Question about Kenwood KAC-7202 Car Audio Amplifier
Probems with my kenwood 7020 amp
How come it will turn on but the sound sound's distorrted it sounds like the sub's are blow so i put them in my outher car and thay work fine it has two grund do i hook them both up
  • 2 more comments
  • rudy22 Apr 03, 2008
    DO I REALLY NEED THE OUTHER "GND" ? ON THE RCA?
    i tryed the setting's and steel no sound
  • rudy22 Apr 04, 2008
    it sounds but can't hear any thing if u toch it i can feel it want to move but it dont play loud to move the sub it 's like not even playing any thing i have a jvc deck 200 watts to that amp and i have 2 "10" jenssen bass sub's i had an 800watt legacy it sounded good i took it out to put the new amp and i have it hooked up like one sub the sub 1 negitiv to thesub 2 positv and froum the amp i have the pos to the pos sub1 on the box and the neg to sub 2 thats how i have all my systems hooked up
    I tryed some difrent sub's to the amp and thay do the same thing i tryed to hook them up one sub to one channel and the outher sub to the outher channel and it steel doing the same thing
    Sergeant:
  • 300 Answers
The ground nearest "batt" connection is your main ground. The other "GND" is for grounding shielded RCA cables.
If the amp is being used to run subs alone:
  • Set the Bass Boost to 0.
  • Set the LPF Frequency to about 80.
  • Set the Input Sensitivity to 5 (the minimum).
  • Set the Filter to LPF.
If things sound fine at these settings, one at a time, slowly bump the Bass Boost and the Input Sensitivity up, checking the sound quality as you go.
Posted on Apr 02, 2008
  • 1 more comment
  • Tygh Duval
    Tygh Duval Apr 03, 2008
    If you happen to have RCAs that have a shield that needs grounding, that's where they'd connect. If not, don't connect that "GND" to anything.
    Are grounding/shielded RCAs necessary? I'm sure it depends on who you ask and your situation. For most installations, being careful on where the RCA cables are run and what they are near is usually plenty.
  • Tygh Duval
    Are the subs not outputting at all, or does it still sound "funny"? If there some sound, try and describe it. Give some details on what your subs are, how they're wired, and what your head unit is.
  • Tygh Duval
    Tygh Duval Apr 04, 2008
    Hard to say if it's an amp issue or a connection issue. If you have other subs to try on this amp, I'd try them just to see if they act the same.
    Obviously, if you haven't already, check all your connections (especially RCA preamps between the HU and the amp).
    I don't know if your subs are dual voice coil or not. If they are DVC (dual 4 ohms), your optimum setup is:
    • +'s together on the voice coils of each sub.
    • -'s together on the voice coils of each sub.
    • -'s of Sub A to +'s of Sub B.
    • +'s of Sub A to Left + on the amp.
    • -'s of Sub B to Right - on the amp.
    • Total power per sub = 230W
    If the subs are not DVC (only single 4 ohm voice coil):
    • Sub A + and - to Ch 1 + and -.
    • Sub B + and - to Ch 2 + and -.
    • Total power per sub = 150W
Kenwood no sound
If you have a separate 'power' or sub-woofer amp, check that it still has power and did not blow a fuse. Is there an internal selection inside the unit for enabling the internal amp vs an external amp? Some will disable the internal amp using a setup setting, and just provide low level output that is expected to be amplified by an external amp. If it 'forgot' you might have to set it to use the internal amp again. Or vice-versa, depending.
Jul 23, 2014 | Kenwood KDC-S2009
RCA jacks on kenwood head unit do not function
Just run your amp on the front RCA and tune it on your amp they can blow which sounds like whats happend hope this helps
Mar 18, 2013 | Kenwood Car Audio & Video
I have 2 12in kenwoods and a 1200 watt pyrimade amp, how can i hook these up to be the loudest
1st have your subs facing inwards towards the front of the car, not facing out the boot, This creates a better bass.
Wire 1 sub to one channel and the other sub to the other channel.
Turn down your gain as low as possible and then power everything up.
turn volume to desired loudness and then start turning up the gain slowly, if distorts a little turn in back down a notch.
avoid using bass boost, I agree it sounds great but it puts more strain on your amp and shortens its life.
after sorting out your gain, tweak all others until sound is bassy and clear with no distortion.
If you would like to use bass boost, turn on bass boost first, then up your gain etc.
Jan 16, 2013 | Pyramid PB915X 1200 Watts 2 Channel...
I just recently bought a brand new MTX magnum amp and dual 10" enclosed subs deal off of amazon. They arrived today, and with the help of a friend who is good with car audio systems, we set the whole
the best thing to do is get in touch with amazon,and see what they can do about it,if you try to fix the problem yourself it will invalidate the garantee!
Dec 05, 2012 | MTX Car Audio & Video
Poor sound/ Unable to play anything load without distortion.
i can tell you right now base on the vehicle you have a bad system hook wosrt if you are using factory head unit
Mar 25, 2009 | Kenwood KAC-8151D Car Audio Amplifier
Adjusting wattage on kenwood kac 9103 class D mono amp
That amplifier is 900W x 1 @ 2ohms.
If your subs are 4ohm SVC wired Parallel, resulting in a 2 ohm load, each sub will only see 1/2 of the rated power. (450W ea.)
Your gain (sensitivity) setting should be between 75% and 85% to max. You will be fine.
Jan 02, 2009 | Kenwood KAC-9103D Car Audio Amplifier
No sound
good day, check your spkr impedance, if 4oms use a posive spkr dividing network. if stills blows up replace a higher amperage of your fuse. ex.4A raise it up to 5A. the your amps consume higier current if more spkr wattage.
May 29, 2008 | Kenwood KAC-5203 Car Audio Amplifier
AMp keeps blowing fuses
When any amp blows fuses, this indicates that something is drawing too much current. The most common cause are components in the output stage and driver stages that have become defective.
On the amp that is blowing the fuse with the volume being turned up, this means that the output stage is partially working. The short or over-draw of current must be in the output stage, or what is loading it. It is possible in this case that a crossover in a speaker unit is defective, and is drawing too much current. I have seen this with especially sub-woofer crossovers, and the driver itself. Subs pull a lot of current because of the amount of drive power required to have very strong bass sounds. Other than that, this still does not rule out the possibility of the problem being defective components in the amplifier.
Jerry G.
Apr 25, 2008 | Car Audio & Video
Kenwood kac-9152d
by jump do you mean all it does is thump and no sound besides thumping noise? if so put a better ground on your amp, double grounds work the best. please reply
Oct 06, 2006 | Kenwood KAC-9152D Car Audio Amplifier
Kenwood KAC-7202 Car Audio Amplifier Logo
606 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
