Question about Whirlpool 24 in. ADP6940 Dishwasher
Whirlpool GU1500 chopper assembly cover
I would like to check my chopper assembly for debree (I had to replaice it a couple of years ago) because there is small bits of stuff being left on my dishes. I can't get the "inlet protector" off - part #8268390
  • alandb Mar 14, 2009
    Please be more specific when you say the "tab in the corner"
  • 4 Answers
I had the same problem. Grabbing the little tab and yanking does not seem like the best idea, as it has a groove that fits around the chopper screen, and another lip that fits tightly against the motor housing. There is also a hook at the bottom of the tab that helps hold the cover in place. If you are too rough you could damage stuff. I found if I used a thin lever (screwdriver) on the screw flange side, and worked tthe tab gently with a needlenose, it came free without too much trouble.
Posted on Oct 10, 2009
    Novelist:
  • 131 Answers
It's held on with a # 15 Torx screw. If that's out, it may be stuck. Grab the plastic tab on the corner of the cover with a pliers and pull up.
Posted on Mar 31, 2008
I have a KitchenAid KUDSEWH2 dishwasher that is not allowing the water to spray onto the dishes. It comes into the DW through the fill part but does not spray upwards into the racks
Either your motor or capacitor are bad, or the chopper screen inside the pump is plugged, which can mean the chopper is broken. Remove the lower spray arm, the screws on pump cover, the cover, then screws inside pump that hold chopper cover. If screen isn't plugged the motor or capacitor are bad.
Nov 19, 2011 | KitchenAid Dishwashers
I also can't get the chopper cover off my dishwasher.
My chopper cover was held in place by two screws, but even after removing them I found I needed to use a pair of 'channel lock' pliers to grasp the plastic cover and pull it up and off. Yours may just be stuck from a few years of use and thermal cycling.
Putting the whole thing back together was an equal joy...
Aug 23, 2009 | Whirlpool GU1200XTLS Stainless Steel...
Whirlpool quiet partner II top rack sprayer doesnt work
The top rack spray arm doesn't work because of low water pressure from the wash motor or it's clogged with debris.
If the top spray arm looks clear of debris, remove the lower spray arm and lower feed tube to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary (part # 8268383). If the motor gear is broken, replace the sump and motor assembly (part # 8535150). Remove any debris from the sump area in the process.
You don't have to shut the power off to the dishwasher because the door will be open, but if you feel more comfortable, do so.
Apr 03, 2009 | Dishwashers
Top tray of Kenmore Quietguard3 dishwasher not cleaning!
The top rack is not cleaning because of low water pressure from the wash motor to the upper spray arm.
Assuming the top spray arms are clear of debris, remove the lower spray arm and lower feed tube to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary (part # 8268383). If the motor gear is broken, replace the sump and motor assembly (part # 8535150). Remove any debris from the sump area in the process.
Apr 03, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwaher does not clean, upper rack
Assuming the top spray arms are clear of debris, remove the lower spray arm to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary (part # 8268383). If the motor gear is broken, replace the sump and motor assembly (part # 8535150). Remove any debris from the sump area in the process.
Mar 13, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Dishwasher spray arms don't spin & spray water
Could be a a couple different issues.. Not filling with enough water or food chopper broke or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
Inspect food chopper:
1. Remove lower spray arm and rear water supply tube to upper spray arm.
2. Remove torx screws that secure the sump cover.
3. Remove primary filter
4. Remove food chopper cover to expose the chopper assembly. Inspect for breakage or blockage.
If you need further assistance, let me know
Regards,
reg501
Jun 29, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Whirlpool Quiet GU2300XTLS2
Check water level:
Remove lower spray arm and rear water supply tube to upper spray arm. Remove torx screws that secure the sump cover. Remove the rounded cover on the left side to expose the chopper assembly. Inspect for breakage of blockage. There may be an additional plastic screen to remove first.
Jun 13, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Rinse arms not spinning
Could be a a couple different issues.. Not filling with enough water or food chopper brokeen or food chopper filter screen clogged.
Check water level:
Jun 10, 2008 | Dishwashers
Removing Chopper Cover
go to www.servicematters.com/tech_ref/JA/ja_main.htm This is foer a Kitchenaid unit but the same pump mtr assby goes in the WP it will explain how to do what you want .PLZ Rate this repair Thx Gary
Feb 23, 2008 | Whirlpool GU1200XTLS Stainless Steel...
Water not spraying hard enough
Check water level:
Sep 30, 2007 | Whirlpool GU1200XTLS Stainless Steel...
Whirlpool 24 in. ADP6940 Dishwasher Logo
440 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
