Question about Dell Inspiron B130 Notebook
Computer not recognizing the CD/DVD ROM drive upon initial boot
When I first boot up the computer, a message will come up saying the a device in the modular service bay cannot be identified (DVD ROM drive). I try restarting the computer to see if it'll recognize it the second time, but to no avail. When putting a CD or DVD in the drive once the computer is up and running, it won't read it. Is there anything I can try or do I need to buy a new DVD drive?
  • 1 more comment
  • Jotman2006 Mar 31, 2009
    Device in the Modula bay not identified
  • sdornick Apr 10, 2009
    Dell Inspiron B130 not reading or writing to CD ROM drive. Suggestion was to check bios ... F2 gets me to the bios, but what am I looking for when I get there?
  • valerie gordon Apr 20, 2009
    I have the exact problem- the error message upon booting and the computer not playing the anything in the CD-DVD drive.
    Genius:
  • 1,913 Answers
No
check your bios setup
and detect your rom
Posted on Mar 31, 2008
How do I unlock the Bios on an Acer ES-1 111M Laptop
To boot from a CD, DVD or USB device, make sure that the device has boot sequence priority over the hard drive.
BIOS Boot
BIOS (Basic Input Output Subsystem) is a programmable chip that controls how information is passed to various devices in the computer system. A typical method to access the BIOS settings screen is to press ESC, F1, F2, F8 or F10 during the boot sequence.
BIOS settings allow you to run a boot sequence from a floppy drive, a hard drive, a CD-ROM drive or an external device. You may configure the order that your computer searches these physical devices for the boot sequence.
The first device in the order list has the first boot priority. For example, to boot from a CD-ROM drive instead of a hard drive, place the CD-ROM drive ahead of the hard drive in priority.
Before you set boot priority for a USB device, plug the device into a USB port.
To specify the boot sequence:
  1. Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. Depending on the BIOS manufacturer, a menu may appear.
  2. Choose to enter BIOS setup. The BIOS setup utility page appears.
  3. Use the arrow keys to select the BOOT tab. System devices appear in order of priority.
  4. To give a CD or DVD drive boot sequence priority over the hard drive, move it to the first position in the list.
  5. To give a USB device boot sequence priority over the hard drive, do the following:
    • Move the hard drive device to the top of the boot sequence list.
    • Expand the hard drive device to display all hard drives.
    • Move the USB device to the top of the list of hard drives.
  6. Save and exit the BIOS setup utility.
  7. The computer will restart with the changed settings.
Boot Priority Options
Some computer manufacturers allow you to select the device that contains the boot sequence from a special device selection menu. The example below uses a Dell system board.
To set boot priority using a device selection menu:
  1. When the computer starts to boot up, after the manufacturer's ID screen, press F12 several times. The device selection menu appears.
  2. Use the up and down arrows to select CD-ROM or
May 04, 2015 | Acer Aspire Computers & Internet
Hello, My laptop shows the following message when I turn it on- Realtek PCIe FE Family controller Series v1.19(08/10/09) PXE-EGI-Media test failure,check cable PXE-MOF-Exiting PXE ROM Reboot an
It can't locate a working boot disc. Most likely lost communications with hard drive. Look in BIOS again to see it recognizes the drive. If not try re-seating / reconnecting drive.
Feb 16, 2013 | Dell Inspiron N5010 Black
How can I get my computer to recognize my CD-ROM drive?
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
hope this helps you
Nov 12, 2011 | LG CRN 8245B (CRN-8245B) Internal 24x...
Computer does not recognize CD/DVD disks in drive. My Windows XP PC has suddenly stopped recognizing disks in my CD/DVD drive. Device Manager shows that both of the listed drives (TST Corp. DVD +RW...
Most likely a problem with the reader on the CD/DVD Drive.
Very easy to swap out a different CD/DVD Drive. Add the new device and see if that resolves the issue.
May 02, 2017 | Computers & Internet
Ntldr is missing at startup
To fix your problem please follow the below steps.
1. Locate your Windows XP/2000 installation disc and place it in your CD/DVD ROM drive. If you don't have this disk, then you cannot proceed further.
2. Restart your computer.
3. When the computer restarts press any key on your keyboard when you are prompted, "Press any key to enter setup." Most computers are configured to boot to another device other than a hard drive. Since the Windows XP/2000 installation disk is bootable, you should see the prompt. However, if you don't see the prompt you may need to change your boot priority in your BIOS. To do so, enter the system BIOS by following the onscreen instructions upon startup. Then navigate to the Boot Priority menu and modify another device, such as a CD-ROM to boot prior to the hard drive. Then reboot your computer.
4. After you have pressed any key, the Windows XP/2000 setup screen will appear. After loading, press the "R" key to repair the Windows installation. The screen will appear black. The computer requests which installation you would like to log in. Generally speaking, press "1" and "Enter." If you have more than one hard drive or more than one partition, the procedure may be different. You must know which hard drive or partition your Windows operating system is installed in. You are subsequently prompted for a password. If you haven't set up one up, you can just leave the query blank and press "Enter." The phrase "c:\WINDOWS>" and a blinking cursor subsequently appear.
5. Type "copy d:\i386\ntldr c:\windows" (without quotes), where "D" is the letter of your CD/DVD ROM drive (your optical drive may be different, especially if you have more than one). Eject the CD from the drive and type "Exit" (without quotes) to restart your computer. The NTLDR file will be copied from the installation disc to your hard drive.
Thanks for contacting Fixya. Have a good day.
Aug 10, 2011 | Dell Dimension 4600 PC Desktop
I have a dell dimension 3000 desktop. I removed a cd rom drive and replaced it with a audigy sound blaster front panel drive. when I boot my PC it says primary drive not found, press F1 to continue, Press...
Your computer is configured to recognize specific devices in your computer. If you removed the CDROM drive, you need to tell your computer that it's gone, and that you're aware of it. That message is kind of like a "Hey, there's something missing from your computer... did you know about this?"
You should boot your computer up and get into the BIOS. When your computer turns on, you'll see a message in the corner that says something like "Press F2 for BIOS" or something like that. Get into the BIOS menu using this option. When you get into the BIOS, you'll need to find the sub-menu called "IDE Devices" or something referring to IDE drives. You should see two IDE channels, with two possible devices per channel. You should see the entry where your CDROM drive used to be - change this option to "Disabled" and then save your settings and reboot the computer. The message should go away. Good luck!
Mar 08, 2010 | Dell Dimension 3000 PC Desktop
Hi: My computer is not recognizing my ts-h492a
Please go here and download the live update from Samsung. This software is designed to automatically update you to the latest firmware via the internet. To get this service, customers have to install the Firmware LiveUpdate program on their computers.
Please download the live update full version if you have not used this software before. See link.
http://www.samsungodd.com/Eng/Firmware/liveupdate.asp
Simply follow the instructions as given and your software will be updated to the latest version required to run your CD/DVD writer with your computer.
Hope this helps. If so please do leave a vote for the solution. Thanks.
Mar 01, 2010 | Samsung TS-H492A/RSWN CD-RW/DVD-ROM...
My pc won't boot from cd-rom... Bios recognizes both cd-rom drive and hdd, and boot sequence is set to boot from cd-rom but when it comes to boot from the windows XP install dvd it shows the message...
you are saying two differnt things here.. CDROM and DVD if its a dvd in a CD ROM it will not boot a windows disk if somehow this is written to a DVD Is it original?
Secondly is the Cd ( or DVD drive) actaully working. Being listed in CMOS does not guarantee that.
I know you have listed the drive as DVD but do you have 1 or two drives installed and not have the disk in the recognised drive.; have to eliminatge all possibilities of werror in interpretation here.
So assuming everything appears as it should, then the medial in the drive has to be considered at fault .. dirty disk.. drive needs iris clean, not an original disk, damaged disk, not a boot disk.. just a windows cvopy.;
Nov 23, 2009 | Intel D865GBF Motherboard
CD ROM drive not seen in "device manager"
i think you are going to have to boot into bios and where it shows the boot configuration look to see if there is a cdrom there if not change it so the computer will have the cd rom in there along with the harddrive and the a drive then save it and exit and reboot then the cd rom should be back into the device manager and also under my computer
Aug 17, 2008 | Samsung TS-H492 (TSH492AWRBH)...
Non-system disk or disk error
Is you cd-rom drive shot - are you trying to boot up your computer through an xp or windows cd? If it is, it's not going to recognize and boot up. You'd be best getting a new drive - look around for someone with a Compaq Evo 800cp. They have the same exact cd-rom drive. Here are your compatible cd-rom devices:
TEAC DW-224E-A
or a Compaq DVD-ROM DRN-8080B
otherwise try a HP SD-C2612. I have these three drives. They all work really well.
Jul 01, 2008 | Compaq Armada E500 Notebook
Dell Inspiron B130 Notebook Logo
314 people viewed this question
Alun Cox
