Pyramid PA1000X Output Problem
Hello. When driving the amp beyond 50% on VU, the output shuts off, amp clicks and resets. Happened all of a sudden. Amp used in same configuration for past 2 years. Thanks.
  • Bob
    Bob Dec 05, 2008
    I don't think it's DC current leakage. It seems the overload sensors on these have a hair trigger. Mine will occasionally do it even at -20db. I have two other amps and they don't give me any problems. I didn't do my homework and picked one of these up cheap. I won't buy another Pyramid low power amp. It doesn't push the RMS110 watts either with out clipping bad.
  • 4,234 Answers
You probably have some DC voltage leaking through to the output stage and the protection circuit is kicking in to shut it down. Look for a problem in the front end (pre-amp). If you are not familiar with electronics, expect a parts cost in the $30 range plus the local labor rate for repair.
Dan
Posted on Mar 31, 2008
SOURCE:
I've bought a pyramid crystal 1000 watt 2 channel amplifier used it states it runs at 4 ohms can I run it at 2 or 1 ohms and if so what will the wattage be?
Not to disappoint you too much, but the 1000 watts advertised is just marketing hype. If your amp is the PB781X, it should have only a single 15A fuse on it. Your battery provides 12.5 volts when the engine is off, so at most, your amp draws 187.5 watts of power. Draws, not outputs. No amp is 100% efficient due to heat. When your engine is running, assuming your alternator outputs 14.4 volts, your amp's maximum power draw is about 216 watts. Again, this is what your amp draws, not what it puts out. What you should focus on is the RMS (continuous) output, not Max or PMPO. Those numbers are useless, unfortunately.
Your amp is rated to output 50 watts per channel at 4 Ohms, and 75 watts per channel at 2 ohms. This is when wiring your channels separately, not bridged. I did not see true power specs for your amp while bridged, but it's possible you'll just get the full 150 watts to the single bridged output. Do not attempt to apply a 1 ohm load to your amplifier, as you will run the risk of damaging it. It's not designed to handle a 1 ohm load. If you're lucky, you'll blow a fuse before the amp is damaged, but either way, there is nothing to be gained by attempting it.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/reginald_bec291de192ca44f
Sep 12, 2017 | Pyramid Car Audio & Video
How to wire a pyramid graphic equalizer sea-4600 to a pyramid pa1000x
Deja vu.
Recommend contacting a local car audio professional or Pyramid customer support directly here:
http://www.pyramidcaraudio.com/ContactUs.aspx
Jan 19, 2014 | Pyramid Car Audio & Video
Older Cr 1604, powers up but no output, suddenly after gig.
The power supply is located in that area on one side. It is possible that one of the output op-amp ICs has failed. There are a number of 4558 ICs used as output buffers for this unit. Without seeing the unit and testing parts of it, I can't say for sure. These are not the easiest to work on as they are really compact. Where are you located? I may be able to suggest a service center in your area. The repair cost should not be too bad. The parts are cheap and readily available. Please update this with your location. Thanks, Dan
Jun 06, 2009 | Mackie 1604 Vlz3 16 Channel Mixer
Re: Pyramid PS-36kx power supply buzzer sounded,red light came on
Hi! I saw your question, and maybe this will help. I also have a Texas Star 100w amp, and this same power supply. Even though the nominal draw for your equipment is way below the rated amp flow of the power supply, when you key up, and the output on the amp is at max, you are drawing the limit of your power supply! Try running this setup at a lower linear output. You don't need the full 100 watts to get out! 60-80 watts is aplenty! You should start at a low output, and slowly increase the output(while keyed up), untill the power supply starts to complain.(buzzer/light). This is what your limit will be. The only other cure, is a MUCH bigger power supply. Unfortunately, I cannot afford a 60-90 amp supply, so this is what I am forced to do to use the one we have. Also,keep your cb's output very low when using the linear amp. These amps are supposed to get a low signal from your radio, or the linear amp is overdriven. (noisy and unstable. Hope this helps you! 73's to you! jimsjinx
Apr 30, 2009 | Pyramid (PS36KX) 600-Watt Power Supply
Electrical schematic needed
For a schematic diagram, contact Pyramid directly.
Jul 24, 2017 | Pyramid PA1000X 1000 Watt PA Amplifier Car...
252 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
