Question about Baby Gear
REVERSE LIGHTS ALL LIGHTS ON CAR WORK .WHEN CAR IN REVERSE LIGHTS DO NOT WORK .CHANGED FUSE AND BLUB STILL DO NOT WORK
  • Anonymous Mar 27, 2009
    reverse lights wont work, changed bulbs, fuse and switch on transmission
  • 50 Answers
Try the reverse switch in the gearbox or take the plug off and connect the 2 wires togther lights should be on andy
Posted on Mar 31, 2008
Reverse lights not working changed blubs anf fuses
it is more than likely the switch.
On the 5 speed models it is screwed into the left side of the gearbox casing next to the driveshaft inner joint and on 6 speed models it is on top of the casing.
To test the switch, disconnect the wiring connector and use a multi-meter set to resistance function, select reverse gear and test for continuity across the switch terminals. If you dont have & meter you can make up a battery bell or light set.
If your test doesnt get a response from your chosen tester then the switch is faulty, sometimes it is just stuck and a tap on the switch will clear it, however if not sorry, new switch.
I hope this helps.
Jun 19, 2014 | 2005 Renault Laguna 1.8
Headlights donot work
Do you have a ground at the lights?
Jun 19, 2014 | Thule 2003 Chevy S10 Pickup - Crew cab -...
Back up light wont work where is my back up light switch located
M/T on Tranny
A/T on Tranny,
if car is A/T its in the PRNLD switch, mounted to side of tranny.
it not only does reverse but sends your shift selections to the
ECU , so it can autoshift your transmission
the first check is , fuses
2nd ,is try one new bulb inserted, and all old bulbs in pocket
blubs can short.
Oct 14, 2013 | 2007 Honda Civic 1.8
Tail light dont work
could be a dirty socket not allowing good contact for the bulb. or you have a bad connection with one of the wires in the back of the socket.
Apr 22, 2013 | 1992 Toyota Camry V6
I was installing a radio and my dash lights and left turn signal quit working my car is a 1988 cadillac deville
could be the fuses, did you check the fuses or the blubs can be blown, did a wire hit some metal by accident. if so then that is what is wrong. but check fuse first, then blubs
Mar 14, 2010 | Car Audio & Video
Reverse lights not working.have check fuses and blubs
your neutral starting switch on the transmission is also your back up light switch,locate the three wire screw in switch on the radiator side of the transmission and with a test light ,turn the key on and unhook the connector one wire will be hot one wire is the back up lights,using a jumper wire put one end in hot wire and jump one of the other two,one will activate your lights.
Dec 28, 2009 | 2001 Dodge Neon
Reversing lights
Could be the reverse light switch itself, usually mounted on the gearbox with 2 wires coming from it. If you had a multimeter (set to resistance / ohms) you could check that the switch changes from open to closed by disconnecting the plug on those wires and putting the multimeter across the two terminals. The resistance will be very low with the gear lever in reverse, and very high/open circuit with it not in reverse. Also check that there is battery voltage to one of the terminals.
Oct 21, 2008 | Hyundai Motor 1995 Accent
Back up lights
Could be the mechanism inside the shifter that tells the car it's in reverse. Usually a little button of sorts.
Jul 18, 2008 | 1994 Toyota Corolla
Baby Gear Logo
338 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
