Question about Palm Tungsten E2 (Multilingual) Handheld
Unit locks up to reset Screen
My E2 often locks up to the reset screen. When it does it will reset or respond to screen tap or buttons. It will only reset by pluging in and reseting. This makes it useless on the road.
  • tallraka Mar 30, 2009
    Mine locks up goes to blank screen, then have to plug it in, do a reset after some charging; yep making it useless for out of the house.
    Problem Solver:
  • 15 Answers
Try pressing the reset button on the back
Posted on Mar 22, 2009
SOURCE:
I have a tungsten E2 and rep;aced the battery, after charging it overnight and doing a soft reset I am only getting the start up screen asking for password. On the screen are the number pad,...
Still not working, decided to purchase a new one for mine was 3 years old and it was not worth investing a lot of money to fix it.
Thank you for your help............snicksandsam
Oct 15, 2009 | Palm Tungsten E2 Handheld
Fatal Alert Datamgr.c,Line7564 InvalidUniqueIDPassed I get this when I synchronize.
Perhaps you haven't tried performing a more severe reset to break the freeze. You might want to try doing a hard reset. This will erase all data from your hand held so make sure you have everything backed up on your computer so you can sync it again after the hard reset. Note, when I occasionally receive a Fatal Alert error, the Reset on-screen button almost never responds to a tap...I invariably have to depress the reset button in the back of my E2. http://kb.palmone.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=PalmSupportKB,ts=Palm_External2001,case=obj(26419) resets:
http://kb.palmone.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=PalmSupportKB,ts=Palm_External2001,case=obj(887) Depending on a variety of factors including the available memory on your E2 and other installed applications, the problem might or night not be caused directly by the program you were trying out. But once you get the E2 unfrozen, you should refer to this article to troubleshoot the cause of this apparent software conflict:
http://kb.palmone.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=PalmSupportKB,ts=Palm_External2001,Case=obj(27908) Also, I recommend going to the developer of the software you are using, to determine whether there are any compatibility issues at their end, and whether they have an upgrade available.
Here are the directions for the hard reset.
1. Press and hold down the power button.
2. While holding down the power button, use the tip of your stylus (or a similar object without a sharp tip) to gently press and release the reset button inside the hole on the back of your handheld.
3. Wait for the Palm Powered logo to appear and then release the power button.
4. When you see the message that warns you about erasing all your data please continue and then follow the on screen directions.
If this doesn't help then I recommend going to www.palm.com. From there you will need to select PDA's and then the model of yours. It will go to another screen and you should be able to contact palm via free chat. I have had to do this several times and both times I got fast service. Hope this helps.
Aug 24, 2009 | Palm Tungsten E2 Handheld
Touchscreen not responding.
There are three levels of fixes, please try them in order:
1. Reset the GPS using the Reset button, on the back, just under the Antenna Hinge. Resetting will turn off the GPS, and then turn it back on, if connected to power. Test, if fixed, great, otherwise, go to fix 2.
2. Turn the power off, then press and hold the powerbutton for up to 2 minutes. The GPS will turn on, and display a "PreBoot Mode" message. When that message disappears, and the screen calibration screen appears, follow the on-screen instructions, and you are fixed. If you still cannot use the touch screen, repeat fixes 1 and 2 several times, just to be sure., then go to fix 3
3. The touch-screen glass has probably broken or lost its connection with the GPX motherboard. You can order new touch screen glass on the web and install yourself, if you are techy in nature, otherwise do a search for "garmin nuvi 660 repair" and choose your service.
Jun 19, 2009 | Garmin nuvi 250W GPS Receiver
Tungsten E2 has lit screen & not responding
You can take the back off and unplug the battery for a few mins, this sometimes will clear a logic lock
Feb 27, 2009 | Palm Tungsten E2 Handheld
Cant use stylus.
Unscrew the 4 torx screws on the back and remove the cover carefully.
Unplug the battery for 30 seconds. plug it back in and re- assemble the unit. Once it comes back on it will give you the chance to re calibrate the digitizer ( or you can now select it from the prefs menu)
If the touchscreen fails to repsond you will need a new digitizer.
You can purchase it from :
http://www.gethightech.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=PA1634&Category_Code=DIG\
there is also a video on how to take it apart here
http://www.gethightech.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=RD
Feb 17, 2009 | Palm Tungsten E2 Handheld
My screen is lockedI did a hard reset and screen wont respond
ur touch panel is faulty u have to go to service centre , there are 3 things coupled together Lcd screen then touch panel and then front housing for protection of both , u might dropped it , if ur screen is working partially i mean if it responds to taps at some region of screen then it may be a dust inside the housing u have to clean it from inside if u can , otherwise if it completely not responding then it is faulty touch panel , it will cost u around 50 , 60 $
Feb 12, 2009 | HTC Touch P3450 Smartphone
Garmin 360
Have you tried performing a soft reset by pressing the reset button on the back of the unit, then turning it on again?
How about a hard reset?
With the unit powered off, hold your finger on the upper right- hand corner of the touch screen and tap the power key. Continue to hold your finger on the screen until you get a warning message. Tap "OK" to reboot the GPS.
Please let me know if I can be of further assistance to you.
- Jim
Feb 15, 2008 | Garmin nuvi 350 GPS Receiver
My Palm Tungsten E2 does not turn on.
Have you tried doing a soft reset? To do a soft reset, use the tip of the stylus to gently press the reset button inside the hole on the back panel of your handheld.
Jan 09, 2008 | Palm Tungsten E2 Handheld
Touchscreen no longer works
Well watch this video and after you follow the directions get the screen and find the glass like cover and remove it from the screen bend it in a very lightly way, then put it back on and put the PDA back together and BAM.
Nov 07, 2007 | Palm Tungsten E2 (Multilingual) Handheld
Alm one
PDAs that use touch screens have a very thin membrane over the screen itself that responds to pressure. If this membrane becomes damaged, which it sounds like what has happened, then you're more than likely going to need to have it replaced. You can try doing it yourself, but it's WAY up on the difficulty factor because of the complexity of the connection to the circuit board on the Tungsten E2.
To determine if your unit is, in fact, actually damaged, you should first make sure that you've syncronized the unit (which may not be possible if you don't have it set to automatically activate HotSync when the device is attached) then do a "hard reset" to restore it to the factory default. To do this, hold the reset button while simultaneously holding the power button for, at least, three seconds. You will get a message asking you to press up on the control pad to reset to factory defaults. Once the unit is reset, try the screen again... touching even the outer areas to see if there's any response. If it reacts, or beeps at all, then it may be an issue of recalibrating (using the "Digitizer") once it's fully reset. If not, it will need repair/replacement.
Oct 21, 2007 | Palm Tungsten E2 Handheld
Palm Tungsten E2 (Multilingual) Handheld Logo
151 people viewed this question
Top Palm Computers & Internet Experts
Ekse
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
