Question about Xerox C2424 Copier
Xerox copier C2424 error CT3
We just replaced the maintainence pack and now we are getting a CT3 error in which the paper is jamming in tray one before we even start a print job. What is going on it is making grinding noises now too.
  • rhodek Feb 17, 2009
    CT3 error, based on the response. I will change the maintenance kit and check back...
    Ken
    President:
  • 2,072 Answers
Your maintenance roller could be out of place in the kit. Since you just replaced the kit and getting the grinding noise. Sounds like you have a problem with that kit binding as it pivots up and down away from the drum.
Posted on Mar 31, 2008
Xerox C2424 error code 19,003.48 and 07,010.43
for error code 07,010.43
Access the power switch by opening the Interface Cover on the right side of the machine.
click on this:
for maintainance
http://www.office.xerox.com/userdoc/C2424/C2424_Web/pdfs/en/ug_maintenance.pdf
for troubleshooting:
http://www.office.xerox.com/userdoc/C2424/C2424_Web/pdfs/en/ug_trouble.pdf
Jan 30, 2008 | Office Equipment & Supplies
Xerox workcentre 5020/Dn c1 error
i have one xerox 5020 machine, there is display showing C1 error code in first tray and C3 error code in bypass tray .if open and close the machine will be idle and ready to cpoy. there is no paper pick up in both trays. please help to resolve the problem.
Dec 17, 2012 | Office Equipment & Supplies
The wiper blade is stuck to the print head of my xerox c2424 printer. how do you take the ink cartridge tray out to get to the print head. i have it torn down that far...bonnie
The printhead and wiper could be heated to soften the ink.
Enter Diagnostics by holding the back arrow and "i" button while powering up. Go to the Monitor menu and turn on "All Heaters"
After a few minutes, it should be able to be moved away.
This situation may have broken 2 Camshafts and perhaps even motors. If you continue to get an error 07,010 then buy this kit "C2424-Z2" It may require a technician to install.
Whit
Item, Inc.
Oct 01, 2010 | Xerox C2424 Copier
Xerox c2424 has error message "Waste Tray Missing". Have emptied waste tray which was overflowing and placed it back in machine but above error message means it will not work.
The Waste Tray Optical Sensor 119-6487-80 is probably bad, which contributed to the overflowing ink. Look at the diagram #6
Whit
Sep 10, 2010 | Xerox C2424 Copier
System error 09,005.40:143310 Xerox workcentre c2424
You either have jammed ink sticks or a bad Ink Loader 200-4711-80
It is fairly easy to replace, if you can get the covers and Document feeder off.
Whit
Item, Inc.
May 06, 2010 | Xerox WorkCentre C2424DN All-In-One Laser...
Error code-07,010.43:19044 I'am a Tech, and I got this code when testing a machine?
I am a tech also. This sounds like a paper path code.
On some of these machines the motor drives all feed rolls on all trays. Some have independent motors for each tray.
If you are using one tray check to see if that motor is working. Sometimes they will just momentary start then shut off. This could be a bad motor PWB or a main board problem.
Actuators on these sensors will hang up. Check the actuators to see if they are operating. If you can swap a tray sensor with another see if this changes when feeding paper. One sensor might be not working right.
Check the doors to see if they are closing right. The drive rolls might be not be holding on the paper causing stalls and constand paper jams.
Check to see if the rolls are binding. They appear to be fine until you spin the rollers, they should spin free.
Good luck.
Oct 02, 2009 | Xerox C2424 Copier
I am receiving error code 39,012.40:76243 on C2424
Replace document feeder. 004k07270 $390.00
Sep 04, 2009 | Xerox C2424 Copier
Xerox C2424 Copier Logo
144 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
