Question about Panasonic HDC-SD5 Flash Media Camcorder
HDwriter 2.5 My SD5 came with an old release of HDwriter (1.0). Could you send me the link to download the 2.5 release.
  • 5 more comments
  • Anonymous Apr 07, 2008
    Can Panasonic give a download link for new HDC SD-5 customers?
  • ghostsurfer Apr 07, 2008
    Is there a link?
  • longss Apr 27, 2008
    In the end, I had to buy HDWriter 2.5. I had believed that the MPEG soundtrack bug in 2.0 had beeen fixed but I am getting a transcribed MPEG without a soundtrack. Anyone have similar problems or solutions?
  • longss Apr 30, 2008
    Just received a response from the Panasonic Technical Support:
    "Thank you for your response. We recommend converting the file and using a different software program to do any editing, if the HD Writer is not fitting your needs."
    What sort of company is it?
  • Anonymous Oct 30, 2008
  • stefan3 Apr 28, 2009
    I bought a SD5 , and I have the same problem with sound on my editing software... I also cannot install my SD writer software onto my brand new Acer Aspire XP sp3 laptop.
    I would like to know where to download the new version, and also which alternative software one could use.
    Stefan
    email: stefan3 at btopenworld dot com
  • nicandniki May 02, 2009
    We have the same Panosonic video and have the same frustration in getting no sound track when converting to mpegs using HD Writer 2.0E!
This is the link for HD Writer upgrade - You need this to install on Windows XP SP3. Very slow download though
Posted on Dec 21, 2008
Have installed HD Writer AE 1.0 for HDC on laptop running Vista. Works OK. Have tried to install on PC running Win 7 but won't load. Is there a way to upgrade software to run on a Windows 7...
If you have the CD with HD Writer AE, justfollow the steps below:
1. Go to the Administrator account and download the update software from: http://cnc.asp.hi-ho.ne.jp/cnc/global_cs/software/win7/Setup.exe
2. Insert the CD-ROM with the HD Writer AE1.0.
3. Double click the Setup.exe you just downloaded, and follow the procedure.
A free alternative to backup videos from camcorder to hard drive without HDWriter AE on Windows 7: Aunsoft Final Mate.
Jan 03, 2011 | Panasonic HDC-SD20 High Definition...
I have a Panasonic HDC-SD5 camera and it doesn't work on I-Mac. The Mac can't read the files. What should I do to work with it on I movie ? Is there any driver for the mac ?
HDC-SD5 + iMac = perfect compatibility
I have an iMac (early 2011).-I remove the SDHC card from the camera-plug the card directly into the iMac SD slot (Below the CD/DVD slot) -wait 5 seconds till iMovie or Final Cut X download high-quality HD video.
I was digitizing video on a Mac IIx back in the late 1980's, a long, tiresome error-ridden process that only just worked.The tools we have today are brilliant.Anybody wanting to do serious or hobby video on a computer needs one of Steve Jobs' babies.No downloads of drivers, no conversions, no installation.Just plug 'n play.
Hope this helps
Dec 05, 2010 | Panasonic HDC-SD5 Flash Media Camcorder
Pls send the motherboard drivers for mercury pi845glm-p
Open the link provided by Mercury below;
http://www.mercury-pc.com/product-drivers.php?productid=389
Download the drivers you are looking for.
Mike
Jun 19, 2010 | Mercury P4VM800M7 Motherboard
I can find my cd installer how i can fix this
Download the install files from Panasonic here:
http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Camcorders/Hi-Def-Camcorders/Drivers-Downloads/model.HDC-SD5.D
Then run the installer.
***Don't forget to VOTE for the guys who take an interest in helping!
Apr 30, 2010 | Panasonic HDC-SD5 Flash Media Camcorder
Do you have to drop the tank to change the fuel pump on 93 plymouth voyager or is there a way from the top?
Yes the tank must be removed
Fuel Pump: Service and Repair
WARNING: The fuel system is under constant pressure, even when the engine is OFF. Always release fuel pressure before servicing any fuel
system component.
FUEL PUMP REMOVAL
1. Release fuel system pressure.
2. Fuel tank must be removed prior to fuel pump service.
3. Using a hammer and a brass drift, carefully tap the fuel pump lock-ring counter-clockwise to release the fuel pump.
4. Remove the fuel pump and its O-ring from the fuel tank, and discard the old O-ring.
5. Cover tank openings to prevent dirt from entering system.
FUEL GAUGE SENDING UNIT REMOVAL
1. Gently bend the sending unit locking tabs away from the sending unit.
2. Remove the electrical connector cover (red). Remove the sending unit wires from the electrical connector.
3. Use one screwdriver to push on the fuel pump body, and use another to release the sending unit locking tab from the sending unit.
4. Slide the sending unit assembly off of the fuel pump reservoir housing.
5. Pull the wires through the reservoir body and fuel pump cover plate.
FUEL GAUGE SENDING UNIT INSTALLATION
1. Bend the sending unit wires and lay them into the slot on the back of the sending unit.
2. Slide the sending unit into the slots on the fuel pump reservoir body. Slide the wires through the triangle shaped hole in the fuel pump reservoir
body. Check that the tab in the fuel sending unit locks into the detent in the fuel pump reservoir body.
3. Slip the wires onto the tab of the fuel pump reservoir body.
4. Slide the sending unit wire terminals into the electrical connector. Install the terminal locking cover.
5. Slide the fuel sending unit electrical connector into the bottom of the fuel pump electrical connector. Check that the connectors are securely
attached and fully pushed into each other.
FUEL PUMP INSTALLATION
1. Wipe seal area of tank clean, and install a new O-ring seal on pump.
2. Position fuel pump module in tank and secure with the lock-ring.
3. Using a hammer and a brass drift, carefully tap the fuel pump lock-ring clockwise to lock the module in place.
NOTE: Do not overtighten the lock-ring, because the fuel pump seal could split and leak.
4. Install fuel tank assembly.
NOTE: ASD and fuel pump relays remain energized for 7 minutes during the following test, unless the test is stopped or the ignition switch is
turned to the OFF position.
5. Using scan tool, place ignition switch in "RUN" position and use Actuate Output Test "Auto Shutdown (ASD) Relay", to activate fuel pump and
pressurize system.
6. Check for leaks.
Sep 10, 2009 | 1993 Plymouth Voyager
HD writer will not write to disc
I just used HDWriter today to copy a film I took from a new Panasonic HDC-HS250K to DVD. It took about 30 minutes to complete, and the movie was only 1 Gb; about 5-10 minutes of HD. I used a Memorex DVD+R that I happen to have from a couple years ago. The video looks very good played back on my PC or HD TV using a regular DVD player (not blue ray). I don't happen to have any other DVD except for the 2 sided which I hate to use for the short videos. So in looking to buy some more I'm concerned that DVD-R might not work so well. I've read some conflicting reviews about that. Anyway just wanted to let you know that the DVD+R worked fine.
Jul 06, 2009 | Panasonic HDC-SD5 Flash Media Camcorder
Problem with the image. panasonic hdc-sd5.
AV out must be composite connection not S-video
May 19, 2009 | Panasonic HDC-SD5 Flash Media Camcorder
Baattery For Panasonic camcorder
The number is VW-VBG130 Li-ion 7,2V 1320mAh
Perhaps to order by mail.
Regards,
Wim in Holland
Dec 18, 2008 | Panasonic HDC-SD5 Flash Media Camcorder
Problems downloading onto Macintosh
Can you not remove the memory card from the camera and read the data on a cheap USB card reader? You don't need any special software to do this.
good luck.
Apr 18, 2008 | Panasonic HDC-SD5 Flash Media Camcorder
Panasonic HDC-SD5 Flash Media Camcorder Logo
2,101 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
