Washing machine digetal read-out shows code 43.
43 error is the 'out of balance' fault code. The oob switch is under the motor controller board. This is accessed by removing the 2 screws at rear of facia and exposing the motor board which is attached to the hob. The microswitch is most probably faulty.or there is oxidation on the slide on connections. When replacing the switch make sure it's the same as the one coming off as they can be opposite function...Sometimes the oob arm below the oob swich can get jammed over the edge of the bowl and give the same fault...Check that first....Good luck....Nomess
