Question about Lite On LiteOn LH-20A1P - Disk drive - DVD±RW (±R DL) / DVD-RAM - 20x/20x/12x - IDE - in Burner
My LH20A1p186c Lite on dvd writer will not do anything. A simple swap into my comp with 3 cables and the comp. does not recognize the new hardware. In fact both dvd and old cd player appear tp be one according to the computer. My other burner was recognized as drive F/: which no longer exists.It seems that dvd writer is not even there. Please advise. recent purchase from Tigerdirect
  • 165 Answers
Check the Master Slave jumper on the back of the drives. If using 2 drives on 1 cable, make sure one is set to master and the other is set to slave. The jumper positions usually are labeled on the top of the drive as "M" and "S"
If you have them set to the same, both drives won't work.
If the drive is sharing cable with a hard drive, try changing the M/S setting.
Posted on Mar 31, 2008
Does not recognise disc
reading ability on lite on will dropped drastically. you can use other writer to burn that disk to minimum speed such as 4X.
then try it on your lite on.
if still cannot be recognized mean the optical sensor is broken or dirty.
Mar 04, 2011 | Lite On LITE-ON SOHC-5236V COMBO BK OEM...
COMPUTER NOT READING IT, NOT BEING RECOGNIZED BY COMPUTER
Turn your computer off, and unplug the AC power.
Open up your computer, and unplug the "data" and "power" cables from the DVD-drive, and then reconnect them. Check that the "other" end of the "data" cable is firmly attached to the motherboard.
Reconnect the power, and restart the computer.
Press DEL to enter BIOS-setup mode.
Is the DVD-drive still not detected?
If it is not detected, it probably is electronically "dead", and needs to be replaced.
Nov 05, 2009 | Philips LITE-ON 20x DVD RW Drive -...
DVD Writer not recognizing DVD
the drive is not recognizing any dvd. this happens when you insert dvd into cd drive. if this happens with dvd drive its factory malfunction probably so if you can-replace it
Oct 02, 2009 | LG GSA-H55N DVD-RAM Burner
HP dvd1040i only recognizes discs for a few minutes.
it is the simple poblem of hardware you want to change your cd drive now
Jun 26, 2009 | HP DVD1040i 20x Super Multiformat Dvd...
My lite-on combo sohc 5235 is not recognized as a dvd/cd writer but only cd after having my computer reformatted... i lost the installer... what to do please?
http://www.liteonit.com/global/index.php?option=com_wrapper&Itemid=75
XP should recognize it any way.
Nero capabilities depends on clean install/version of itself.
XP SP3 runs fine with Nero 7 again without that mindexerror popup
Propably you installed SP3 and had Norton also there being the virus?
May 01, 2009 | Lite On (SOHC-5235K-BKRTL) CD-RW/DVD-ROM...
Cpu doesnt recognize new drive
ok i may be able to help, first of all i must ask if you plugged the cables in correctly and didnt forget the power connector.
secondly, have you been into the BIOS and checked weather or not the device shows up there? to access the BIOS (basic input output system) usually you have to repeatedly press the delete button or F1 button as as the PC boots up(before windows loading screen). If you see the device in the BIOS then you should unplug the drive and return it to it manufacturer. If it does show up in BIOS, also check to see weather the drive is compatible with your current version of windows, this also includes the service pack you have installed. if the device does not show up in BIOS then check the cables again, check for any phsyical damages and return to manufacturer. if this dosent help you im sorry, but theres not much you can do if hardware decides it dosent wanna play.
Mar 14, 2009 | Lite On Lite-On LH-20A1L-06 SuperAllwrite...
HP DVD 1040i
on the back of the hardware are jumpers
mine are located next to where the ribbon plugs in
there are 3 jumpers- like this : : :
the jumper must be on "cable" ( printed above post )
just move the jumper and reinstall
Now xp can find the 10401
I did it...it works
Dec 30, 2008 | HP LightScribe dvd640i (DVD640I)...
Installer
Depending on your opearating system CD-WRITER LITE-ON LTR - 52327S and any other cd writer lite- on are plug and play devices which does not need an installer.
All you need to do is properly connect your CD writer on your pc while your machine is off, when you turn on your computer it should be displayed under my computer.
If its not shown under my computer window then its either.
1. Your device is not properly connected
2. Your device have a power fauilure problem
3. Your cabling is faulty
If your device is connected but does not function properly you can
1. update your driver
Mar 24, 2008 | Lite On LTR 52327S CD-RW Burner
DVD rewriter wont install
yeah i have the right solution,
right click on my computer ----> select properties and in that select ---->hardware tab ----> advance and select----> device manager ------> select IDE ATA/ATAPI controllers (expand it ) and go to SECONDARY IDE CHANNEL right click select properties and in that go to advance and in that change tha transfer mode to PIO ONLY from DMA IF AVAILABLE(its default)
Aug 25, 2007 | LG GSA-2166D DVD RW Dual Layer Burner
New DVD/CD Writer is not recognized
Try the drive in another machine to isolate the problem. If the drive works and its your system you may have to do the following Update your BIOS Place the drive on the other IDE channel. If there is only one IDE channel on your system board it sounds like you already have the jumpers set properly. If this is an older system you may only have a 40 pin cable, make sure you have a new IDE cable. The cable may also be damaged. Check the power to the drive. If none of that works and it is working but absolutly not compatable with your hardware you could purchase an external enclosure for it and connect it with the USB or Firewire. Hack
Jul 09, 2007 | Pioneer DVR-710 DVD±RW Dual Layer Burner
Lite On LiteOn LH-20A1P - Disk drive - DVD±RW (±R DL) / DVD-RAM - 20x/20x/12x - IDE - in Burner Logo
108 people viewed this question
Top Lite On Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Michael Vanidestine
Michael Vanidestine
Level 1 Expert
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
