Question about Protron PLTV-37 37 in. LCD Television
No Picture (power indicator does not light up)
I have a Protron 37" LCD model# PLTV-37C. The power indicator does not light up and the TV will not turn on what so ever, I used the remote and the power button on the TV still nothing, also tried a different outlet..nothing. Only had the TV for a year.......please help!
  • 3 more comments
  • kmisskriss Apr 01, 2008
    my 32" Lcd tv stopped working 2 agos, what does china have some sort of chip or something inside of them, so that just after the year warranty runs out, the tv kicks the bucket? I don't know, it's awful weird
  • rogerwhite Oct 31, 2008
    i have the same problem
  • Anonymous May 02, 2009
    power indicator light does not light up.
  • rderego May 13, 2009
    I have a Protron model PLTV-37C. It was working fine when suddenly there was a "boom" and everything stopped working. Now, the power indicator light does not come on and there is no picture on the screen. Also tried a known working wall outlet, but still nothing. Bought this TV in 2007. Can this be repaired?
  • dianne866 May 25, 2009
    i have the same problem..no power...has anyone an idea how this is fixed?
I have a Protron 37: LCD TV. The power indicator does not change to green (the red light is showing) and the TV will not turn on, either by remote or using the power button on the TV. The TV is about a year and a half old. Can you please help me?
Thanks
Posted on Oct 24, 2008
    New Friend:
I am having the same issue with my pltv-37c right now at the moment, from what i can gather up from the internet, it seem to be the power supply on mine. just something that u might wanna think about looking into. The power supply usually runs some where around 70 bucks or so.
Posted on Jan 29, 2013
How can I adjust the picture colors?
There are several performance issues you may encounter with your Protron PLTV-37C LCD television.
Some problems include the television not turning on, issues with the TV's picture and issues with the TV's sound.
Depending on the type of problem you encounter, there are several options available to you to solve it.
Power Issues
Check the TV's main power cord. If it is not plugged in or is loose, securely plug it in to an electrical socket.
Unplug the television and plug it in to another electrical socket.
If the one it is plugged in to currently is bad, the television does not receive power.
Try turning the television on with the remote.
If that does not work, try turning the television on with the power button on the TV's front panel.
If that works, then remove the battery cover from the remote.
Remove the current batteries and replace them with fresh batteries.
Picture Issues
Check the video cables.
If they are loose or disconnected, securely connect them.
Adjust the television's brightness.
If the brightness is set too dark, images on the screen are extremely difficult to see.
Check the power indicator on the front panel of the television.
If it is red, the television is in power-saving mode.
Simply press any button on the remote to bring the television out of power-saving mode.
Audio Issues
Check the audio cables. If they are loose or disconnected, securely reconnect them.
Turn to different channels and adjust the volume.
It is possible that some channels are coming in quieter than others.
Access the audio options from the main menu. Check what audio setting the TV is at.
If it is set to "Mono," change it to "Stereo."
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=dde1880d298054849d8c8adc90514f40&modelid=22971545&q=Proton+CS-37
Specifications for Proton CS-37 / PS-47
Aug 09, 2013 | Protron PLTV-37 37 in. LCD Television
My protron pltv-37c will turn on for 10 seconds the light turns green then goes to red after ten seconds
The green light indicates power is being applied. The change from green to red indicates that the power supply has failed
Oct 29, 2012 | Protron PLTV-32 Television
Protron service manual
I do not have the service manual for this LCD. I've looking for it as well.
All my work is done without it.
I'm sorry colega i could not help you on this one.
Aug 24, 2008 | Protron PLTV-37 37 in. LCD Television
Protron 37" LCD, PLTV-37C
You can look it up under the Spectroniq PLTV-3750 TV. Protron changed their name but kept the set up the same. Hope this helps...
Jan 18, 2008 | Protron PLTV-37 37 in. LCD Television
Sound but no Picture
Most likely it is the board on the lcd panel. The first question though is, can you get menus? If yes, it is the input module, if no, most likely the panel controller board. There are several makes of panels in these sets, so once diagnosed, we would need to know what panel you have to help further. I can help you figure that out once you let me know if you get menus or not.
Jan 14, 2008 | Protron PLTV-37 37 in. LCD Television
Protron PLTV-37 37 in. LCD Television Logo
778 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
