WIRING DIAGRAM WIRING SET UP FOR GA- M59SLI-S5
  • Deeds45 Apr 18, 2008
    I have bought a Cooler Master 330 Elite case and was planning fitting my old Asrock P4VT8 Board, all going OK but 1 or 2 glitches. seem to have too many wires in the case and the floppy drive pwr and connector cable dont reach the only place I can put the floppy. Anyone have a wiring diagram that shows which wires I dont need and if can re position floppy????
    Cheers
    Dave
  • jimke2004 Dec 24, 2008
    i have the same problem.but i have lsot my manual.pls help me have a copy of it pls
    Motherboard - Foxconn 661fx7mi-S(3y)
I have remove the power switch cable hdd cable from mother board when i put them back my system wasn't geting on please help me
thank you
Posted on Jun 17, 2009
I have a problem in the unit when the central Kabul brought electricity to operate without doing so does not show anything on the screen
Posted on Apr 09, 2008
    Genius:
  • 1,027 Answers
Manual page 30 has setup
link
Posted on Apr 01, 2008
How do I find a wire diagram for a 4949cc mini choppers ga-643f
Hi, Anonymous for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary, transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day.
http://www.tootoo.com/idetail/49cc-mini-chopper-with-two-strokes-ga-643f_24495635_721073_6878978_16262765
49cc mini chopper wiring diagram Google Search
Download 49cc mini chopper wiring diagram
APC Mini Chopper Key Switch
Dec 15, 2015 | Motorcycles
DRIVE nvidia network bus enumerator n 68- succ para xp
http://download.cnet.com/nvidia-network-bus-enumerator/3000-18508_4-98151.html
if this is not what you want or need
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: motherboard name audio driver you might have to try a few times to get it right
hope this helps
Aug 05, 2012 | Gigabyte GA-M59SLI-S5 Motherboard
I have an 8800Ultra in my Ga-M59SLI-S5 motherboard and it works great. I'm running windows 7 with 4 gigs of ram, a 3 gHz dual core AM2 6000+ and a 160Gig raptor. Now I have decided I need more Powaa so...
As far as i know you will need two identical VGA cards to make a SLI board, and you must connect them both with a special cable. After this you must enter to NVIDIA menus and make adjustments from there.
Jul 28, 2011 | Gigabyte GA-M59SLI-S5 Motherboard
Will not boot just clicks
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Mar 30, 2011 | Gigabyte GA-M59SLI-S5 Motherboard
The mother board will power up but the video card , hard drives and cd rom drive wont work
In that case the motherboard's chipset is fried. Time for a new motherboard.
Aug 08, 2010 | Gigabyte GA-M59SLI-S5 Motherboard
Cables not connected for power, hdd light another
http://www.tomshardware.com/forum/261599-30-8istx-wiring-power-switch
Jul 23, 2009 | Intel D845GVSR Motherboard
Fried motherboard c51gm03a1 would like to buy another one
I have done a pretty extensive search online for that motherboard and unfortunately it looks to be discontinued. its an AMD AM2 socket with the Nvidia 590 chipset. If you were to find another board thats AM2 with the nvidia 590 chipset you might be able to get away with installing it and not having to reinstall your OS. I reccomend tigerdirect.com or newegg.com as well as eBay.com for used products.
Apr 20, 2009 | Gigabyte GA-M59SLI-S5 Motherboard
NVIDIA nForce 10/100/1000 Mbps Ethernet not working at 1000 Mbps
http://www.filehippo.com/download_nvidia_forceware_xp/tech/
Feb 09, 2009 | Gigabyte GA-M59SLI-S5 Motherboard
SATA HDD problems
Is this a 2nd hdd added into the system or a new primary replacing a hdd that you removed? If it is an additional hdd you will have to enable it in system bios & then format & partition it before you will be able to use it. Hope this helps.
Jan 23, 2009 | Gigabyte GA-M59SLI-S5 Motherboard
Ethernet Drivers (slow internet access)?
the fastest speed is the slowest path on the network.
right click on the my network place.
right click on the NIC local connection
click on configuration at the right of the connect using (NIC)
second tab, "advanced" check the speed & duplex- it should be auto, but you can change it. do not recommend it.
check resources- make sure it has no conflect with any other device.
if that doesn't help. uninstall the NIC driver and try to find a older driver. Sometime that works better, don't ask me, but it works.
Oct 30, 2008 | Gigabyte GA-M59SLI-S5 Motherboard
Computers & Internet Logo
2,753 people viewed this question
David Payne
David Payne
