Question about Kitchen Ranges
Burner does not hold its flame on a Feather 442 stove
  • Dunlin Apr 03, 2008
    My query was re a camping stove, but this answer was still very helpfull - its always good to understand how things work in order to solve a problem!
    Novelist:
  • 184 Answers
IF THE FLAME IS LIFTING OFF THE BURNER, THERE IS TOO MUCH AIR IN THE MIX. LOCATE THE END OF THE BURNER WHERE THE FUEL ENTERS THE BURNER. THERE SHOULD BE AN ADJUSTMENT HOOD THAT CAN BE MOVED TO PARTIALLY BLOCK THE AIR INTAKE. THIS WILL REDUCE THE AIR MIX AND SHOULD MINIMIZE THE FLAME LIFTING OFF THE BURNER.
ON SOME SEALED BURNER COOKTOPS, THE MANUFACTURER RECOMMENDS PLACING A PAN ON THE BURNER AFTER LIGHTING TO MINIMIZE FLAME LIFTING.
IF THE FLAME GOES OUT WHEN SET ON SIMMER,
THERE IS AN ADJUSTMENT SCREW IN THE SHAFT OF THE VALVE ON SOME MODELS. REMOVE THE KNOB TO GAIN ACCESS TO IT. YOU WILL HAVE TO OBTAIN A SMALL SHAFTED FLAT BLADE SCREWDRIVER TO MAKE THE ADJUSTMENT.
Posted on Mar 31, 2008
Since it has turned cold my flame on cook stove has yellow flame
It may or may not be related to outdoor temperature but it appears that your burners don't have enough air. See if there is an air adjustor under the burner in the gas piping.
Oct 05, 2014 | Suburban Drop In Black CookTop Stove - 3...
Does model XFG371LVQ Whirlpool stove have air adjustment for top burners?
Remove the front panel to find where the gas injectors enter the burner tubes you will see they are cut away and have a screw holding an outer ring which is adjustable, open them up more to get more air in .
May 16, 2014 | Whirlpool Stove / Oven / Range Cooktop -...
I have a Frigidaire model FCG30B6Q0JWI-5A gas stove (Made in Costa Rica) and can't get the oven to stay lit. There is no electronic ignition, no pilot, it's just a regular run-of-the-mill light a...
While your holding in the knob after lighting the pilot,their is a thermocoupler that is heating up and will hold automatically what your pushing in, that thermocoupler is defective
Jul 28, 2011 | Ovens
Gas stove burner will not turn on
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Apr 29, 2010 | Gaggenau 23 in. KG 260 Gas Cooktop
How do you dry out the stove ignitors? They have
You do this at your own risk, but try holding a lighter flame next to the igniter gap close to the burner and light the burner manually when the igniter clicks. The heat will dry them out.
Oct 24, 2009 | Maytag MGR6772 Gemini Gas Kitchen Range
Poorly functioning Shipmate stove
Hi
Normally pressing red buttons on stoves is for lighting the oven. You press the button, light the pilot light, leave it depressed for a minute and then that heats up the thermocouple, which opens a valve and allows gas to the main burner.
Shipmate Stoves are still in business, so you could contact them. The link also suggests places for Shipmate propane gas stove spares.
Shipmate stoves Google Search
Mar 27, 2017 | Brown Stove Works 23 in. TL03-3 Gas...
Magic chef gas stove has flames coming from the bottom
Replace the burner. Quickly. Do not use that burner until it is replaced.
Apr 23, 2009 | Magic Chef 31000 Gas Kitchen Range
Oven burner flame is low
0000000.jpgOn top of that safety valve is a nut. Get a good fitting wrench. Turn on the oven and use that good fitting wrench on that nut. Turn it counterclockwise till the flame comes up about midways of the flame spreader. Don't get the flames too high. Midways of the spreader now. LOL
Jan 02, 2009 | Ovens
Kitchen Ranges Logo
529 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
