Question about Toshiba Satellite 1405-S151 Notebook
Laptop won't comeback on
My laptop battery went dead on it while I was using it. When I charged it with the AC I turned it back on and the Toshiba emblem comes on then a screen saying:
We apologize for the inconvience, but Windows did not start successfully. A recent hardware or software change might have caused this.
If you computer stopped responding, restarted unexpectedly, or was automatically shut down to protect your files and folders, choose Last Known Good Configuration to revert to the most recent settings that worked.
If a previous startup attempt was interupted due to a power failure or because the Power or Reset button was pressed, or you aren't sure what caused the problem, choose Start Windows Normally.
Safe Mode
Safe Mode with networking
Safe mode with Command Prompt
Last Known Good Configuration(your mose recent settings that worked)
Start windows Normally
Use up and down arrows keys to move the highlight to your choice.
- Now I hightlighted Start windows Normally and I got the Windows page and it look like it was loading but then it went to a dark screen. Nothing came on, none of the keys worked. And I turned it off and tried the Last Known but that did the same.
Please help I have to retrieve my pictures from it.
  • 1 more comment
  • Keidelberg Mar 31, 2008
    Nope that didn't work Prisni, all it did was give me:
    multi(0)disk(0)rdisk(0)partition(1)\WINDOWS\System32\Drivers
    A bunch of times with various drivers.
    That didn't work either just gives me
    multi(0)disk(0)rdisk(0)partition(1)\WINDOWS\System32\Drivers over and over till it filled the screen.
  • Jeffrey Pemberton
    Jeffrey Pemberton May 11, 2010
    Is your cd drive set to bootable? If not can you get into your bios to make it so it boots from your cd drive before your hard drive? If you can and you have your original Windows cd or maybe one that did an upgrade from, you may be able to do a repair from the Win cd. If you need help if you think this is possible, give a shout.
  • 652 Answers
1. select safe mode command prompt
2. type SCANREG and press enter key
3. follow the screen instruction
4. select the old one date when your computer was working well, from the restore list appeared.
5. reboot
and finally.............:))
Thanks
Iqbal
Posted on Mar 31, 2008
  • Iqbal Husain
    Iqbal Husain Mar 31, 2008
    means you did not get command prompt. hmmm then you have to re-install your OS. becoz its got currepted badly.
    So, if you have setup cd/dvd and want some help about installation, then just Ask me.........
    thanks
    iqbal
  • 58 Answers
Try safe mode.
On safe mode return the computer to an earlier date configuration.
At some point will ask if you want to do that. And say yes.
Make sure that if for some some reasons it asks you to restore the computer to factory settings, you should say no. I hope you can do this.
No power
Hello, If the battery won't charge and the laptop won't turn on but the ac adapter works with other laptops, then the problem is the port where you plugin the ac adapter. Some of the laptops has it built in to the motherboard. So you might need to have it repaired by a technician. Or if the laptop is still in warranty, you might need to send it to the manufacturer to have it repaired or replaced. But if the laptop works without the battery, or it will turn on but the battery indicator is not lighting up, you're facing one of these problems. 1. The battery itself is dead. 2. the battery bay is loose 3. the battery itself is loose Hope this helps
http://www.chargerbuy.com/laptop-ac-adapter/toshiba-ac-adapters.html
Nov 10, 2012 | Toshiba Computers & Internet
Battery won't Charge
Hope this helps
Nov 04, 2012 | HP Computers & Internet
Laptop Battery Won T Charge on a laptop dell inspiron 1525
Battery could be dead and won't hold another charge. Batteries only last for so long until you have to replace them. If you laptop is ok with the AC Adapter & Power Cord meaning it boots and allows you to work in windows, then the battery is definitely dead.
Mar 19, 2012 | Dell Computers & Internet
Netbook charging indicator light won't light and battery won't charge. AC adapter works on other computers
Hope this helps...
Sep 15, 2011 | Gateway LT2021u Netbook
I have a toshiba laptop about 2 years old. I didn't use it for a few days and now it won't turn on at all.
was it plugged in when you tried to turn it on?
if not, try charging it for a couple of hours. the battery must be completely empty
other than that I might need more details
Aug 07, 2011 | Toshiba Computers & Internet
My toshiba satellite pro doesn't work , even with charger in , it doesn't turn on , its like all the power is gone :o ?
You may have a bad DC connection:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it
Dec 16, 2010 | Toshiba Satellite A60 Notebook
Toshiba Laptop not charging
So confusing...Laptop AC Adapter nowadays has AUTOMATIC VOLTAGE, meaning it doesn't matter if it is 110v or 220v. Maybe you've got a FAULTY BATTERY. Remove the battery and plug in your AC Adapter to outlet and to your laptop and try to power-on.
machinetosh of (tipidpc.com) site
look for kuya boy laptop
Global PC Laptop Professional Services
09126888500
Apr 02, 2010 | Toshiba Satellite A100-S8111TD Notebook
Toshiba satilite P100...wont turn of
Try these:
1. Can you plug something else besides your laptop into the outlet...verify you have power?
2. Is there a light on your AC adapter...when you plug it in?
3. Try removing your battery and plugging it in, and verify that your AC adapter is working (somehow, if it has no indicator light)
4. Then unplug it, put the battery back in and see if it will start.
Let us know what happens after you try these.
Apr 12, 2009 | Toshiba Satellite P100 Notebook
Problem with laptop- no power
The battery needs to be taken out once in a while. It is possible to use the ac adapter and power cord without the battery to power your laptop. Please press on the power button for 10 seconds for your computer to turn on. Check if you can see any message on the screen.
Sep 04, 2008 | Toshiba Satellite A105 Notebook
Turn on
Have you checked your power adapter with a digital multimeter? Maybe run it by your local radioshack or computer super store if you dont have a DMM and see if someone can check the voltage on it. Maybe your adapter died, then the laptop was running on battery until it went dead.
Another quick check, remove the battery all together. Plug in the ac adapter... does it turn on? does it show any lit led's indicating it is plugged into the wall? try wiggling the connector at the jack on the laptop, does that light any led's or cause power to be restored?
Oct 31, 2007 | Toshiba Satellite A105-S4004 Notebook
Toshiba Satellite 1405-S151 Notebook Logo
184 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
