Question about Kodak EasyShare C340 Digital Camera
Down load Error message saying device is busy or not plugged in, everything is connected properly... also error when starting easyshare and program shuts down. I have removed and reinstalled program but still having same issue.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kodak Master
  • 102,366 Answers
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Posted on Oct 26, 2012
SOURCE: e-mail pictures using Kodak EasyShare software
when I send a picture, the envelope shows sending but it never goes thru to the recipient.
Posted on Apr 15, 2009
  • 68 Answers
SOURCE: Lens error 10e,1,10- Kodak EasyShare M753
this is an hardware error. I'm sorry but you can't fix it by yourself. You've to contact kodak for a repair.
Posted on Oct 16, 2009
  • 32 Answers
SOURCE: USB DEVICE NOT RECOGNIZED KODAK EASYSHARE C913
remove you memory card
turn camera ON > Press Menu > go to setup menu> format internal memory>
take 1-2 picture > reconnect your camera to the computer>
if the camera will be recognized> reinsert the MMC> format the MMC > it will delete all your pictures including the corrupted ones
most of the time its just a MMC issue
good luck
Posted on Oct 28, 2009
SOURCE: My kodak easyshare c813 says lens error 111,0,0,24
I have the same problem except mine is 221,1,0,0
Posted on Jan 13, 2010
SOURCE: Kodak Easyshare Software has stopped working
I was getting the message "Kodak easyshare software has stopped working" and couldn't find any forum with an answer. I called customer support and they were able to help me. I was running Vista 64 bit. And apparently the default installation installs in under the "c:\Program Files (x86)\" folder instead of the "c:\Program Files\" folder. They had me uninstall the software then create the folder "Kodak" under "c:\Program Files\". They also had me delete the "Kodak" folder under "c:\Program Files (x86)\" which I had trouble doing. I ended up having to go down in that directory and delete some of the files individually. In the end they said it was okay to leave a few files there. I then reinstalled the software - using custom settings and selected the "c:\Program Files\Kodak\" folder to install. After restarting it worked. This is a pretty simply error in the software that the programmers should have fixed. Fortunately the help people were helpful!
Posted on Mar 02, 2011
Error connecting to server
Error messages can mean several things. You may have lost internet connection for a short period or your tablet may be having problems with downloading. This is a common problem that happens to devices if they aren't working properly with internet or you could have interferance. Try down loading later at night, late late and see if it just happens to work.
Feb 28, 2014 | Android 4.0 Tablet PC
While pluggin USB it shows an error that device not installed properly
Feb 17, 2013 | Kodak EasyShare C180 Digital Camera
CODE 10 ON TSST l632@ VISTA os
This is from Microsoft and is from their code explanation page.
Code 10 loadTOCNode(2, 'moreinformation'); If the device has a "FailReasonString" value in its hardware key, that string is displayed as the error message. The driver or enumerator places this registry string value there. If there is no "FailReasonString" in the hardware key, the following generic error message is displayed:
This device is either not present, not working properly, or does not have all the drivers installed. (Code 10)
Try upgrading the device drivers for this device.
Solution button: Update Driver
To resolve this error code, make sure the device is connected to the computer correctly. For example, make sure all cables are plugged in fully and that all adapter cards are properly seated. Follow the suggested solution button and update the device driver. It may be possible to remove the device and redetect it using the Add New Hardware wizard.
Jan 15, 2010 | HP Pavilion DV6700T Notebook
Everytime i set up my router it says "your ethernet cable does not appear to be connected properly. Error 321: Ethernet Cable not connected" now i have tried setting this up multiple times but i keep...
there is a program on your computer that shouldnt be there thats preventing it from working..go to start then control panel then clink on maintenance+system then click on device manager and any program in the list in yellow triangles you uninstall.
Jan 04, 2010 | Linksys WRT120N Router
Data saving error
I came to the point where I had done everything, restarted, closed the program in the task manager nothing would work. Every time I would hit any key even the X to close the program I would get the error. data saving error enitity exception. So finally I shut down the computer, disconnected the battery, waited about ten minutes started back up and so far it has worked without problems. Ever since My Deluxe Invoices made their last up grade I personally have had lots of issues with the update. Wish I could go back to one of the very first versions but with the ability to email statements. Thats the only upgrade I have found useful.
Dec 27, 2009 | Avanquest My Invoices And Estimates Deluxe...
I have the Kodak 5300 All in one easy share printer. Less than a yr old. Also a Del computer with Vista Operating system, Less than a yr old. About a week ago decided to take the time to learn the kodak...
try using the system restore option on Dell computer.........as you have vista,,,click on the start button and type system restore in start search box and follow the on screen instructions and select yesterday's date and proceed.......should help:)
Apr 16, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
"Device is in use by another program" error message
Consider NOT connecting your camera to your computer.
Mar 03, 2009 | Canon PowerShot SD600 Digital Camera
Loading photos to computer: error message says device is busy or not connected
I wish I could tell you what I did. ALl I did was unplug the cable several times from the computer and the camera. I used a duster to blow out any dust particles in the connection areas. I turned the computer and the camera on and off several times. It finally worked.
Sep 27, 2008 | Nikon COOLPIX L12 Digital Camera
Cannot transfer photos from c340 camera
Make sure that the camera has sufficient power when connecting and aslo try connecting the cam w/out the sdcard
Feb 15, 2008 | Kodak EasyShare C340 Digital Camera
Kodak EasyShare C340 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
