Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Whirlpool Gold side by side SR2659325
The lights started flickering on the fridge side and a humming sound. I found on burnt out blub. I changed the bulb and the problem continued. The fridge continued working until I changed all 3 bulbs. The fridge stopped working completely except that the lights in the freezer side is working and the lights on the water and ice dispenser is working.
Any ideas on what the problem is and how to fix it?
  • dantera Apr 07, 2008
    please see solutions at diychatroom.com (google "whirlpool fridge flicker" and that should take you to the diychatroom page.).
    President:
  • 1,314 Answers
Are you hearing a hum then loud click hold my rating till we are done
Posted on Mar 31, 2008
GS6SHEXN500 fridge light and display on temp control flickers and sounds like relay making noise
The problem could be very well a relay that has the contacts pitted or weak causing the lighting in display and the interior lights to flicker. Here is a GS6SHEXNS00 Parts List and the relays I can see are in a covered control box near the compressor on page 17 and 18 on the parts list 2304056 Electronic Control I will be here if you should have any questions, Thanks Sea Breeze
Apr 01, 2013 | Whirlpool Gold White-on-White 21.9 cu. ft....
Hear a humming sound when the dishwasher turned on. The panel seems to be ok. Model is GU1500'
Hello & Welcome to FixYa
If the hum sound is coming from the bottom panel then it is the moto that has gone bad and needs replacement. However, if you hear the sound from the control then it can be due to a bad relay in the control and it is recommended to replace the control completely. Please get back to me if you have any other questions.
Kevin
Dec 14, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Light inside the refrigerator flickers (or not) and the door makes a buzzing noise when opened. There appears to be a small light flickering inside the fridge behind the vegetable bend. The refrigerator...
Sounds like the electronic control in the rear compartment by compressor may be bad . There is a light in the crisper as well I believe and that one and the main light are controlled by the control in back.
Dec 03, 2010 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Whirlpool Gold GB2SHDXPS fridge/freezer has stopped working. It is not cold and food is thawing. The light in the fridge and the freezer is still on but it is not cooling.
can you hear a humming sound coming from the back of the refrigerator, if so that means your compressor is running, if you are hearing a buzz or clicking sound your compressor is trying to start, you may need a compressor. Some whirlpools have a 5 year sealed system warranty that would cover the repair.
Aug 22, 2010 | Whirlpool Gold GB2SHDXPS Stainless Steel
Makes viabration noise when blubs installed and blub start flickering. it is six year old Whirlpool gold & just startered happing
It sounds like the bulb is not making good contact with the socket. Try this.
- Unplug the refrigerator.
- Take a blow dryer and heat up the socket where the bulb screws in. Do this for about 1 minute only, be careful not to over heat the plastic side walls so direct the heat on the socket to make sure nothing else gets too warm.
- Retighten the bulb into the socket, this warming will allow the bulb to seat better and tighten up more.
- You can use this same technique when you need to remove a bulb, a warmer socket will let the bulb come out and go in easier.
Apr 18, 2010 | Whirlpool Refrigerators
Whirlpool Gold Black on Black 21.9 cu
I had the same problem. The light would dimly flicker and make a sort of clicking noise. It was still under warranty and the repair man had to replace a circuit board in the back. Not sure of what the cost would be if not under warranty. Hope this helps.
Oct 23, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold refridgerator light not working and is making funny noise
Had the identical symptoms with my Whirlpool Gold GS6SHEXNB00 side-by-side refrigerator. Had a technician come on site, indicated it was the "circuit board/ timer" (Whirlpool part # 1394052). Board is accessible from behind fridge (lower left side in a white plastic housing to left of compressor).
Swapped the board out (noticed a scorched circuit on the old circuit board). Lightbulbs now work, temperature readouts also good to go.
Mar 03, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool side by side fridge freezer
 if posible try turning off over night, if its ok when you start it back up after 24hours, defrost not happening, ice builds up air flow is restricted
Oct 18, 2007 | Whirlpool ED2FHEXN Side by Side...
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
166 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
