Question about IBM ThinkVision L200p 20.1" LCD Monitor
IBM THINKVISION MODEL 6736-HBO - NO DISPLAY
Hello , I have Monitor IBM L200P Power steady green - no video signal come out either Analog Port or DVI ... Is a video controller PCB- Failure compoment has to be replaced or Can anyone have a service manual for authorized part for that model share , I 'll appricate for share valuable information... Thanks
CompuGuy44
  • 432 Answers
SOURCE: IBM thinkVision
Could be the invertor board is bad and will need replacing.
Posted on Jun 30, 2007
tantong
  • 138 Answers
SOURCE: Monitor wont turn on, green power light on
Hi you can inspect that what's wrong with your monitors. After you turned it on and the screen went black, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Posted on Mar 09, 2008
Fix-4U
  • 293 Answers
SOURCE: ibm thinkvision l170 monitor
Hi! Tammy,
It's seems your new pc resolution settings, set to high...
Hook up to another monitor and go to settings to correct your
resolution to 1280x768 or less. That will fixed your problems.
Good lucks!
Posted on Aug 07, 2008
SOURCE: IBM ThinkVision 17" Monitor displays for 1 second then black
This seems to be a common problem with these monitors. Have a look very closely and see if you can still see something there. From there, either send it to get repaired, or, if you are handy with a soldering iron, open it up and replace the 4 main capacitors (at least one of them will be "popped", but it is handy to replace them all.
In order to open the monitor, you will need to remove the stand, and make sure you get all of the screws out before attacking it with a screwdriver.
I have 5 IBM monitors at work with the same problem, and opening them up has shown the popped capacitors.
Again, only recommended if you know what you are doing. Screwing it up will leave you with nothing.
Posted on Feb 03, 2009
budmrtn
  • 11361 Answers
SOURCE: ibm thinkvision monitor is stuck in power saving
I would try it on other PC first to narrow down the problem.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Apr 11, 2010
I can't install drivers for the Thinkvision L200p on windows 7. I went to the Lenovo support page (http://support.lenovo.com/en_US/product-and-parts/detail.page?LegacyDocID=MIGR-69721) and downloaded .cat,...
Is the video card a seperate card? Or is it part of the motherboard? You'll have to open the case to make sure. If it's a seperate card that will make a difference with the drivers being loaded.
Oct 11, 2013 | IBM ThinkVision L200p 20.1" LCD Monitor
How can i fix the continous on & off blinking of my ibm l170p monitor
If your monitor is blinking or flickering increase the refresh rate.
Apr 07, 2012 | IBM ThinkVision L170p 17" LCD Monitor
What does dvi mean
Hello figment_of_u,
DVI stands for Digital Video Interface. They are used for direct digital connections between source video (namely, video cards) and LCD monitors. This provides a faster, higher-quality image than with analog, due to the nature of the digital format. All video cards initially produce a digital video signal, which is converted into analog at the VGA output. The analog signal travels to the monitor and is re-converted to a digital signal. DVI-D eliminates the analog conversion process and improves the connection between source and display.
Hope this helps you understand what DVI is for. Thank you for choosing Fixya.
Feb 12, 2012 | HP 2009M Monitor
Thinkvision monitor is in power save mode. It is not connecting to Thinkpad laptop
There are 2 possible reasons for this:
- Your Laptop resolution is not supported from the monitor. Solution: reduce the resolution to something smaller (e.g. 800x600) and then gradually increase it untill you have the maximum accepted resolution from the monitor.
- You have not switched the Laptop display to point to the external monitor. Solution: do that b pressing the corresponding shortcuts in your Thinkpad keyboard. (usually a bottom left key together with a top key).
Jul 28, 2011 | IBM ThinkVision L200p 20.1" LCD Monitor
How can i use dvi port
DVI stands for (D)igital (V)ideo (I)nterface.
DVI is a new form of video interface technology made to maximize the quality of flat panel LCD monitors and high-end video graphics cards. It is a replacement for the P&D Plug & Display standard.
you can connect high definition monitor , LCD projector , LCD T.V to a DVI port
There three kind of DVI connector
1. DVI-D (Digital)
2. DVI-A (Analog)
3. DVI-I (Integrated Digital/Analog)
DVI-D format is used for direct digital connections between source video (namely, video cards) and digital LCD (or rare CRD) monitors
DVI-A - High-Res Analog
DVI-A format is used to carry a DVI signal to an analog display, such as a CRD monitor or and HDTV
DVI-I - The Best of Both Worlds
DVI-I format is an integrated cable which is capable of transmitting either a digital-to-digital signal or an analog-to-analog signal, but it will not work transmitting a digital-to-analog or analog-to-digital signal.
How to Recognize These three types of DVI Cable
There are two variables in every DVI connector cable, and each represents one characteristic.
The flat pin on one side denotes whether the cable is digital or analog:
A flat pin with four surrounding pins is either DVI-I or DVI-A
A flat pin alone denotes DVI-D
The pinsets vary depending on whether or not the cable is single- or dual-link:
A solid 27-pin set (rows of 8) for a dual- link cable
Two separated 9-pin sets (rows of 6) for a single-link cable
Jul 12, 2011 | Computers & Internet
Inout signal out of range Answer Failed: retry
It shows out of range because the PC is sending out the video signal that is higher than the monitor can display, you need to set the PC video resolution to the native resolution: 1024 x 768 @60Hz. You can reboot the PC into save mode (hitting F8 key while booting up) then set the resolution to 640 x 480 (try 1024 x 768 if it allows you to do so), reboot and reset the resoltion to 1024 x 768 @60Hz.
Mar 06, 2010 | IBM ThinkVision L151 15" LCD Monitor
IBM ThinkVision 17" L170P, the problem is that the screen is black and power indicator is steady green on. Can not turn off the power indicator at all.
Check the DVI connections on your computer and your monitor. It is possible that there is not a good connection. Do you have access to another working monitor? If you connect a different monitor, and that monitor comes up, it could be the DVI cable or a bad monitor itself. If neither monitor comes up it could be a bad video card or port, or the computer may not recgonize it under Properties, Display, then settings when you right-click on the monitor, if you are using it as a second monitor.
Dec 01, 2009 | IBM ThinkVision L170p 17" LCD Monitor
I have bought a second hand monitor model is 6736-hcp off my mate but after pluggin in it the picture is not that clear..its kinda blurry and moving .I have downloaded drivers online for the very monitor...
If the monitor didn't have issues when he had it (and you didn't drop it, or bang it into anything), and you've installed the latest drivers, then the problem has to be in the cable or the monitors settings.
First try opening your monitor's settings menu (should be some buttons on the front of the monitor) and adjust the sharpness.
If that doesn't work the problem may be that the cable is transmitting the signal poorly from the computer to the monitor. Go to the place you bought the cable and ask for a new one.
Sep 19, 2009 | IBM Open Box 6736HC9-BLC THINKVISION L200P...
A vertical sector of the display, about 30% of the
Due to the lack of cost with another monitor, I would buy a new one. 5 years is more than I would expect for the life of a monitor.
Apr 23, 2017 | IBM Open Box 6736HC9-BLC THINKVISION L200P...
Jan 25, 2009 | IBM ThinkVision L170 17" LCD Monitor
IBM ThinkVision L200p 20.1" LCD Monitor Logo
996 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
