Question about Microwave Ovens
Microwave removal I have a Sharp Carousel model # R1381 which needs service ( door latch replacement) how do I remove it from the mounting bracket?
  • sixtyfoe May 01, 2009
    how do I remove my old microwave
  • Microwave Ovens Master
  • 9,086 Answers
Actually, you shouldn't need to remove it from the wall to change the door switches or latch head.
We have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We have a partial service manual for that unit at our site, and it has the wiring diagram (helpful to be sure it all gets back right).
The manual is at http://www.microwavedisplay.com/r1380_r1381_sm.pdf
Feel free to contact me directly if you have other questions.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 31, 2008
I have a problem with my Sharp Carousel R 1480. The door will not latch and the light will not go out. The hooks on the actual door seem to be in place and working like normal so Im assuming it is...
We have the full service manual at our site here.
If you gently push up on the door latch heads (hook-like devices sticking out of the door) there should be spring tension. If they just flop right up, the spring is off inside.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
In some cases, you problem may be a damaged latch head, which is an odd name for what I would call a door switch holder.
Our file on door switches is here.
You can order parts from Encompass Encompass here or you can call them toll-free at 866-779-5835.
Oct 01, 2010 | Sharp R-1480 Microwave Oven
How to install latch and spring in microwave door
You need to know where the 'catches' are inside the choke cover on the door to remove it carefully without breaking anything or marring the cover. You might get inside and find that the post for mounting the return spring has broken and that is part of the outer door panel.
Sep 11, 2009 | Sharp R-1610 Microwave Oven
Microwave door does not latch; oven does not work
We have the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
Dec 22, 2008 | Sharp R-1405 / R-140 Microwave Oven
Door does not latch when closing on Sharp Carousel model R1480 Ser.# 221885 Microwave oven
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the internal spring is off.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here but the best place to order Sharp parts is Tritronics.
Nov 05, 2008 | Microwave Ovens
We have an old Sharp Carousel R-1440 that works great, except for the door latch broke (i.e. doesn't work at all now). Can we replace just the door?
Actually, the door latch head (hooklike device) is pretty easy to replace or repair if that's the issue.
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off.
You can usually find exploded views and order parts by entering your model number here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
We have critical safety & disassembly info at our site, linked here.
Sep 27, 2008 | Sharp Microwave Ovens
Sharp microwave oven door won't close!
You will need the free Acrobat Reader to view or print it.
If needed, the best place to order Sharp parts is Tritronics.
Sep 14, 2008 | Sharp R-1750 Microwave Oven
Door latch on sharp 1480 microwave over the range oven
Sep 13, 2008 | Sharp R-1460 Microwave Oven
We have the service manual for this model and have uploaded it to our site here to help you. You will need the free Adobe Reader to view or print it.
Normally you have to separate the door panels (as shown in the manual) and then you'll see the screws you need to remove.
Aug 08, 2008 | Sharp R-1480 Microwave Oven
R1381 Sharp Carousel over the range microwave
I know this is late, but I have instructions for this unit. Remove the grease filters on the bottom. Inside the exposed hole there should be two gold colored bars. These are attached to plates at the top of the until which hook onto the mounting plate. Undo the screws at the bottoms of the bars and pull them down. This will unhook the unit from the top of the wall plate. Roll the unit forward and unhook from wall plate.
Mar 31, 2008 | Microwave Ovens
Directions to remove and open door panel to repair safety door latch.
You don't have to remove door to remove panel. Panel is held in by an outer plastic retainer which can be removed by carefully prying with a small screwdriver. I can be replaced by pushing it back in place after repair is completed. If you cannot open door from the outside, remove cover and you can see latches. Pry up on latch which will let door open.
Jul 28, 2007 | Sharp R-1610 Microwave Oven
Microwave Ovens Logo
663 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
