Rca tv problem
My tv is showing all three colors on screen. that is the reason i went to my manuel to see what the problem was. it told me to go to main menu and click on screen then on adjust projection tv. i have no adjust projection inn the selection box. the three colors are all showing at the same time.
  • 2,336 Answers
It is a common failure. It requires replacing a couple of ICs that we call STKs. The cost of repair is always $400 plus or minus unless you can do it by yourself (You should have some basic hand soldering skills in order to do the work because it requires some soldering AND some further testing for other components that may have failed in addition to the ICs).
Check for a part that looks like the one in this link but with a different part number that is mounted on a big heatsink.
Let me know if you require further assistance.
Posted on Mar 31, 2008
My RCS HD52W67 is showing three pictures on the screen. I have tried zooming, but it only makes all three pictures larger. I cannot get it to only show one screen. What can I do?
Your TV most likely has a convergence failure. You can get parts and instructions from www.tvrepairkits.com Here are some of the most common symptoms and example photos of a convergence problem Screen looks 3D Colors don't line up One or more colors can't be adjusted when using the convergence menu. Screen is bowed or warped.
Nov 22, 2012 | RCA HD52W59 HDTV Projection Television
The color was off on the tv i took the bottom back off and there was a box with three screws on top and three screws on bottom that adjusted the colors when i turned the top left screw a little the three...
turn the center dial ( for green) down slightly then turn the other two the red and the blue up slightly to get the best screen without a dominate color screen.
Sep 02, 2011 | Philips 50P8341 50" Rear Projection...
Converging problem
This is a rear projection TV that uses three color "guns" in a cathode ray tube . They are no longer converging at the screen. The convergence problem is usually a sign of something else gone wrong with the high voltage.
Do NOT attempt to open this set yourself. This type of TV can have LETHAL voltages inside for WEEKS after it is unplugged. The repair and convergence calibration will require a qualified service technician.
Jan 09, 2010 | RCA HD52W59 HDTV Projection Television
Convergence issue-60 inch RCA projetion TV
it is under set up options in the menu
Oct 16, 2009 | Televison & Video
RCA HD61W66 My Picture Went Round and The Three Colors Are Out Of Sync. And the menu screen would flash on and of erratically.
Ur convergence is dead.Tries these websites.Tv Repair World.com Shopjimmy.com.For many DLP Tvs convergence kits for repair.
Jun 25, 2009 | RCA HD61W66 61" Projection HDTV
Rca r52wh74 - no auto convergance
fl231 is solderd in and will have to be replaced along with DL231 and CL230
Apr 07, 2009 | RCA Televison & Video
Go to menu then setup look for convergence if it is missing on menu then you have a open FUSE/ FL231, But if you have convergence on menu then go into service mode turnTV off then PRESS and hold at same time ch- and vol- wait for set to come on then release TV should now be in Factory settings.
Feb 20, 2009 | RCA D52W23 52" HDTV CRT TV
Rca tv screen went all red. you can still see program
Color wheel controls the color. try replacing then reindexing the color wheel. Let me know if you need further assistance.
Mar 14, 2008 | RCA HD61LPW175 61" Rear Projection HDTV
Showing picture in three segments
Test through MENU? explan that please. are there different colors that lead you to idea that is convergence.
Jan 10, 2008 | RCA HD52W56 52" Rear Projection HDTV
RCA HD52W59 REAR PROJECTION
there should only be three colors.. can they be aligned?
Sep 16, 2007 | RCA HD52W59 HDTV Projection Television
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
