Question about Sony PlayStation 2 (PS2) Console
Cd drive my drive will not open to allow me to put in the game disc. Can that be fixed?
  • 32 Answers
Yes, but you would have to take it to a computer shop. Or you could try giving it a whack, might just be jammed-try at your own risk!
Posted on Mar 31, 2008
SOURCE:
Once you put in a game it gos back to open tray
I'm no expert but it Looks like you got error code E79 it's when your xbox refuse to read the disc well I guess I'll give more detail it's a small circular sensor in the disc tray that allows the games info to the internal hard drive. In your case that little sensor is slight off it's brackets or it is no longer working, try sending it to microsoft if you warranty is still valid . There's also another option " YouTube " type in the adress bar " open disc tray problem fix" ok so I hope this gave you an idea of what's going on. Steph the not so expert guy.
Feb 04, 2010 | Microsoft Xbox 360 Console
Grandson put a ds game into the Wi where the disc
Does this unit have a tiny hole, similar to those found on CD or DVD drives, which allows the insertion of a large paper clip?
By pushing a straightened out paper clip into this hole, you can push with a certain amount of force, which will then allow the drive to open, and from there, you might be able to remove the disk from the ds game.
Good Luck,
-a.
Jan 06, 2010 | Nintendo Wii Console
Got call of duty mw2 opened it put it in elite xbox 360 was fine has started to say (disc is unreadable) and to clean the disc i have only touch disc one time to put it in
Yes this is actually the receptors on the back of the disc drive you will need to get this fixed. You can do this yourself or you can send it in.
Dec 19, 2009 | Microsoft Xbox 360 Console
When i put a game into my xbox360 it reads unplayable disc.
Try blowing in the cd drive to get any dust off of the laser that could be one of the causes if it doesn't work then send it into microsoft if warranty is good if not then you try poping open the 360 yourself and try look at the disc drive but more than likely if it doesn't read anything thing then your better off at getting a new disc drive, that includes if it doesn't read dvds. let me know if cant fix it and you don't want to buy a new cd drive.
Jul 01, 2009 | Microsoft Xbox 360 Console
My xbox 360 doesn't play my games
the lens of the disc drive needs a check up...
May 29, 2009 | Microsoft Xbox 360 Console
New XBox 360 putting scratch in games
the problem is the disc drive.
you have to open it up and put some stick foam " like a sticky strip of foam, insulator : on top of the drive .
the problem is that the disc touches the laser assembly while turning cheating a ring on the disc.
i can fix your games as well as the disc drive if you feel like is to complicated.
Jan 02, 2009 | Microsoft Xbox 360 Console
Xbox 360 will not read games or dvd's
Try to insert a straighten paper pin into the hole under the tray if still no go You have to open the cover and take the cd out.
Sep 01, 2008 | Microsoft Xbox 360 Console
Disk wont spin?
If its still under warranty, and the seal hasn't been cracked, contact Microsoft.
Try what hijackthis1 suggested, if that doesn't fix it, try this.
Since you have the 360 apart, and the top cover off of the dvd drive, here we go...
There's a circular cut-out that's glued to the top cover that you removed from the dvd drive, right below the sticker with all of the drive information. I was able to pop out the cut-out. After that you now have (3) pieces in your hand, the cover, cut-out, and a plastic piece.
Connected the dvd drive back in the 360 with the top cover off.
Put a game or movie in the drive, don't hit the eject botton, just put the disc in the tray.
Now with the disc in the tray, put the plastic piece in the center of the disc. Its magnetic, so it should kind of lock in to place.
Connect the power/av cords in the 360 and turn her on.
You should see the disc try to spin. (It may spin once or a couple times around, but it will stop). When you see the disc start to spin, GENTLE, spin/turn the disc in the direction in wants to go. It should load the game or dvd with no problems.
Reassemble the cover and put back on the dvd drive.
Now use the eject botton, and try games and dvds.
If disc fails to spin, do process over again.
I've done this with one of my 360's with no problems.
The drive I used was an Hitachi 0059DJ.
Dec 24, 2007 | Microsoft Xbox 360 Console
Unplayable disc
Open up the console and open up the CD Drive. Clean the lens of the CD Drive with some rubbing alcohol and a q-tip. Then put the console back together.
Xbox 360 problems
If its still under warranty, and the seal hasn't been cracked, contact Microsoft1.gif.
Since you have the 360 apart, and the top cover off of the dvd4.gif drive, here we go...
Now use the eject botton, and try games and dvds4.gif.
Sony PlayStation 2 (PS2) Console Logo
14 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
