My tv has a problem with the projection tubes. i pulled up the main menu, clicked on screen and it tells me to click on number 6, which is adjust projection tv. my tv has only 5 selections. that is not one of the selections. what do i do now? i have been on hold for over two hours this morning trying to get a service person. no luck, please help.
  • grovep5 Mar 31, 2008
    brand, rca, model number,P52923, chassis number,PTK195K4B
    do i get your solution on this page or do i have to go to my e-mail to get your answer?
  • 2,334 Answers
Can you please provide brand, model number and chassis if applicable?
Posted on Mar 31, 2008
  • Jaime Hernandez Mar 31, 2008
    Thank you for the info.
    Could you please describe the problem with your TV? and the reason you want to go to option 6.
    This option might not be available because it controls critical adjustments that are perform if you have the service manual.
When you turn the TV on, you have sound but no picture. However, in hte upper right hand corner you see the number station and wording in the color green over red, what is the Problem?
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
May 07, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Hi there, I have a hitachi 53" projection tv and
  • Screen looks 3D
69189a5.pngSOLUTION
69189a5.pngSOLUTION
Jan 31, 2011 | Hitachi 53UDX10B 53" Rear Projection...
Bowed red green lines at top screen. picture looks like it in 3d.
  • Screen looks 3D, wavy, or has a shadow or shadows
69189a5.pngSOLUTION
69189a5.pngSOLUTION
Jan 28, 2011 | RCA HD52W59 HDTV Projection Television
Picture is coming up as 3D
69189a5.pngSOLUTION
69189a5.pngSOLUTION
Jan 21, 2011 | Mitsubishi VS-55601 55" Rear Projection...
Picture looks concave and 3D. The convergence is wacky and can not re adjust
  • Screen looks 3D
69189a5.pngSOLUTION
69189a5.pngSOLUTION
Jan 20, 2011 | Mitsubishi VS-55601 55" Rear Projection...
My tv needs readjusted (color,focus,etc.)Is there an easy way to do so myself? i got a 1986 45'' RCA projection tv.it started of with just a blury spot across the top but after i messed with it the whole...
First pull back Look for screen and focus block you will have 3 controls ontop for focus and 3 controls below for adjusting screen drive to each Tube R/G/B
turn color off on Menu NOW try to Adjust the red,greenand blue screen drives as close asyou can to a Black and White picture then turn Color back on in Menu also adjust Focus for each Tube Be sure to Clean Top of Tube Lenses of dust&dirt Just in case Post me your Model and Chassis Number it will be on back of TV some RCA Focus&screen drive Block maybe in front of TV if so remove front bottom panel their you will see control box.
Nov 10, 2009 | Televison & Video
I was just given this t.v because friends couldn't figure out what is wrong with itl. The colors don't line up right,looks kinda blurry depending on the lighting of the program being watched. How do i fix...
According to the manual:
1) go to the "TV Main Menu"
2) Select "Screen"
3) Select Adjust Projection TV (obviously only if a projection TV).
This then allows you to adjust the TV's 3-colors. Selecting GREEN CENTERING brings up a control panel that lets you center the green projection tube on the screen. Selecting RED CONVERGENCE or BLUE CONVERGENCE lets you align the Red & Blue projector tubes. Centre the green projector tube 1st. Then adjust the red & blue until the test pattern on the TV screen appers white.
Good Luck!
Jun 08, 2009 | Proscan PS50700 50" Rear Projection...
Hitachi TV screen adjustment
in the menu , the display or video settings should have different video display settings such as 16:9 , 1:1 , 14:9 ect... these will change the video display to different sizes
Oct 09, 2008 | Hitachi 50UX57B 50" Rear Projection...
Alighning tv
i have an alinemenet problem with my rca tv P52929 i went to the book and it said to go to the menu and select 3 which is the screen menu then select option 6 which is the adjust projection tv. this is suppose to allow you to adjust the the tv's three colors. it says to select the green centering to adjust the green tube. blue for the blue and red for the red. it says to center the green first then adjust the red and blue tubes until the test pattern on the tv screen appears white. i hope this helps you. my problem is that the program is not in my tv. it has everything else but not the option 6 to adjust the tv. this may be your problem to. good luck.
Apr 15, 2007 | RCA P52929 52" Rear Projection Television
Televison & Video Logo
Top Televison & Video Experts
