Canon NP 6551 Black and White Copier Logo
Posted on May 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am having a 6551 canon copier and I am getting the problem in the duplex. When I am taking copy in overlay mode. the over lay mode first copy is coming and when the paper is in duplex. the second copy is not coming it is moving slightly and jaming the paper
Anonymous
Level 2:
  • Expert 149 Answers
  • Posted on Jun 09, 2010
Anonymous
Expert
Level 2:
Answers
149
Questions
0
Helped
53923
Points
373
Sounds like the registration rollers and the duplex rollers need to be replaced. they have finnally gotten worn out to the point that single sided copies are fine but the paper slips during the duplexing and offsets the copies
Np 6551 error code E015
E015 •Clock pulses of the pick-up/duplexing/developing motor fails to be generated or be detected.
•Excess current of the pick-up/duplexing/developing motor is detected.
http://tokomesinfotocopy.blogspot.com.au/2011/04/code-error-canon-fotocopy.html
I do not have a solution for that. A Canon printer tech would know what to do to fix it. But you have to weigh the cost of a fix with the cost of the printer.
2helpful
E020 pada mesin foto copy NP6550
Mesin foto copi canon np 6551 scan atas waktu ngopi berhenti di tengah tidak ada intruksi lain, sudah di cek motor scaner bagus, sensor bagus ?????????
I have a copy machine the model is canon np 6551 and on the screen there is a message E005 switch the power on and off again what should I do?
it is code for cleaning web. the fuser cleaning web may have tqken up completely if so, replace it. else check sensors which detect taken up cleaning web.
Canon 6551 copier-rollers are grabbing causing smear on the copy
check the paper path you need to control the main drive mecanism, and all bushing roller : registration roller, pickup, fixing and exit: you can see exemple of the bushing to check: mabroukmedal_41.jpg
the roller that you need to check and replace the bushing:
Read out says remove the jammed paper from the duplexing unit. where is the duplexing unit?
the duplexing unit is under the fixing feeder frame unit..... have only worked on one NP before and it was much like the IR5000 all you need to do is pull out the tray under the fixing frame assemble
Digital replacement for Canon NP 6025
"No" is the answer to all of those questions, and even if it were "yes", purchasing a good quality refurbished digital machine from a reputable supplier, would still be a far cheaper option than all of that.
Not in or around Toronto, are you?
4helpful
Error message - re insert unit 1
GO ON LINE AND TYPE THE FOLLOWING:
CANON NP 6551 B/W RE INSERT UNIT 1
ENTER
WHAT IS CANON NP6551 B/W UNIT 1
ENTER
CANON NP 6551 B/W SERVICE MANUAL
ENTER
ROD
Canon imageCLASS MF6530; can't set up duplex (2sided) printing
hi there
there are 2 ways to copy 2 sided
one is full duplex which means your copier must have a duplex attatchment fitted on the copier lid
the other if it hasn't got a duplexer is to copy in 1 to 2 mode which means you have to turn the copy over. it sounds like your machine has not got a duplexer fitted but it can still do double sided using 1 to 2.
hope this helps
beergut707
old marine
old marine
ZJ Limited
ZJ Limited
