Question about JVC HD-61Z786 61" Rear Projection HDTV
HD61G787 TV WENT BLACK NO SOUND, LAMP AND TV LIGHT ON FRONT BLINK RAPIDLY. WHEN TV IS TURNED ON AGAIN FAN STARTS UP AND TURNS OFF RIGHT AWAY.
  • 2 more comments
  • toyolady Jul 26, 2008
    tv was on. all the sudden tv just went off. cut tv on power came on. black screen no sound,fan came on,red light on. tv stayed on less then a minute and powered off again. red light remained blinking radidly.
  • chinookie Dec 02, 2008
    My HD-61z786 was on then went black. When repowering it up the fan comes on and then goes off and both the red power light and the blue power light blink simultaneously.
  • Anonymous Dec 20, 2008
    MY TV WENT BLACK NO SOUND, LAMP AND TV LIGHT ON FRONT BLINK RAPIDLY. WHEN TV IS TURNED ON AGAIN FAN STARTS UP AND TURNS OFF RIGHT AWAY.
  • Anonymous Jan 07, 2009
    Same problem exactally... I have JVC HD-61Z456 ILA and it also shuts off... no video no sound... both lights blink and then will not come back on for more than a minute when I try powering it up. Have to leave it unplugged over night to use it again! This sucks and is getting bad!!!! HELP Please!!!!
Its the lamp
Posted on May 03, 2008
Problem with lamp turning on
maybe try turning off at wall rebooting device can harm the computer if you turn off both you may turn off modem box thingie
Nov 21, 2013 | Panasonic PT-50LC13 50" Rear Projection...
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
When i turned it on screen went black...3 lights started to blink on front of screen
The "LAMP"LED light indication flashes or stay lite?The projection lamp life is over.Replaced the projection lamp.Tv require a new projection lamp.
Oct 19, 2010 | Samsung HLN5065W 50" Rear Projection...
TV went out and will not turn on
try rehooking up your cable for your tv, if it dont work just call your tvs manufacturer
May 26, 2009 | Mitsubishi WD-62327 62" Rear Projection...
TV makes humming noise, lamp light is blinking, does not turn on
Your color wheel needs to be changed. Mine just did the same thing. I changed mine, and the buzzing sound went away, however now my picture washes out with light or yellow colors. The darks look green and purple also.
Mar 28, 2009 | Samsung HL-R6167W 61" HDTV
Mitsubishi DLP - model #WD62725
you have mention that after 10-15 seconds T.V starts up, will you give total description of the T.V within that 10-15 seconds?
Aug 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Tv keeps turning off?
cutta, you will most often hear a click on boot then the fans start up and lamp will then fire. The picture will start to show up....at what point does it shut off? and do you hear a click when the tv is turning off? Is it the complete tv shutting down, fans and everything that turns off? Do you see any lights on the the front panel "POWER", "STATUS" or "LAMP", what are they doing? If you see a Power, Status or Lamp light after it shuts off the below are what they mean if there is an issue. POWER - STATUS - LAMP - CONDITION/ISSUE: Off - Yellow - Off - Temp. high/dirty filter/excess room temp Off - Off - Yellow - 4000 hrs. Lamp usage warning Off - Off - Blink Yellow - Lamp Cover open Off - Blink Yellow - Off - Air Filter Cover open Off - Off - Red - Lamp failure (failed to turn On or broken) Off - Blink Red - Off - Fan Has Stopped Off - Red - Off - Circuit failure (short) or DVI cable disconnected If you want to check for the last "Error Code", after you first turn the TV on, by pressing the front panel ?DEVICE? and ?MENU? buttons at the same time and holding them for 5 seconds, it activates the Error Code Mode. The ?Power LED Light? blinks/flashes (1/2 sec delay) and then flashes again denoting a two digit Error Code indicating no problem or an error has occured since the last Initalization. i.e. "Power light" blinks 3 times (1/2 second delay) and then blinks 4 times then 1 sec delay and repeats a few times. This would mean "Error 34 - Lamp abnormality". See below for error codes..... Error Code - Description or issue 12 - No Error detected, check Power Supply 32 - Lamp Cover is open 33 - Air Filter Cover is open 34 - Lamp abnormality 36 - Light Engine (DMD or LAMP Fan stopped) 37 - Exhaust or Lamp Ballast Fan stopped 38 - Lamp temperature high 39 - DMD temperature high 41 - Short is detected 44 - DVI cable between FMT & Engine disconnected. Sorry for the long answer but it was an open ended question.
Jul 11, 2007 | Mitsubishi WD-52525 52" Rear Projection...
JVC HD-61Z786 61" Rear Projection HDTV Logo
197 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
easy alberta
easy alberta
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
