FixYa.com
Tags:
Gateway FPD1975W  19 inch LCD Monitor
Monitor
posted by msuclassof92 on Mar 31, 2008
I have had this problem occur once before to a monitor and I was able to solve it. This time it is a different monitor and my solution is not working.
My monitor is now operating sideways (with the Windows start button in the upper left hand corner and all of my icons at the top going from right to left). I tried to use the front panel buttons to flip it back but all it did is make the situation worse. Is there a way in Windows to get it back?
Thanks
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Apr 10, 2008
Not Rated (0)
scott201201
Rank:Wiz Wiz
Rating: 83%, 35 votes
The Ctrl-Alt-Direction key sequence is supposed to be used for changing your workspace. On my computer at work it changes the screen orientation.
Ctrl-Alt-Up - right side up
Ctrl-Alt-Right - 90 degrees
Ctrl-Alt-Down - 180 degrees
Ctrl-Alt-Left - 270 degrees
(If that doesn’t work, try Ctrl-Shift-R)
This is a feature in Windows XP Tablet PC Edition. Which makes sense. But it looks like ATI Intel copied the keystroke for the same “feature” in their video card drivers. I can’t think of a good reason why I would need an always-on keystroke for this on a desktop PC.
When creating a keystroke-mapped feature that only 1% of your customers will want to use and the other 99%[1] are going to be confused by, put in a menu option to disable it and have it disabled by default.
To fix the issue press Ctrl-Alt-Up. To permanently fix the problem go to:
Start >> Control Panel >> Display >> Settings >> Advanced
Where it is after that it dependent upon your video card.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Monitors problems?
Gateway FPD1975W (Black) 19 inch LCD Monitor
power light flashes but monitor...
i have a fpd1975w hood up to a... Answer This...
monitor issues
My screen keeps going into like... Answer This...
MONITORS
hello, i am looking for... Answer This...
mail delivery
my email has been held up from... Answer This...
Monitor will not stay on
My monitor will not turn on.... Answer This...
Repair Service
Find Monitor Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
