Question about George Foreman GRP99 Indoor Grill
Handles broke off
My grill plate fell off and the handles broke where the screws go in the metal plate underneath. Is there a place I can replace my handles?
  • bugsbuni70 Apr 24, 2008
    I tired the advice given to slove this problem and have gotten no where. any other ideas?
  • 19,396 Answers
Here is also the contact for Salton Europe:
Address : Failsworth, Manchester, M35 OHS, England Handles broke off - pixel.gif Phone : +44 (0)161 947 3000 pixel.gif Fax : +44 (0)161 682 1708 pixel.gif E-mail : Sales@saltoneurope.com
Posted on Apr 07, 2008
    Genius:
  • 3,422 Answers
You can try to get the parts from HERE
Goodluck,
Please don't forget to rate the solution
    Master:
  • 788 Answers
Send an email with your request for information on replacement handles to: foremangrills@saltonusa.com
  • Dean Joly
    Dean Joly Apr 07, 2008
    The grills are manufactured by:
    Salton, Inc.
    3633 Flamingo Road
    Miramar, Florida 33027
    Phone 954.883.1000
    You might get somewhere by calling or sending them a letter.
  • Dean Joly
    Dean Joly Apr 25, 2008
    Unfortunately if none of the contacts provided previously have enabled you to purchase a replacement handle then you just might be out of luck. It may be time to purchase a replacement grill alltogether.
    Guru:
  • 377 Answers
Hi dear
visit this site
http://www.esalton.com/004c/img/Use_Care/GRP99.pdf
for manual reair
and this site for order your grill
http://www.canningpantry.com/emg-grp99.html
ok
  • 818 Answers
    Master:
  • 555 Answers
Call 1-800-233-9054 to speak to a customer relations person at Foreman Products to order spare parts for your grill.
Door handle on my 2000 Buick Park Ave wont open the door, the door will open from the inside, is a part on the handle broken
Either the linkage fell (broke) off, or the handle itself broke. Most handles are only plastic afterall. You can buy new outside handles for fairly cheap ($20 or so). Installing them can be easy or tough depending on the vehicle - soem give you room, some do not. But the job is very straight forward - start by taking off to inside panel. Locate the (should be two) bolts/nuts that hold the handle in place. Take off the lock (held in by retainer clip) and the linkage (metal rod with plastic retainer clip). like I said, pretty straight forward. (make sure the window is all the way up before you start).
Jan 23, 2011 | 1999 Buick Park Avenue
Hello i am cleaning my parkinson cowan cooker and i have took the gill door off and i cant put it back on, just wondering if you have instrouction please? thankyou
Position the glass between the metal plate and the white plastic handle contraption and secure with 4 screws. This is not very stable so hold the glass securely.
Pull the grill door forward 4inches, place the glass assembly with the lugs at the bottom in the corresponing holes on the grill door.
Move the top white handle and glass thingy towards the top of the grill door.
The secret to how this works is to make sure the sticky out things with holes in at either end of the metal plate/glass/plastic handle go under the lip of the grill door.
Place the remaining unattached to anything 2inch wide metal plate above the lip.
All the holes will line up. The screws screw into the affore mentioned sticky out things with holes in.
Thats it.
If you by any chance want a new website look at this.
Nov 06, 2010 | Parkinson Cowan SG553 Dual Fuel (Electric...
I have a house which was built in 1965 and i need to repair the bathroom faucets. the problem is that when i try to repair the faucet i can not remove the little round thing on the front of the faucet...
Double handle controls, correct? Stamped metal? Thin and can be fragile, but will take some abuse. Okay, take a putty knife, or thin blade flat screwdriver, and place it in the groove that should be about 1/8" inch from the faucet handle top, hold that at about 25 degree angle, and strike the handle of the putty knife or screwdriver lightly. I don't mean a touch like tap, but don't take a mighty swing at it either, Just a little tap, or two, and any corrosion, rust, ect. should let go and the cover should raise a bit. In the alternative, if you can't get them to move or pop off, you can drill through the top of the handle with a 1/2" bit, and reach the phillips screws that hold the handle on that way. replacement knobs are available at Lowes, Home Depot, 84 Lumber, ect. But if the covers are stuck that tightly, then the handles probably are too, I've actually had to use vise grips and destroy the handles to get them off, and then replace them. Just be a bit patient, and they should remove. And if you have to drill them, only drill through the cover plate. About 1/4" should do. Put a peice of masking tape on the drill bit about 1/4" from the end and drill slowly and stop when it goes through. Otherwise you may mess up the phillps head screw that lays underneath. The replacement handles are pretty inexpensive, and if yours are pitted, scarred, rusted, or lost their luster, these will brighten the faucet area nicely. Plan on spending around 6 to 8 dollars for replacement handles. Still, thats cheaper than a faucet replacement.
Sep 28, 2009 | Plumbing
The plastic handles that dispense the water are broken
Where can I buy the spigets for a Sunbeam water cooler. I need one for hot and one for cold water. These handles are not strong enough plastic to last the lifetime of the unit. They should be made from metal. If the taps on our kitchen sink was made from plastic you can imagine how long they would last.
May 27, 2009 | Sunbeam Refrigerators
Need new door
No need to get new door if it's only the handles that broke off, unless they fell through the rust or something. Buy a new set of handles from dealer or parts place, or even autorecycler (wrecking yard) and change them.
Feb 02, 2009 | 2003 Ford Taurus
Needing new handles for the removable plates on my George Foreman GRP4.
Hi beccagc06,
I'd contact the manufacturer (Salton, Inc.) customer service site for parts or manual. If they don't have them, they should know where to send you (though if they don't, I'd seriously wonder about the company).
Go to
http://prc.prodregister.com/prodprotect/applica/
And click on "George Foreman" (lower-right portion of the page), it redirects you to a secure webpage where you can register.
https://secure.prodregister.com/prodprotect/applica/gf.shtml
Part of the page reads:
"Call toll-free or visit our websites for assistance if you need more help.
Parts & Accessories:
Phone: 1-800-738-0245 (Monday–Friday, 8:30 a.m. to 8:00 p.m., ET)
Product Warranty:
Service: 1-800-231-9786 (Monday-Friday, 8:30 a.m. to 8:00 a.m., ET)"
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Sep 28, 2008 | George Foreman GRP4P Indoor Grill
Grill handles broken
I have the same problem, so if you find a source for handles, let me know. Thanks!
Jul 24, 2008 | Wolfgang Puck 781698 Indoor Grill
Handles fell off
I have a Foreman GRP99 that has a broken Grill Plate Handle.
I called 1-800-233-9054, Fox-International, and ordered a new handle for $14.95 including Shipping.
Maybe they have support advice?
Dave in Ohio
Apr 07, 2008 | George Foreman GRP99 Indoor Grill
G5 Handles on plates
called salton and ordered new handles for the plates
Mar 26, 2008 | George Foreman G5 Indoor Grill
Broken lock on grill plate
If you find a source for a replacement locking handle, we would appreciate you letting us know. Likewise, we will let you know if we find a source. Thanks, utxfamily@aol.com
Aug 29, 2006 | George Foreman G5 Indoor Grill
George Foreman GRP99 Indoor Grill Logo
232 people viewed this question
Top George Foreman Kitchen Appliances - Others Experts
Mike
Gerry Harvey
Gerry Harvey
Angel Joseph Jr.
Angel Joseph Jr.
Are you a George Foreman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
