Roland pc 60 color camm
Roland pc 60 is printing in single lines with about a 1cm
gap before the next print line, it is not printing in blocks, i am thinking it is set up all wrong please help
  • Anonymous Sep 17, 2008
    I am having the same problem with mine.... ?
  • Chuck
    Chuck Mar 01, 2014
    I am having trouble with the colors not coming out sharp - they look like a rainbow.
Look on www.rolanddg.co.uk and they might just help. i have just got a pc60 and the test print/cut is'nt working so i'm not a happy bunney. Andy @ YesIDoOwnTheRoad.com
Posted on Dec 19, 2008
Looking For a place to get my PC-60 repaired. This is the third time it's quit. Just plain quit. I'm told I hae to ship it to the east coast for repair. I live in Wisconsin. Any place closer? I've owned it now for about eight years. Have had it in to the shop three times already at two grand a pop. Ouch!
[email protected]
Posted on Nov 13, 2008
SOURCE:
X2250 won't print form pc
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Good Luck!!!!
May 01, 2013 | Lexmark X2250 All-In-One InkJet Printer
Bidirectional printing
check your [email protected] if something stuck in it in the back or under it
Dec 18, 2011 | Office Equipment & Supplies
All four colors wont print roland sp300v
you print head is dry out. Normally, it happened on Magenta and Cyan colors.
Apr 09, 2010 | Office Equipment & Supplies
Can print the color I want. Only prints red.
Aug 24, 2009 | Lexmark X2350 All-In-One InkJet Printer
Can't print in color
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.  2. Select "Clean and Fix Horizontal streaks."  Click on "Print". This will produce a printed page.
1. Please open the "Solution center" again and go to the "Maintenance" Tab.  2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.  3. Get a damp paper towel.  4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.  5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.  6. Next dab the cartridge on the towel to make sure that the ink is flowing.  7. Snap the cartridges back into the printer.  8. On your computer, select "Old Cartridge install."  9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
May 26, 2009 | Lexmark JetPrinter Z11 InkJet Color...
Printer output has shadows, blurring, streaks, lines, poor color
Seem like blocked hole(s) on the color print head...
Most likely if there is a deep clean option then do it (may need a few times to unblock a hole or never).
Also get the printer physically cleaned up if you can see dusts inside (vrtical lines on color bars).
Mar 20, 2009 | HP DeskJet 9800 InkJet Printer
Roland colour camm pc60 printing / cutting contours
Yes, if you have a photo editing program, like googles free Picassa. You can change the text all kinds of ways from the basics to the shadow directions. There are all sorts of fonts and colors, look in your programs, the chances are that you have a photo editing program. Most of them if not all, have the features to allow experimenting. I just did a similar thing on an old document where I scrolled until finding the almost perfect text, and then was able to fade it and change the shape and texture to look like the original text. Good luck
Nov 19, 2008 | Computers & Internet
I have a Roland Camm-1 CX-24 cutting machine that has a parallel connection. I have recently bought a Dell Inspiron 1720 with a Windows Vista OS. I have a USB to Parallel cable to connect the two. I have...
connect the printer and the comp. and boot up....windows should recognize the new device.
did you add the plotter to "add printers" and its driver and to the correct port?
make sure your plotter is on and loaded and function key pressed.
also some cable manufacturers supply a driver...so download one if need be.
what software are you using? is the software cutter driver set to the correct printer and port?
(by default it never is)!!
Aug 03, 2008 | Computers & Internet
HP Color LaserJet 2600n - Thin White Line on Print Out
Which color is this line? Try changing respective cartridge..
Sep 09, 2007 | HP Color LaserJet 2600n Printer
Open Questions:
Computers & Internet Logo
607 people viewed this question
Ekse
Alun Cox
