Take power head apart
After removing the seven screws, there is still something holding it together. I need to do what or how to take it apart. It will always shred on the left but not on the right side (power switch side) the reason why I am going inside is because something is loose or broke off. Could this be reason why it is not shredding properly? Do you know what could be broke off inside?
There's another screw under the sticker. If only one side rotates, it's probably due to a stripped gear. That's what I just discovered on mine...now anybody have any idea where to get a replacement?
Posted on Apr 04, 2008
How to put motor and blade sections back together?
There are two phillip head screws holding the blender end together where it came apart. They are hidden under plugs on either side of the imprinted information. Simply drill a hole in each plug and remove them by putting something in the hole (small screwdriver) and pulling them out. Loosen the screws, enough to pull the body apart far enough to insert the blender end back in. Tighten the screws back up and your good to go. I left the plugs out, they don,t serve any purpose.
May 16, 2013 | Cuisinart CSB-33 Quick Prep Handheld...
Tristar vacuum has wiring pulled loose inside and I cannot figure out how to open the vacuum. It is a 1997 model. It appears that the rubber seal is holding the two halves together.
I have the same problem with my older '80s Tristar.
This may work for your model, give it a try.
On mine, there are 3 phillips head screws holding the two halves of the cleaner together, and the rubber bumper.
You have to remove the screws first. Your model may have more or less screws.
On mine, there are two screws near the front wheels, down deep. I had problems taking them out, but not to worry, once they are loose, they are no longer holding the other half, don't worry about taking them fully out.
Also, at the rear, there is a small black plastic clip that has a screw in it. You'll need to remove that too. Once all the screws are removed, use a medium sized flat head screwdriver to go behind the rubber seal -- you're looking to get the screwdriver to where you can see or feel the edge of the canister. Simply twist the screwdriver a bit and the canister should feel like it's coming apart. Mess around with that for a bit, and the parts should come apart easily.
May 02, 2011 | Tristar Vacuums
How dose the case come apart
usually with LCD monitors there aren't many screws holding them together, instead they are held together with plastic tabs. You need to remove any screws holding it together (if any) and you need to pull the case open with a butter knife or a special pry tool (flat head screwdriver wouldn't be a good choice because it leaves more marks). you need to insert the knife or whatever your using and pretty much pull it apart gently, this isn't easy to do and you can risk ruining the whole screen if your too aggressive when opening it. unless your trying to fix the monitor, you shouldn't open it because it usually will look like **** afterwards.
May 01, 2011 | Acer H233H bmid Monitor
Utencils touch the bottem of bowl
it sounds like the planetary has gotten loose and dropped down. Check out this parts list so you can see how it is put together.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212057.pdf
Try pushing up on the shaft which holds the mixing attachments. It should not move more than 1/32 inch - if it does then something inside the gearhead is worn and you will have to take it apart. If the whole planetary moves up and down then something deeper in the gearbox is worn.
To take it apart lay it on its side and carefully pry the chrome ring off. Now drive out the pin that goes thru the planetary and the shaft. Now pull the whole planetary off its shaft. Remove the six screws underneath plus the other screws you can see from the bottom of the gearbox - there are 4 more. Now carefully pull the top half of the gearbox from the bottom half, which will expose the gears. Examine for worn parts and replace the necessary ones.
Apr 12, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
How do I get access to the switch on a KitchenAid Classic mixer? I've removed all the needed screws,I think, and nothing comes apart except the silver band and the back plate....
the chrome ring around the rotating head needs tapped off to and drive the pin out of the center shaft of the head. Pry it off to access 5 ring gear screws under the head. The also hold the two halfs of the case together along with the 4 obvious ones.
Dec 12, 2008 | KitchenAid K45SS Classic Stand Mixer
Fellows ps60c-2
took schreder apart: The plastic driven gear it striped is that gear serviced
Apr 01, 2008 | Fellowes PS60C-2 Shredder
Fellows ps60c-2
I have the exact same problem. Please share what you find I would be very grateful. Thank you, jmlaatsch@gmail.com
Mar 31, 2008 | Office Equipment & Supplies
Shredder ps60c-2
There are usually one or two hidden screws under the stickers.
Taking laptop apart
never worked on a gateway 9500 , but I bet with all screws removed you have to pry it apart with a screw driver in a the side cracks.. be careful.
Feb 17, 2008 | Gateway Solo 9550 Notebook
230 people viewed this question
k24674
jasbo
jasbo
