Philips Magnavox 51MP392H Rear Projection Television Logo
Posted on May 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The pictures are all blurry and all three colors show up on the screen volume and everything else is ok what do i do
Anonymous
Level 3:
  • Master 1,961 Answers
  • Posted on May 17, 2010
Anonymous
Master
Level 3:
Answers
1961
Questions
Helped
665995
Points
5692
You can adjust your screen focus located at the main controll pannel it is labelled as focus adjustment..if this not work replace the CRT socket of the 3 cathodes the red,green and blue
I have a 60 PC ID-UE LG PLASMA AND THE SCREEN COLORS GET BLURRY AND HARD TO SEE PICTURE VOLUME IS OK AND STAYS ON FINE NO OTHER ISSUES JUST AFTER IT WARMS UP IT WORKS FINE
to be honest with you, i have experienced this problem on my previous Panasonic industrial TH42PDUY (Not sure the exact numbering ) but anyhow, when this occurs, turn off the screen immediately. Problem shouldn't cling after.
My tv overall is blurry, but when I click menu to mess with the settings, only the picture of what I'm watching, and the highlighted word is blurry, but everything else is clear, video games and movies n...
Some of your electronics parts were worn out. Like capacitors may have leaks that need to be replace
as use stated that the word focus were very clear it means that your tube is still okay. or you adjust the focus knob on the compartment. To tune in the 3 colors.
2answers
Blurry picture
Sounds like convergence failure. (Colored shadows of images.)
The left side of screen is blurry.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony2_bing.gif,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer2_bing.gif, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
I just got my HD52W59 back from the shop a few weeks ago and they got the three colors around everything taken care of but a friend adjusted it again and the middle of the screen is OK, but the left and...
It needs a full service mode convergence set up and possibly a focus adjustment. Don;t let friends touch your tv unless they are somewhat qualified.. EVER!!!!
My tv is blurry, showing green and red waves...zenith d61w25
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic2_bing.gif,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
BLURRY SCREEN
If all 3 colors are mis-aligned, you may have solder connections that blew a fuse. There are three fuses next to the flyback transformer, one usually blows causing this issue. Resolder the flyback solder connections and replace the fuse to fix.
Green color convergence
make sure you hooked everything up properly and that all connections are tight
New PCB SUB - But blurry and color off.
have you tried to also adjust the lenses to fine tune the focus .
18helpful
8answers
Blurry tv
Sounds like theres a leaky capacitor in the screen drive circuit. I have seen this problem also be a gassy crt but was able to clean off the grids of the CRT with a crt/rejuvinator. It happens because of low emmissions in the tube and when white is on thats a mix of all the colors, so the tube works harder. I bet when you whatch a movie and the scene changes suddenly to a white or brite scene the pic looks a little washed out. If this is not the case then I aggree with the Pravin and try it on another TV just to be sure .. This is not a repair for a consumer to do, though however it is only a three year old set you stated, so there should be life left in the tube, so im kinda thinking a capacitor is bad. Seek out a yechnician to check this out for you as a TV is not a place to see it you can fix it or to exoeeriment with. Good Luck
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
