Question about Toshiba Tecra 8100 Notebook
No Screen Had turned off the computer and now when I turn it on again the screen is black. Seems I only have 1/2 power.
  • Speed66 May 11, 2010
    Just some questions to get a better idea - what was the last thing you were working on? Do you have it connected to a power source or just battery? Can you reboot and select Setup(usually F12 or delete button when first thing appears on screen or power sounds)? If you can select safe mode with video. Thanks.
  • 27 Answers
You may have also selected the external Monitor. FN button and button with monitor picture. (usually green). Reboot as normal and select that combination a couple of times. Or try plugging in an external monitor and reboot.
Posted on Apr 10, 2008
Its an 8gb.i had it plugged into the comeputer it
You did not turn it off completely. Press and hold the power button for more than 4 seconds or unplug the power cord. Then try again. If a problem persists, write here again.
Oct 03, 2017 | IBM NetVista PC Desktop
Gateway monitor FPD1975W won't display
Same problem - unplug both computer and monitor - hold power button for monitor for 15-30 seconds...then power it back on and then power on the computer. Seems from other sites there is a power issue with the monitor - this worked for me.
May 23, 2009 | Gateway FPD1975W 19" LCD Monitor
My screen is blacking out without removal of power
Check the monitor settings - is the screen saver ON?
Jan 31, 2009 | Computers & Internet
HANNS-G MONITOR BLACK SCREEN JUST FLICKERS
when u power the computer press F8 key then enter in enable vga mode.
then if u able to enter then chagne screen resolution to 1024*768
Jan 05, 2009 | Hanns.G Corporation JW-199DPB 19" LCD...
Monitor black screen dark picture when power on then black. power button flashing
I'm having the same problem, my power button just flashes now, and it seems like the screen tries to turn on over and over again.
I'm pretty sure its the backlight for the LCD.
If your very handy, go to inventgeek.com and type in LCD backlight fix.
Dec 16, 2008 | Computers & Internet
Screen goes black
It could be a bad backlight bulb.
Sep 08, 2008 | HP vs15 15"LCD Flat Panel Monitor
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Monitor goes blank less than a second after turning on.
I start my computer and turn it on, and everything looks fine for about 1/4 of a second and then it goes black while leaving the power light green. I can only see the screen again after turning it off and on, but that's only for another 1/4 second. What's up?
I got my rosewill flatscreen as a hand me down from my father. I've had it for several years now. Was working fine until a month ago. When I turn the computer on the screen goes black after 1/4 of a saecond. I have to turn it off and on anywhere from 10 to 20 times before it stays on. I have checked all plugs to the computer and outlets. I have absolutely no idea whats causing this.
Dec 28, 2007 | Rosewill R700J 17" Flat Panel LCD Monitor
Black screen
How old is the computer? Make sure that the power light comes onto the monitor when you plug it in, should be orange and then turn green when video card syncs with it when PC is turned on. If you are getting black screen when PC is powered on:
1. Bad video card
2. Bad video cable
3. Bad monitor
1Solution: Try using a different monitor attached to this same PC and see if it works. If it does, then its the monitor, its cable, or its power supply. If it doesn't work, then its the video card or the video cable coming from monitor.
Nov 24, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Toshiba Tecra 8100 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
