Question about HP Pavilion F1523 15" LCD Monitor
MONITOR OR IS IT COMPUTER
My Monitor as soon as I turn it on goes to sleep. No Input also
  • 472 Answers
Check your video card is seated correctly in the computer.
Disconnect the power and video cable first.
Open the side panel, lift the card up and push it back into the slot with a gentle side to side wiggle as you go.
Also if possible try another video card.
Another thing is to check is if your computer has onboard video. It will be a blue socket on the motherboard at the rear panel where your USB ports etc are.
Posted on Apr 09, 2008
Monitor won't wake from sleep!!!!!!!
Sounds like you may have a bad connector. Make sure it fits snugly in the pc and the back of the monitor. If you still get no input try a different connector
Mar 31, 2017 | ViewSonic Computers & Internet
Monitor goes to sleep immediately after turning on the computer. How can I fix that?
go to start,then pc settings,then monitor or power options the to power and sleep and change on plug to 4 hours and on battery to 10 minutes
Jun 11, 2015 | Computers & Internet
Goes to sleep as soon as I turn it on
Hello, If is goes to sleep when you turn on , it has a power supply problem.
Jun 03, 2014 | LG L1530S 15" LCD Monitor
NO DVI INPUT SIGNAL AND MONITOR GOES TO SLEEP
you can't run 2 different inputs at the same time. VGA takes prescedence.
Apr 06, 2014 | HP L1950 Monitor
As soon as i turn on my computer my monitor says no input signal and then goes to sleep i have an hp
either your video card has stopped working or your cable to your monitor or the monitor is bad. Try to hook another monitor up to it see if it turns off if it doesn't then the video card needs to be replaced. If it does its the monitor.
Mar 07, 2010 | HP Pavilion a305w (DM181AR) PC Desktop
How do i turn off the sleep mode
On the majority of monitors the monitor goes into sleep mode when there is no input, but to turn off monitors altogether, on most monitors you press the power button to turn off the monitor altogether.
Feb 04, 2010 | HP Computers & Internet
No DVi input, then computer goes to sleep
Hi publicworker,
I had a similar problem whereas my monitor went to sleep mode after a few minutes. I'm running an HP LP 2065 in dual mode with another HP flat screen. However, I did resolve the issue after resetting the output settings.
How to do that:
  • right mouse click on the desktop
  • select graphic options
  • output to
  • extended desktop
Maybe some changings/modification will help you too.
Stefan
Jan 31, 2009 | HP 2025 20.1" Flat Panel LCD Monitor
I have a new HP pavilion slimline with Vista......a 19 inch flatscreen monitor......I went nuts with it not connecting and saying no DVI input......
I tried something and so far it has worked 10 times in a row...
start out with puter and monitor off.......turn on monitor.......let it go to sleep....then turn on puter....
I have the puter that has the start button on top of it.....not too crazy about it.....
hope this works for you.........Judy in NY
Dec 07, 2008 | HP 22" Widescreen Flat Panel TFT LCD HD...
My hp w2207h goes to sleep
Turn off the "powersaver" feature on your monitor by pressing <menu> then <management>then <powersaver> select off.
Nov 20, 2008 | HP f2105 21" LCD Monitor
Going to sleep
(if you have an orange light) Turn off your computer and unplug all of your devices, printer, scanner etc... Only your monitor, mouse, keybord and monitor should be connected. Now turn on your computer. It should work now. You can attach your other devices if you are successful.
Nov 15, 2007 | HP Pavilion F1523 15" LCD Monitor
HP Pavilion F1523 15" LCD Monitor Logo
64 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
