I have just bought a wireless router for my laptop and share it with my aunty next door...it is less than 10 metres to my room and yet it wont reach (despite the router 'apparently' able to reach 100m. why?? help me x
  • 55 Answers
Go to properties and set the range of wireless connections.
thanks
Posted on Mar 31, 2008
SOURCE:
Limeted coonection to our router 20 netbook to 4,5 mbs router shared to the network
Get the router up to a highest point in the room. If it serves multiple rooms, put it at the highest point in the biggest room. Be realistic about where it can reach too given a basic G router. If it serves two floors then the basement corner will not have 100 percent
Jun 14, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
My Belkin Wireless router has always only one or no bars of connection and my internet is always running slow or cant connect. The router is in the next room near the phone line with one single brick wall...
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Sep 22, 2010 | Belkin (F5D9230-4) Wireless Router...
Something is blocking wireless signal, i live in flat so in one room there is wireless router and in other room signal is very poor sometimes it's not connecting. i tryed 3 diffrent routers the last one is...
There are several likely causes, if the building has plaster walls it may have metal lath behind it blocking the signal.(this is fairly likely the cause) If there are high-power microwave transmitters within 2 or 3 km, can cause spotty interfering. Neighbors with a wireless router close to your wall can as well.
If you can move the router to a position across from the door between the rooms, you can test by connecting (wireless) your laptop near the router, then walk it into the other room (stay where you can see the router). If the laptop stays connected move across the room to a point where you did not have a signal previously, if you are still connected leave the laptop there and move the router back to its original location and recheck the laptops connection, if it is gone, it is your wall...
Apr 23, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Router not powerfull enough to connect to laptop in other room
the topic states you have a G router so a g or b will connect. make sure the laptop is not higher then that eg: an n wireless adapter.
Nov 30, 2009 | NetGear / WGR614 / 54Mbps / 802.11g /...
Router issues in my apartment.
When to moved into the penthouse, there are more walls between the wireless router and the laptop in the bedroom. The walls are probably reinforced concrete walls which will stop or weaken the radio waves penetrating into different rooms. When you lived in a house this was not a problem.
The only way to solve this problem is to move the wireless router near an opening such as a door and move the laptop as close as possible to the wireless router to get a better signal strength.
The outer way is to install a wireless repeater or connect a long network cable to the router and the laptop.
Jul 29, 2009 | D-Link Dlink DES-3028P Switch 24-port...
Wireless range/signal seems very weak
ok the problem is that ur using a wireless b modem
the wireless b is the shortest of the classes of wireless routers
you should go with a G or N series
this should solve ur isse
the B series is for one room operations then the signal has to go through ur home that is more resistance on the signal
you could also buy a 2wire modem /router at best buy
that covers ur whole property with ur wireless range
but u will pay the same in one router as this 2wire single unit
Apr 11, 2009 | Gateway Wireless-B Router (wbr-100)
Sir, i cant acces irles internet conection from my room,becuse i don't know pasword
Try accessing the configuration page of your router by typing 192.168.0.1 on the address bar of your browser and log-in to the dlink.
>Configure your wireless setting on this window.
>Under setup click on wireless setting
>Then click on manual wireless ....setup
>You will have the configuration of your wireless network.
>You may use WEP or WPA for your password on your security
>For WPA with pre shared key or passphrase the minimum character for your password is 8 characters
>For WEP with pre shared key of passphrase the minimum charactere for your password is exactly 10 characters.
>Once you have save your wireless network
>Go to your laptop and connect to your wireless network before
connecting to the Internet.
Jan 12, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Wireless Internet
yes you can purchase the router
Wireless-G Broadband Router
satellite?blobcol=urldata&blobheadername1=content-type&blobheadername2=content-disposition&blobheadervalue1=image%2fjpeg&blobheadervalue2=inline%3b+filename%3dwrt54g.jpg&blobkey=id&blobtable=mungoblobs&blobwhere=1193783379233&ssbinary=true
  • All-in-one Internet-sharing Router, 4-port Switch, and Wireless-G (802.11g) Access Point
  • Shares a single Internet connection and other resources with Ethernet wired and Wireless-G clients
  • Wireless data rates up to 54Mbps -- 5 times as fast as Wireless-B (802.11b), but also interoperable with Wireless-B devices (at 11Mbps)
  • Advanced security: Wi-Fi Protected Access™ (WPA), wireless MAC address filtering, powerful SPI firewall
May 02, 2008 | Dell Inspiron 6400 Notebook
Gamin adapter set up, plz help
Hi Shawn. Does yout PS2 connect when it is downstairs on the wireless? Reason I ask is wifi routers tend to transmit horizontally, and are very weak in vertical transmittions.
If you are connecting while you are own stairs, we can assume the WEP is not an issue.
WEP setting vary on different adapters. Some allow your to use 5 digits for your wep code, others require the full 10 digits. If you are using just 5, say 12345, try putting a 3 infront of each digit, i.e. 3132333435. If you are using all 10, on bought the adapters, this shouldn't be a issue.
Of course, if you can connect to while downstaris, this issue it mute.
You can also try changing channels. Channel 1 has more range than channel 8.
The last guess is that yoour router has less range than the Dlink.
See if any of those suggestions help, and let us know.
Good luck.
Dec 29, 2007 | Linksys Wireless-G WGA54G 802.11g/b...
Computers & Internet Logo
Ekse
Alun Cox
