Question about Kitchen Ranges
Range ovens covered in black sooty dust.
Bought a double oven. Both ovens are covered in a black sooty dust. Is this something applied by the manufacturer to stay or are they just dirty and I need to clean it up.
    Novelist:
  • 131 Answers
Wipe it out with a damp cloth. Any intended coating to the enamel would have been baked on long before it left the factory.
Posted on Mar 31, 2008
Only one burner doesn't work on my maytag gemini stove
MET8776BS Maytag Gemini Smoothtop Double Oven Range
reviews.us-appliance.com/.../MET8776BS-Maytag-Gemini-Smoothtop-D...
Rating: 4.5 - ‎94 reviews MET8776BS Maytag Gemini Smoothtop Double Oven Range - Stainless Steel - Reviews ... Really like the features, however one burner doesn't work, after a month.... 2 ovens sure beats the storage bin underneath! the only negative I can think of is ...I bought my double oven a few months ago and am very happy with it.
Oct 16, 2015 | Maytag Kitchen Ranges
Whirlpool Double Oven Range
Recycle the circuit breaker for the oven several times. If you haven't used the oven much the contacts may be corroded. The display is off a 110Vac circuit but the ovens use 220Vac, The circuit breaker should be 2 switches "ganged" together as one. Both should be cycled...
Dec 25, 2012 | Whirlpool GGE388LXB - Black GoldR Double...
Jenn-Air dual fuel double oven range - oven wont work.
You can make the repair yourself. What is the model number?
Nov 07, 2012 | Jenn-Air Kitchen Ranges
What does error code F1 E1 mean on a kitchenaid built in oven?
F1 - E1
EEPROM checksum error
1.
Disconnect power for at least 30 seconds.
2. Re-apply power and observe for
at least one minute.
3. If code re-appears, replace control board (also
called ERC or clock).
Note: Applies to all F1-E...
codes except F1-E3.
Feb 14, 2011 | KitchenAid KEMC378 Electric Double Oven
F2 &F3 error codes, oven keeps beeping, I already tried turning off circuit breaker did not solve problem
F2
- E0 Shorted keypad (also called touch
pad) 1. Check keypad connector for firm
connection (keypad connects to control board).
2. Press CANCEL. If error code
returns after 60 seconds, replace keypad (also called touch pad or membrane
switch). Some models incorporate keypad in to control board as one unit. In this
case, replace control board (also called ERC or clock). F2 - E1 Keypad cable unplugged F2 - E5 Cancel key drive line open F2 - E6 Cancel key drive line open F3 - E0 Oven temperature sensor (RTD) opened (upper oven,
if double oven) Replace Oven temperature
sensor (RTD)
Note: Applies to all F3-E...
codes. F3 - E1 Oven temperature sensor (RTD) shorted (upper
oven, if double oven) F3 - E2 Oven temperature is too high (Cook
mode) F3 - E3 Oven temperature is too high (Clean
mode) F3 - E4 Oven temperature sensor (RTD) opened (lower oven,
if double oven) F3 - E5 Oven temperature sensor (RTD) shorted (lower
oven, if double oven) F3 - E6 Warming drawer sensor open F3 - E7 Warming drawer sensor
shorted
Dec 20, 2010 | Whirlpool Accubake RF362LXTT Electric...
Hello my oven will not turn off and it gives me an error of E2 F3
F3
(upper oven, if double oven) Replace Oven temperature sensor (RTD)
Note: Applies to all F3-E... codes. F3 - E1 Oven temperature sensor (RTD) shorted (upper
mode)
Dec 11, 2010 | Kenmore 96422 / 96424 / 96429 Electric...
Gas oven wont turn on
my brother stopped by last night and undid the lower fire cover , fiddled with something (we don't know the name) , now the oven will heat up and life is calm.
thanx for having this site to help calm us silly homemakers who aren't DIY.
aloha, teri
Aug 21, 2009 | Maytag Gemini 30" Self-Cleaning...
Sooty burning in oven after Natural-LP gas conversion
The conversion was not done correctly.
Either wrong parts or incorrect adjustments to air flow.
Feb 08, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Kenmore double oven
This is what f 7 means:
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Will need to replace the oven control. Part # is WB36T10486 for black and WB36T10488 for white. Cost is $314.75 for black and $417.99 for white. You can get it at http://www3.sears.com/.
Nov 16, 2007 | Kenmore 47772/47774/47779 Electric Double...
Kitchen Ranges Logo
147 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
