Question about Mintek DTV-263 26 in. LCD Television
Mintex tv/dvd combo
Cannot change from DVD mode to TV. Does not respond to remote or manual
6ya staff
SOURCE:
Anonymous
  • 52 Answers
SOURCE: Lost remote for Mintek TV-DVD combo
hey, had the same problem.
found one on ebay for $20 shipped.
also heard that the "Kameleon" Universal remote, from radioshack, will work with it.
The remote is the RC-600 (atleast for my DTV-265), and here's where I got it on ebay:
http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&rd=1&item=360029014984&ssPageName=STRK:MEWN:IT&ih=023
Posted on Mar 11, 2008
salsaurbana
Luis Rondon
  • 56 Answers
SOURCE: mintex 37 inch wide screen. remote is working however cannot change channel, input source or volum. only turns tv off. The buttone on tv doesnot work connot change input source or volume
Check if the remote is in TV position, that is, because most of the remote controllers have the feature that you can program them for use with another devices. Make shure that one button that says "TV" in pressed and released once before you try to change any function on the TV.
Posted on Nov 20, 2008
Anonymous
SOURCE: Will not change from dvd to tv mode
i had the same problem if fixed it rather simply buy using a base ball bat
Posted on May 07, 2009
Anonymous
  • 814 Answers
SOURCE: mintek -dtv-265-d stuck in DVD mode
These units have had a failure in either logic board or the main board. The only way to repair these units is to get replacement boards and see if this repairs the problem. You can try to source these parts at e-bay. Use the search engine, plug in the make of you television model number, and part number of the board you think you need for the repair.The search engine will bring up all available parts for you.You can also try this website for parts. http://www.discount-merchant.com/SearchResults.asp?Cat=&Search=PCB&RefineBy_Manufacturer=MINTEK I hope this information is of some help to you with your problem.
Posted on May 29, 2009
Jim Krause
  • 1779 Answers
SOURCE: Mintek DVD LCD combo
There's nothing you can do. The DVD unit and the TV are both controlled by IC2 bus lines that work together. You will have to have the unit repaired or invest in another set. My recommendation is " Never buy a TV with a built in DVD player". They do not last. That is from a professional stand point.
Posted on Sep 09, 2009
I want to use my cable remote to operate my Apex TV/DVD combo but it will only turn the unit on and off by using a DVD code. Problem is that in DVD mode, my Cable remote will not change channels or c
you must read carefully your owner manual, and proceed with the instruction for to see if this possible. If you do not have the instr. manual go to www.fitness.manualsonline.com and download free.
God bless you
Aug 30, 2012 | Televison & Video
Sponge bob DVD player will work on a regular TV but will not show up on the sponge bob tv anymore. Also tried a different DVD player and only get a blue screen. Shows AV then AV then tv or something. It is...
Hello
Your Emerson Sponge Bob's model will be SB350. It is a TV/DVD combo, with two AV inputs too. You ahve to see only DVD player with it as you says. You can change its mode to eiter TV/AV or DVD/TV by its remote control buttons. Press the DVD/TV mode button on the remote control to chage the modes to TV or DVD. On DVD mode, you can play DVDs with it. I thinks that you have its user manual with you now. Go to its pate [23] where there is illustrations for which button on the remote control handset should be pressed to select this. If you haven't its user manual with you, send your email address to me by FixYa comment box. I'll send a copy you the user manual to you by return mail. OK.
Jun 27, 2011 | Emerson SpongeBob SquarePants TV
Need the remote code to my Samsung TV. My model is: TVN5054CA
Hello
Three digit universal remote code for Samsung Tv are:
002 012 102 103 112 212 502 512 818 914
Four digit remote code for Samsung TV/VCR/DVD combo is
0942
DVD/VCR cobo are:-
0455 0963
TV/DVD combo is
0942
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
OK.
Dec 28, 2010 | Samsung CXD1342 13 in. Combo
Unable to switch on DVD function on a Bush 14" combo
Switch on t/v press TV / DVD button on remote to ensure it is in TV mode. Select DVD by pressing
AV button once or by using input select menu
Press TV /DVD button until DVD RC appears on top left (The remote is now set to DVD mode)
Insert disc ensuring label is to rear of set and Auto play function will start
Oct 10, 2008 | Bush DVD142RC 14 in. TV/DVD Combo
CODE FOR DIRECTV REMOTE
I am a installer for Directv and tv's that incorporate a dvd and/or vcr usually do not respond to the directv remote. Trust me I tried all the codes. I did find programming the av1 on the dtv remote for the dvd player would control the volume and on/off for the tv. Try the dvd codes rather than the tv codes. If no luck I recommend a Harmony remote which works well with combo tvs. Although expensive they are you must consider the convenience factor they provide.
Aug 27, 2008 | Toshiba 14DLV75 14 in. TV/DVD Combo
Won't turn on
The Horizontal Output is most likely shorted according to high q technoligies
Apr 22, 2008 | RCA 20F510TD 20 in. TV/DVD Combo
TV dont respond
Hello psp007,
I hate to be the one who tells you this, but you have one of those TV sets that are controlled by a single processor (as most combos have even LCD combos) and that processor may have gone bad. This is why you have so many problems at one time. I would suspect the the main processor board has a problem. You may want to take this to a TV repair shop, because there is so little you can do for this problem since if it is the main processor you will need equipment to troubleshoot this problem and to remove and install the component with the problem. Taking it to a shop is your best bet.
I hope this helps,
Thank you,
Shuttle83.
Mar 03, 2008 | Televison & Video
TV dont respond
Here is the fix for that problem. I tried it and it works as I had the same problem. I used the COMPOSITE cable to make the splice rather than the COMPONENT cable since it is lighter and easier to work with and solder.
http://www.fixya.com/support/t300197-tv_w_built_in_dvd
Jan 19, 2008 | Mintek DTV-263 26 in. TV/DVD Combo
Sharp VT-51DV30 ....combo tv/vcr/dvd
unplug the unit and plug it back in see if it resets
Dec 02, 2007 | Sharp VT-G21 21 in. TV/VCR Combo
Mintek DTV-263 26 in. LCD Television Logo
136 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Ekse
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
