Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
My folder option is not working.
Hi I have i problem regarding virus. my folder option is not working properly.& i don't want to formate my drive . my drive is not opening. its give me open with option.what i do. plz suzzest me . my e mail id is sawan087@gmail.com
  • sawan087 Apr 01, 2008
    I told u . i don't want to format my c drive.and i can't buy a genuin version becoz i m a student.i m learing.
  • amar1mca Nov 09, 2008
    my pc was having genuine windows xp professional sp2
    my local drive is working fine
    when i try to open other drives Dor E it was showing openwith dialog
    and it was also not giving the option to check or uncheck always open with the same program
    if u have the answer plz mailme at chowdarylg@gmail.com
1. Open Start>>Run and type cmd and press enter. This will open a command prompt window. On this command prompt window type the following steps.
2. type the drive name which is nt opening ...
   for example : if  "C" is not opening means ..
                      type    :    C: "press enter"
3. type   attrib -r -h -s autorun.inf
4. type   del autorun.inf
5. now type d: and press enter for d: drive partition. Now repeat steps 3 and 4. Similarly repeat step 5 for all your hard disk partition.
Restart your system and your trouble will be fixed
Posted on Apr 28, 2009
  • 407 Answers
It is like virus if you want you buy a genuin version near your vender..
 or
 you format your pc XP SP2  only c drive format then load any new update anti virus & scan PC.
Posted on Mar 31, 2008
How do i format my memorie card
Hello !Do you think that after you format the memory card the virus will gone ? No, I don't think so because if the virus is infected to your phone this will not help.OK anyway Open the Memory Card folder (not from the file manager) I don't know the exact place but try to open from (tools>> utilities) Option and there you'll see "Format memory Card".That's all you need to do.Good luck thanks for visiting fixya
Feb 27, 2012 | Nokia E63 Cell Phone
I don't formats my kingston 64gb pen drive
Hi kingkumarae,
Due to viruses , the drive cannot be formatted in many cases, however if you want to format it ,
I would recommend that you restart your computer and plug in the pen drive and then do not autorun it.
When you do that , you can right click on the drive that you find in my computer and then rightly click on select format option, and then you can format your drive.
If this does not work in your computer you can possibly try it in your laptop using the same procedure.
Hope this helps ...:)
Sep 04, 2011 | Kingston DTU30G264GB DataTraveler Ultimate...
I am having a Seagate FreeAgent portable hard drive(500GB), a corrupted icon is being shown when I attach it to any PC and it gives a dialogue box of "open with" when I double click on it, But I...
Hi amanvirdi198
The problem seems to be an infection of a virus which has changed the icon of your removable drive and also when you open it up you get the "open with" option by default.
Please follow the below instructions.
  • Select show all files option from the folder options which you find in the start menu the path is :-Start - Control Panel - Tools menu - Folder options.
  • In folder options go in the view tab and select show hidden and system files.
  • Once you are done selecting this option , all you need to do is open your removable drive by right clicking on it and select the 'Open' Option , Or if that does not work use the explore option as you have been doing already .
  • You will find that the hard disk now shows up the contents, so you need to find the autorun.inf file in the root drive , once you find it , you have to 'delete' that file, also delete any suspicious hidden .exe file which is in hidden state and of a small size , which is nothing but a virus which spreads as soon as you plug in your external hard drive and the autorun.inf file get's executed automatically.
  • Therefore once when you delete the autorun file , you should have your hard drive working properly.
  • The above method was the manual method , now if you want to delete the autorun problem automatically via a software , i recommend you to download autorun virus killer by clicking on this link http://bit.ly/k3dOve
Hope this helps...:)
Your feed back would be appreciated.
May 26, 2011 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
Recycler folder virus
You don't have a virus, you have the folders without an executeable link. Use windows explorer to delete the files you want to get rid of.
Sep 07, 2009 | Microsoft Windows XP Professional With...
Enable to format my usb pendrive
your pedrive contains {Autorun} virus that's why you are unable to format it to view this virus go to view option in control panel then view and tick the show hidden file and folder
you can remove this virus
install malwarebytes and scan your pendrive
when you remove the virus format your pendrive
IF it not works
I think you use windows xp that's why it happen
Try to format in windows vista .or in windows 7
Apr 14, 2009 | Alpha Digital 1 Bay (HD360SU) Serial ATA,...
Usb flash drive icon changes into folder icon
This issue may have resulted from a virus infection on the machine the drive was plugged into.
You’ll need to delete the file autoruns.inf located on your flash drive.
By default, Windows hides this file, so before you can delete it you must make a couple of changes (you may reverse these after you’ve finished):
Open My Computer
Tools
Folder Options…
Click on the View tab
Under “Hidden files and folder” choose “Show hidden files and folders”
Remove the tick from “Hide protected operating system files (Recommended)
OK
Go back to My Computer and click on your flash drive. If you can’t open it that way, try right clicking on it and choose “Explore.”
Find the autoruns.inf file, right click on it and choose “Delete.” Confirm “Yes.”
Unplug and re-plug the drive in. You should be back to normal.
Hope that helps.
Feb 26, 2009 | LG KU250 Cellular Phone
Unable to view the pictures folder
Hi, I got the solution for myself. Initially I have enabled to view the hidden folder option and even then I was not able to see the folder, then later I have disabled the options Hide Extensions for Known file types and Hide Protected Operating system files. Then I could see the folder and able to retrieve the photos. Once I have taken my photos I have formatted my MMC card and it is working normally.
May 19, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Need manual help to delete TROJAN.ByteVerify from my computer x 2
In the case of a Virus infection I would most likely disconnect the Hard drive from the machine, scan it on another machine ( using AVG7 + AVGAS = AVG Antivirus and AVG Anti Spyware Scan) remembering to turn off system restore while scanning on the drive and scanning in safe mode.
If you have successfully found and removed the virus infection, remember to delete your system volume information and recycler folder on the drive. virus files tend to infect these folders.
Before you plug in your HDD into your machine again, you might want to do a backup of your data, then either do a Windows repair or a Windows Fresh installation (Formating the entire HDD); The repair will attampt to fix the issues that the virus has caused and the fresh install you'll be sure that everything WILL work after installation OR use the Windows repair option AND a registry repair tool to repair registry items.
Another option would be to create a new user name. The settings in that new accound should be working fine and you should be able to access the start menu and your folders again.
Kind Regards
Stef
Apr 16, 2008 | Computers & Internet
Folder options no working
still a virus problem,,, scan with avast antivirus, this one will really help.
but still after a complete scan,, u'll have to reinstall a fresh windows,,
link http://www.download3000.com/download-avast_4_Home_Edition-count-reg-21443.html
Jan 26, 2008 | Microsoft Windows XP Professional With...
Virus!!!!!!
The folder option in the toolbar can be made to be dissappear by fingering in the registry-editor of your computer.
This might be done by a virus.
Try Restoring your computer to an older restore point.
You may do this by
Start> All Programs> Accessories> System Tools> System Restore> Next........
If this does not solve the problem, format your drive with operating system.
Nov 30, 2007 | Computers & Internet
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
230 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
