Question about Toshiba Satellite 1405-S151 Notebook
Typing Thanks for your quick response but it won't let me type when I chose the safe mode with command prompt, it just gives me a lot of: multi(0)disk(0)rdisk(0)partition(1)\WINDOWS\System32\Drivers
  • 655 Answers
Yaa you need to re-install OS whatever you have XP or Vista.
Thanks
Iqbal
Posted on Mar 31, 2008
  • Iqbal Husain
    Iqbal Husain Mar 31, 2008
    keide..... please don't rate any one solution 'Thank for Try'.
    we expert are try to help you free, and your on rating 'Thank for Try' down grade us.... so please if you don't like just leave it or at least rate.. 'Help Full'
    Thanks
    Iqbal
What to do if chose safe mode command prompt to start windows xp
Press F8 just before boot up and the drop down menu will give you that option, if available.
Jul 21, 2014 | Compaq Mini 110c-1001NR Notebook
Change password
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select safe mode with command prompt
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
Click "Start" icon in the lower left corner of your computer screen
Type the word "run" in the window that appears.
A second pop-up window will appear; type in the letters "cmd," then select "OK."
This will bring up the black DOS command screen.
Type next to the administrator account the following command: net(space)user(space) the username(i.e. johnadams) *. After typing this command, hit "ENTER" on your keyboard.
Type in a new password in the command screen prompt that ask you to type a password. Type the new password again once you are asked to confirm.
Type the word "Exit." This will bring you back to your login screen.
Enter the new password that you selected.
Sep 22, 2013 | Computers & Internet
I have an HP notebook. I was on Skype with a friend when suddenly it froze showing green colors on the screen. Nothing would un freeze it so I opted to turn it off through the power button. ...
Step 1:
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive You should have no input while chkdsk utility is in progress any input might further damage your computer also Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file. Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
Feb 11, 2013 | Computers & Internet
Give bios password for compaq 515
As the computer is booting repeatadly press the F8 key as the computer is booting
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
Then type at the C:\> prompt: type
DEBUG
and hit Enter. You'll see a dash (-) at the DEBUG prompt. Now type:
o 70 2e
which will show as -o 70 2e at the DEBUG prompt. Hit Enter. Then type:
o 71 ff
and hit Enter. Finally type:
Q
and hit Enter one last time to quit DEBUG back to the C:\> prompt.
Now you're ready to reboot your PC, and press the appropriate key or key
combo (look it up in your motherboard manual if you don't know it) to access
your BIOS Setup.
Youll notice the password is gone.
If this fails try typing
At command prompt type debug
you will get a - prompt where you can type the following (<enter> means press enter, not type enter*)
A <ENTER>
MOV AX,0 <ENTER>
MOV AX,CX <ENTER>
OUT 70,AL <ENTER>
MOV AX,0 <ENTER>
OUT 71,AL <ENTER>
INC CX <ENTER>
CMP CX,100 <ENTER>
JB 103 <ENTER>
INT 20 <ENTER>
<ENTER> just hit enter on this line
G <ENTER>
Q <ENTER>
Basic BIOS password - works 9.9 times out of ten
If this fails you will need to
Select safe mode with networking to download
you could download all of these or just one save them to a usb drive for later use if one fails to remove the password
http://www.tech-faq.com/reset-bios-password.html
At some stage you might need to press Ctrl+Enter rather than just Enter if on a Dell Latitude E5410
http://majorgeeks.com/CmosPwd_d239.html
A CMOS BIOS password recovery tool
Editors note: This tool should only be used by experienced computer users.
Please see the enclosed read me if you would like to run it from Windows.
Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus.
Hope this helps.
Nov 26, 2012 | Computers & Internet
I can't remember my password to log in on my netbook.
hold f10 or whatever key that it tells you is the setup key when you first turn it on. Navigate the bios with your arrow keys. Find the option that lets you boot into safe mode with the command prompt. Boot it into safe mode and when you get to the command prompt type "net user *" but type that without quotes and instead of the you should type you're user name without the 's. It will then ask you for a password and you'll type in that but it won't show you typing anything. It will ask you to type it again so do that and then boot your system back up and then hold f10 or whatever key it is and to go into the bios and select boot regularly from the options in there.
May 13, 2011 | ASUS Eee 4G Notebook
Pls help me out to get my password
1. Boot up your computer and immediately hold down f1. If it boots up normally then restart your computer and try f2. try all of the f keys and try del or esc until it boots up into your BIOS setup. This will look like a bunch of very blocky graphics. (usually the buttons are either f1, f2, f8, f10, del, or esc)
2. Once in your BIOS, navigate with the arrow keys and enter until you find the option to boot into "safe mode with command prompt" select that option, save your preferences and reboot your computer.
3.Once you've booted into safe mode, log on as the administrator or guest. Usually it does not require a password.
4. At the command prompt type "net user *" but type that without quotes and where it says you're user name just type you're user name without the 's.
5. It will ask you for a password. Type in the password you would like (It won't show the keys or even * that you are typing so that's ok). It will ask you to retype the password so do that.
6. reboot your computer and hold down whichever key that you used to get into setup.
7. Once in setup change the option from booting into "safe mode with command prompt" to the default option which will usually say boot into windows or something to that effect.
8. Log in as yourself using the password that you typed in at the command prompt.
Hope that helps
May 08, 2011 | Computers & Internet
Forgot password and can't login to it cuz haven't used it in a long time
hold f10 when booting. Navigate the bios with your arrow keys. Find the option that lets you boot into safe mode with the command prompt. Boot it into safe mode and when you get to the command prompt type "net user *" but type that without quotes and instead of the you should type you're user name without the 's. It will then ask you for a password and you'll type in that but it won't show you typing anything. It will ask you to type it again so do that and then boot your system back up and then hold f10 to go into the bios and select boot regularly from the options in there.
May 08, 2011 | Acer Aspire One PC Notebook
I have an emaching E627. When I turn it on it shows the e logo then goes to a black screen and just stay therel. How can I fix this?
try to go into Safe Mode:
reboot your computer in Safe Mode by doing the following :
  • Restart your computer
  • After hearing your computer beep once during startup, but before the Windows icon appears, tap the F8 key continually;
  • Instead of Windows loading as normal, a menu with options should appear;
  • Select Safe Mode with command prompt, then press "Enter".
  • Choose your usual account.
Once in Safe Mode, you can do a System Restore:
Log on to your computer with an administrator account or with an account that has administrator credentials.
3. Type the following command at a command prompt, and then press ENTER:
%systemroot%\system32\restore\rstrui.exe
4. Follow the instructions that appear on the screen to restore your computer to an earlier state.
Look for the most recent system checkpoint created before the errors to restore from.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jan 27, 2011 | Computers & Internet
I get a blue screen error message ''c000021a unknown hard error'' after running CHKDSK as a result of receiving an initial blue screen error message ''The Type of file system is NTFS. The volume is...
Hi, Boot into Safe Mode by pressing F8 at bootup and choose
'Safe mode with command prompt'
C:\Windows\system32\restore\rstrui.exe
Hopefully System Restore will open so choose a Restore Point a few days ago.
Please rate my response!! Thanks, SF
Jan 28, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Laptop Will Not Boot
chose start windows normaly
Apr 14, 2009 | Acer Aspire One PC Notebook
Toshiba Satellite 1405-S151 Notebook Logo
70 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
