Center speaker no sound. tried to do some eliminating before writing you, center speaker is working when i hooked it up to a friends avr receiver so its not the center speaker. also did a channel check all 4 speakers work except center speaker could it be inside my avr85 thats causing the problem or could it be that i did not set up system or modes correctly please help thank you sally
  • 5 more comments
  • pinkfreud713 Apr 19, 2008
    I have hooked up a center channel speaker in conjunction with two front speakers. The sound tests produce static in all three speakers, but no sound is produced from the center speaker from any source.
    I've run through all the troubleshooting in the user manual, but I have not yet fixed this problem.
    Help?
  • wanderson914 Sep 04, 2008
    all trubleshooting
  • cowgolfer Sep 11, 2008
    i unhooked my system to set up new tv, put it back the same way. have verified the center speaker and wires work, but i am not getting any sound out of my center speaker.
  • Anonymous Oct 15, 2008
    Center speaker just stopped working,swapped speakers to eliminate the speaker its self so presume it is a amp failure. Hope some can help with where to go next.
  • badger64 Oct 15, 2008
    No output from center speaker, speaker checked on other channels and working OK, had the top of the unit but could see nothing obvious. Hope some one can help.
  • pottsy1983 Oct 26, 2008
    i have same problem with mine. switched it off one night and next day its not working. can anyone help please.
  • Anonymous Jan 09, 2009
    Came back from holiday to find no sound and volume control seems to be working in reverse direction! Have tried resetting buttons and checked speaker contacts.
Had the same problem and SOLVED it.. the problem is caused by bad solderjoints on the pcb with the pre-out connectors on it. the solution is to take this pcb out and inspect it visually for signs of loose/oxidized solderpoints - indicated by a faint gray 'ring' near the soldered wire. just resolder and there you go! an amp as fresh as on its day of birth.. enjoy
Posted on Oct 28, 2008
SOURCE:
Why does only center channel speaker work?
Try running a sound test. You should have a test mode that will play a sound through each speaker to see if you have them hooked up correctly. If you still only hear it from the center, unhook the center and connect it to another speaker output, say right front. Run the test again. If you hear something from that center speaker, its the speakers. If not, try each speaker output to make sure the results are the same. If so, you may have an internal board problem.
Good Luck!
Nov 05, 2015 | Denon Avr-1910 Receiver
My denon avr-985 has no sound coming out of it why could this be
Go though your menu on the reciever, Look for the speaker functions for your front end rear speakers ,It was probably turned off. Was it working before you got it from your friend,
Sep 20, 2012 | Denon Avr 985 7.1 Channel 945 Watt...
I want to get full surround sound out of my Denon AVR-1508 w/sub
hi there might be some problem with the link that u have hooked up with the speakers.
Jan 18, 2009 | Denon AVR-1508 Receiver
HK AVR 120 (left speaker not working)
Hi, your analysis are right, your speakers has no problem, the problem is in your receiver.
there are several factors that affects it, try some troubleshooting: and answer this questions:
1. During this event, what is the source of your INPUT audio signal?
Have you tried to replaced your RCA cables that connected to the source of your receiver?
If YES, then problem really exist in the internal system of your receiver. may be you have overdrive your receiver unintentionally, which cause the Power Amplifier to malfunction,
On this event, I would suggest that you bring your receiver to it's Service Center for repair,
This problem needs technical troubleshooting of a qualified technician.
Dec 25, 2008 | Harman Kardon AVR 120 Receiver
Denon AVR 1609 Receiver Zone 2 has no sound
you have to change the power amp assignment to zone 2, you must also have Analog audio connections to the Denon from your devices.
Try this put your remote in the zone 2 mode, select tuner in zone 2 and turn zone 2 volume up to -10
Dec 18, 2008 | Denon AVR588 Receiver
Avr 7000
WAT BRAND SPEAKER AND RECEIVER?POSSIBLE OHM ISSUE?WAT IS THE IMPEDENCE ON THE AMP AND CENTER SPEAKER,.HAVE YOU TRIED RUNNING A 6?8 CHANNEL CONFIG?FOR EX.USING YOUR SOUND CARD THROUGH THE PREAMP AS A DSP. WHE PLAYED IN SHOP HE USESD CD? U USING SAME CONNECTION FROM THE SAME INPUY? OR IF LISTEN ING TO RADIO. SOMETIMES THE SINGNSAL IS NOT IN A DIGITAL FORMAT SO THE PPR LOGII C CANT PRODUCE IT.IT WOULD BE PLAYED ANALOGICLY.MEAN NO CENTER.
Dec 26, 2007 | Harman Kardon AVR 7000
Denon reciever avr-487
If your tv is putting out mono you will only get the center and sub speakers. This can be because the tv is only mono, or the output is set to mono in a menu of the tv. If you have cable or sat run the digital audio out to you receiver; it usually sound better that way anyhow. Set your receiver to Dolby mode for best sound.
Aug 27, 2007 | Denon AVR-4800 Receiver
429 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
