed to the engine.
Dec 29, 2013 | Samsung Bp96-00674a Dlp Tv Color Wheel...
Samsung DLP tv is making humming noise, what can I do to correct this?
Most likely The color wheel is gone. They sell for around 80$ on Ebay. It spins at about 5000 rpms. They do ware. So replacing the color wheel will fix this problem.
Dec 26, 2010 | Samsung HL-S5087W DLP TV
Samsung DLP R&R Color wheel Model #HLR5078w
Samsung's digital light projection (DLP) televisions use a spinning color wheel to create the colors that are seen on the screen. If the color wheel becomes misaligned during use, it will become damaged and have to be replaced. Replacing the color wheel on a Samsung DLP television can be done at home, once a compatible-sized color wheel has been bought from a TV supply store.Replacing the color wheel yourself will void any Samsung warranty that might be in place, but is the only solution for getting the TV working again in as short a time as possible.
Put on the anti-static grounding strap to keep static electricity from damaging the internal components of the Samsung DLP TV. Turn the Samsung around so that the back is facing you. Make sure the Samsung is unplugged from the AC socket.
Use the Phillips screwdriver to remove all of the screws from the back panel. Put the screws aside. Pull off the back panel.
Loosen the two screws from each side of the projection bulb's case. Pull the projection bulb out. Put the projection bulb aside. Use the Phillips screwdriver to remove the two screws from the left side panel. Pull the side panel and the circuit board attached to it out carefully and put it down so that the cables attached to it have not been pulled out.
Take a picture of the power cable's position with the digital camera so that you can put it back correctly later. Pull the power cable out from inside of the Samsung's case so that the center panel is free to be pulled out. Remove the two large headed screws from the center panel with the Phillips screwdriver. Remove the top two screws holding the panel to the plastic case using the Phillips screwdriver.
5
Slowly slide the center unit out a few inches. Take a picture of the projector lens' positioning with the digital camera so that you can put it back correctly later. Unplug the two cables from the left side of the center panel. Unscrew the sensor switch using the Phillips screwdriver. Slide the center panel completely out of the Samsung and put it down on the clean cloth. Blow off the color wheel assembly with the compressed air.
6
Use the tweezers to remove the green plug from the top of the color wheel cover. Use the tweezers to remove the two cables at the side that are coming from the color wheel. Use the Phillips jeweler's screwdriver to remove the screws from the top, front and back of the color wheel cover. Slide the color wheel cover straight up to expose the color wheel.
7
Use the Phillips screwdriver to remove the three screws holding the color wheel to the color wheel assembly. Lift the color wheel up and out of the color wheel assembly and discard it.
8
Position the replacement color wheel in the color wheel assembly. Reassemble the color wheel and reassemble the color wheel assembly. Put the color wheel assembly back into position in the rear of the Samsung DLP TV. Reassemble the Samsung DLP TV. Plug the Samsung DLP TV back in for power. Turn the Samsung on and enjoy seeing the colors displayed properly again now that you have replaced the color wheel.
May 02, 2010 | Samsung HLR5064W DLP Projection TV
My tv is making a loud buzzing noise
Bearings in color wheel going bad and needs to be replaced. Call a local tv repair shop on pricing and availability of color wheel for your model and chassis
number.
Dec 03, 2009 | Samsung DLP HL-P5663W 56" TV
Rattling sound from the Samsung DLP TV
Your Color Wheel is bad and needs to be replaced by a trained Samsung tech. There are adjustments that must be made after the color wheel is replaced. Part# is BP96-01579A
Jul 15, 2009 | Samsung HL-S5087W DLP TV
I have a Samsung 50 inch DLP - I heard a pop and the picture immediately disappeared. The 3 lights were flashing on the front which according to the book said it needed a new lamp installed. I ordered it,...
Sounds like the color wheel may have also gone bad. I recently saw a 56" Samsung where the bulb and color wheel went at the same time. The color wheel could produce a crying noise while trying to spin up.
May 05, 2009 | Samsung DLP HL-P5663W 56" TV
Sound on Samsung HD DLP rear projection TV sounds like an airplane taking off (no other sound)
sound like u have a bad color wheel , u need to have the model code to order the new color wheel , is going to be at the side of your set
May 02, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung HL-R6167W DLP color problem/buzzing noise
My 3 yr old Samsung DLP has the same buzzing noise, had a tech out today and he said "color wheel". Thank goodness I purchased that expensive warranty, This is my 4th repair in 3 years.
Dec 24, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung HLS4266W 43" dlp
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television Logo
1,609 people viewed this question
Henry  Thomas
Henry Thomas
