Question about Nokia 6288 Cellular Phone
Speaker Hi, the mobile got wet and after careful drying out, the only function that doesn't work is the speaker.  So no audible ring tones, no hands free music, voice commands etc.  I have to rely on the vibration effect for incoming call alerts. Is this worth getting fixed? Can I buy the part and do it myself? Many thanks, Bryan UK
    President:
  • 1,017 Answers
The speaker is not working, the microphone is not working (voice commands). To repair it's beyond the average person, you need special tools, also some of the screws have to be replaced, you can only use them once. Some parts inside are glued, so you need the glued stickers to replace after removing old ones. In the end water and electrical equipment don't mix very well, in time it will probably give you more trouble. It all depends on how long the phone was in water.
By the time you've bought the parts, the service manual (you'll need one) and spent hours trying to sort it out!. It's not worth it.
I would either take it to a repair shop, to get a quote, and weigh the quote against another phone. Or say a few nice words and give it a decent send off.
Posted on Mar 31, 2008
Crosley CR6001A: Left speaker barely audible
Hi Eric,
I understand how frustrating this problem can be. The problem can be the result of several different things. Two of them are 1) blown speaker and, 2) blown left amplifier output.
Try listening with stereo headphones. If you can hear both channels clearly, the amplifier is most likely functioning correctly. This is desirable as amp repairs would probably be more costly than a driver (speaker) replacement. Make sure you vary the balance controls while checking for output on both L and R speakers. If the sound is intermittent, the volume or balance control may have dirt built up and may return to working properly by liberally spraying electrical contact cleaner around the stem (knob removed) with the unit unplugged. Use the extension tube to pinpoint the output along the stem. Be careful to keep from over-spraying as it may damage plastic and wood cabinetry. After spraying, rotate the knob fully back and forth several times and then plug back in and try for sound again.
If you can't restore the volume to the left speaker, you may have a blown speaker. This usually happens as a result of excessive volume which leads to distorted sound. If played this way long enough, damage to the speaker is unavoidable.
The speaker can not be fixed - but may be replaced. Replacing the speaker is something most people with conventional hand tools can do - with the unit unplugged. Finding the information on the speaker may prove to require some digging however. You'll need to know the size, wattage rating, impedance value in ohms, and frequency response. It would be best to obtain the exact replacement part if possible.
Other than this, you'll probably need to have it serviced professionally. Good luck!
Dec 06, 2012 | Crosley Cr6001a Turntable
My Iphone4 is ringing very quietly and My microphone doesn't work
It sounds as if your phone got wet or your speaker is broken, I suggest that you will take it to the lab
Jun 17, 2012 | Apple iPhone Smartphone
Sound doesn't work tried settings tried turning it up ect can't hear ring tones nothing. when speaker is on when talking to someone it doesn't work.
seems your ringer (Speaker) got damage you have to replace them, install a new speaker and your phone would ring back again.
please vote me if found helpfull.
Aug 04, 2011 | Samsung Gravity SGH-T459 Cell Phone
Where can I get a description of what the lg icons are other than what is on the phone? Eg.What does ring and speaker mean? What does one beep and one beep &speaker mean? Roaming icon means what?...
Depends on what model it is BUT generally....
E911 is emergency calls only, meaning no service.
Ring and speaker is audible only
Beep and speaker is vibe and sound
roaming means you are on another carrier's network, other charges may apply depending on your plan.
1X is comparable to dial-up speed. If your in high speed area, you will see EV or 3G
Location is your GPS function on/off
Mar 28, 2011 | Cell Phones
No ringtone no sound in speaker . i can receive call
Your ringing speaker may get damaged.You can open the cover of your phone and just press hardly where the ringing speaker is situated.Then check with any ringing tone if the ringing speaker is working or not.If its work you can contact a mobile phone service center and tell him to clean the connection of your ringing speaker and mother board.
Or you need to change the speaker to get rid of it
Sep 30, 2010 | Nokia 6230i Cellular Phone
My phone nokia 5130, it doesn't work at this time. But on the following days i can use with loudspeaker only now it doesn;t work
hi :) u mean before u can use with loudspeaker,mean the speaker hearing people talking cant work ?? if now both speaker cant work,mean both speaker was apoil.pls send to mobile shop exchange new speaker.
Jul 06, 2010 | Nokia 5130 Cellular Phone
Wet speaker
First remove the battery or power from the radio. DO not try to turn it on again until you follow this solution....I'd gently open my radio to allow any excess fluid to drain out on a paper towel or cardboard box. Be PATIENT,,,it might take a couple days to dry depending on your enviroment. You can use a hair dryer on "low" heat being careful not to get to close to anything that might melt...low heat is best or just let your radio dry out it's self. When your confident it;s REALLY dry try to apply the power again...you would be amazed but it just might work good as new if you have the patients to completely dry it out,,,best wished, RadioWidgets
Jan 28, 2009 | Radio Communications
Samsung u600 speaker not working
hi!the problem is the speaker cable might be out it's place,or the speaker is not good anymore!if you want you can try to open your fone.
Jan 23, 2009 | Samsung SGH-U600 Cellular Phone
Dropped in water
I got my i870 from my sister a week ago, i got it for boost mobile but the ear speaker doesnt work either, i took it apart and i ordered the flip part of the phone which comes with the whole top section. It should work after i put the new part. it was only $26 off of ebay. the parts were only held up five screws. really easy but you have to be careful and gentle.
Dec 31, 2008 | Motorola Mobility i870 Cellular Phone
Z & X keys and speaker do not work
you need to have the keyboard service this will correct the issue so take the phone to a mobile service center and have them fix it for you.
May 14, 2007 | Motorola Mobility A630
Nokia 6288 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
