Hi folks
I have my Arcus II on a Mac Pro via a FireSCSI adapter and i am utilizing the most recent VueScan software. When I try to preview or scan, the scanning head no longer moves nor lights up. Is this simply because the bulb is gone? It is still the original. or is this a different issue? It has run fine in this setup before.
Thank you
-   I have a similar problem. I'm using the Arcus 2 on a mac and when I try to prescan the bulb lights and the scanner begins but then stops.
I've also noticed that when the scanner is switched on it doesn't make all the set-up noises like in the past.
Also, after set-up the two orange lights go off, leaving only the green light illuminated, which is normal, but then when the mac is booted up the two orange lights come back on.
I have an Arcus II Flatbed Scanner that I was using on a Power Mac. I purchased a new G4 Mac and...
(More)
I have an Arcus II Flatbed Scanner that I was using on a Power Mac. I purchased a new G4 Mac and need to know if I can use the Arcus II on this Mac which is USB. If so what is the correct cable to use or do I need some other converter in order to use it. Lynn Hutchinson 813-549-1604 8262 132 st. n. Seminole, FL 33776
Hi can someone help I have losted my transparency template which the book says ' be sure this...
(More)
Hi can someone help I have losted my transparency template which the book says ' be sure this template is being used ' is there any way round it ie can I get a replacement or make one.
This Scanner is awesome---
however, when going to scan from my Apple G3 today
a Dialogue box...
(More)
a Dialogue box appeared to Turn On Scanner---
Everything was the same
Any Suggestions?
Thank-You!
Troubleshooting Agfa Arcus II Flatbed Scanner rattles when..attempt to scan. This scanner was workig...
(More)
Troubleshooting Agfa Arcus II Flatbed Scanner rattles when..attempt to scan. This scanner was workig well for along while, it just started to rattle and not work. However the LAmp is on .
I have Arcus II Scanner SCSI interface I would like to update driver to work on 10.4 OS Mac I would...
(More)
I have Arcus II Scanner SCSI interface I would like to update driver to work on 10.4 OS Mac I would also like to share use on local LAN network Does any one have suggestion Email gac2@tx.rr.com Name Gary
