Question about Creative Labs ZEN SLEEK MP3 Player
Sleek Photo not rebuilding library
After those options are displayed on my Zen Sleek Photo which one do i choose?
  • 8,596 Answers
Read your manual or go to: http://support.creative.com/Products/Products.aspx?catid=213&catName=MP3+Players
Posted on Jul 06, 2008
Water Damage, screen freezes, reset means rebuilding library.
http://www.fixya.com/support/r3771170-phone_water_damage
Sep 11, 2009 | Creative Labs ZEN SLEEK MP3 Player
My Creative zen Sleek Photo is frozen
Initially, would suspect that the hang or froze. A couple of ideas that you can try:
double check that the unit is fully charged;
  • do a rest. There would be a reset button inside a small hole, you can use a dull pin, straightened paperclip or even a toothpick;
  • verify that the "Hold" is disable/disengaged;
  • access the Recovery Mode. Press and hold the Play/Pause button while doing the reset as above described;
  • there would be several options. You can try all except Reload OS/Firmware;
  1. Clean Up is scans and remove invalid music library;
  2. Format (All) erases everything saved;
  3. Reload OS/Firmware would be a last resort;
  4. Reboot will restart the device.
  • Should it be a battery issue that will not hold a decent charge, you can replace it. Pls follow instructions from here;
  • If all else fails, reload the firmware. Pls reference the Creative website for instruction and latest update.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 18, 2008 | Creative Labs Zen Sleek Photo MP3 Player
ZEN SLEEK PHOTO OWNERS MANUAL
http://safemanuals.com/user-guide-instructions-owner-manual/CREATIVE/ZEN%20SLEEK%20PHOTO-_E
Sep 03, 2008 | Creative Labs Zen Sleek Photo MP3 Player
Why zen sleek photo won't download music
i have a zen sleek and every time i turn it on it says rebuilding library. It completes this but deletes the last album etc that i put onto it. back down to the last album i put on before it started doign it. So i cant put anymore mousic on becuase it deletes it..Any Help?
Apr 17, 2008 | Creative Labs Zen Sleek Photo MP3 Player
Xen Sleek Photo
remove the song and add it again.
Dec 09, 2007 | Creative Labs Zen Sleek Photo MP3 Player
Zen frozen on one screen even after I've restarted it.
hard drive sounds bad. has it been dropped?
try to do a cleanup
  1. Detach the Zen player from your PC , and ensure that the Zen Sleek is turned off.
2. Connect the power supply to the player.
3. Hold down the Play/Pause button while inserting a paper clip into the Reset hole
underneath your player, beside the data/power connector. Keep on holding the
Play/Pause button while you release the Reset button. The Rescue Mode screen will
then appear.
4. After the recovery mode has started, release the Play/Pause button
It will display the following options.
Clean Up Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Format (All) Caution! Erases all content!
Save a copy of your player's content before formatting.
Reload OS/ Firmware Caution! Erases your player's firmware.
DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
Reboot Reboots the device.
Dec 04, 2007 | Creative Labs ZEN SLEEK MP3 Player
Zen sleek photo not recognized by my computer
http://193.95.171.84/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=777,E=0000000000295100332,K=9595,Sxi=19,Case=obj(16737),Kb=ww_english_add,VARSET=ws:http://us.creative.com/
http://193.95.171.84/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=750,E=0000000000295099827,K=9595,Sxi=19,Kb=ww_english_add,VARSET=ws:http://us.creative.com/,Case=obj(12937),Kb=ww_english_add
Nov 22, 2007 | Creative Labs ZEN SLEEK MP3 Player
Not rebuilding Library all the way
1. Press and hold the Play button while powering on your player.
2. When the player displays the Creative logo, release the Play button.
It will display the following options:
Clean Up
Oct 27, 2007 | Creative Labs ZEN SLEEK MP3 Player
Trouble Filing Songs into Playlists
ok, sounds like a problem I had when I was working out the software! The easiest way to create a playlist with the Zen, is doing it over your PC, if you don't have the software it is available for FREE download at the official creative Zen site, just choose your model and region then hit download- simple! (You won't need Zencast with sleek photo model) ok! install your software blah blah blah, once it's gone through that process, restart your pc and then plug in your zen. the software should instantly recognise that your player is connected, so now, you can open up the software via desktop shortcut or start menu. From here, you've got a whole ton of options, whether to add to your library, create playlists etc etc. Choose create playlist and the process is easy. Left side of the screen is navigation of your Library, right side is navigation of current playlists. Create a new list, then name it. From the top left of the screen, select a folder on your library to open, the lower left displays what's in the folder you are viewing. move tracks over accordingly, holding down ctrl while you click is a fast and easy way to select more than one track at a time. hit add in the center of the screen to move stuff over to your new list. when you're done, save it. when you exit the software and unplug your zen, it should take a minute to update itself, sometimes you may need to restart Zen also to get the playlists updated. I hope this helps!
Apr 19, 2007 | Creative Labs ZEN SLEEK MP3 Player
Zen sleek photo doesnt rebuild library all the way
ok, first you will need to let it rebuild as far as it will go without interuption. Then once it gets stuck... take a a clothes pin or a real slim piece that will fit into the reset hole. The reset button is near where you would normally plug it in for data transfer or power supply. Now your player will restart, you shouldn't lose any infomation at all by doing this. After you do this, you need to try and press the power button so you can power the system down. If you are able to power the system down, that is good... then after it is off, you will need to plug it into your computer to charge... or plug in your wall charger in order to charge the system. Once plugged in... leave on charge over night. The next day... unplug the system from the power supply. Try to let it sit for a few moments before you do anything to it... After letting it sit, try powering it on... If it starts to try to rebuild the library, then while it is doing so, lay it on a desk and do not move it until done. After that... if it comes on as normal... it is fixed. However, this is a problem I have had with mine too! So if it does not work after that... you may try to contact me at brianmaggie12@msn.com Thanks and I hope I was able to help you with your Creative product!
Apr 15, 2007 | Creative Labs ZEN SLEEK MP3 Player
Creative Labs ZEN SLEEK MP3 Player Logo
63 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
