Question about JVC AV-27D302 27" TV
Switching from cable to an antenna
I want to eliminate cable and use an antenna. The antenna instructions say that I have to set my TV to receive an ANTENNA single rather than a CABLE signle. I have gone through the TV menu and can't find anything like that. Is there such a switch? If so where is it and how do I get to it?
Thanks.
Georgia Palmer
Georgia@GeorgiaPalmer.com
  • 81 Answers
Well first off, on 2-9-09 the off air antenna will be eliminated. and you must have a converter box to receive signal. Now on the set that you have, you must check and see if its a dual tuner. NTSC or ATSC and still try to run the auto search on cable and see how many channels you get. Most Tvs only have cable setting and not off air. so try it and see.
Posted on Mar 31, 2008
I have set up my top field with red, blue,green cable. White red yellow cable antenna cable into Topfield. Do I require a antenna cable from top field to tv. All working fine but no sound.
I don't know what model you have but common connections are:
for higher quality video use red, blue, green in video section on receiver and TV and white and red in audio section
for lower quality video yellow in video section and red and white in audio section
that will allow you to watch programs from receiver on tv. As for antenna to depends on model of your unit and if you use or nor antenna on the roof you may be able to receive over the air programs. That connection is not regret for sat only programs
Mar 02, 2018 | Televison & Video
Wont receive digital channels after scan non found
Hi Patrick,
You must have a UHF / VHF antenna connected to the antenna input of the TV to scan for digital channels. Most new TV's have a threaded, round 75 ohm coax cable connection for this - but yours might even have connection consisting of 2 small screws to connect a 300 ohm twin lead antenna cable instead. Use which ever yours has.
If you are using this input for the input of a cable TV "set top box" (STB), satellite STB, or similar, you will likely only find a single analog channel (Ch3 or Ch4) after a scan as the scan will only find the output of the STB - which is usually on Ch3 or Ch4 - and not be able to scan the STB channels.
Additionally, the antenna input of the TV will only provide a standard definition picture if connected via coax cable from the STB. It will only provide a high definition picture if connected to a UHF / VHF antenna and a broadcaster is close enough for its signal to be received by the antenna. The way to obtain the best possible picture (high definition) when using an STB for tuning channels is to use an HDMI cable between the STB and TV. An HDMI cable will provide the very best picture and audio signals from the STB to the TV; all over a single cable and is the recommended practice.
I hope this helps!
Dec 26, 2014 | Televison & Video
What is the video single output VHF FM UHF 12db
That sounds like the description of a broadband amplifier. It likely has "F" type (cable-coax) connectors and a power cord.
Commonly used to increase the signal level of TV cable to compensate for inserting a signal splitter, or in some cases to increase the signal level from an antenna, typically outdoor TV or FM radio antenna, so it is connected between the signal source (antenna, or cable) and receiver with antenna as input and receiver connected to the output of this little box. The gain (amplification) it provides is 12 dB, so the output is more than 3 times the input.
Oct 03, 2014 | Radio Communications
The menu does not have a choice to change from antena to cable how do I get it on cable
Typically, your cable box will have two inputs & one output that goes either thru your VCR for recording puposes or just direct to the TV. Your switching will happen thru your cable box, like an A/B switch, designed so that when cable is down, you can switch over to locally broadcasted TV stations. With DTV now in play in most areas, you will want to connect the antenna's connector to your DTV box, then connect it to your cable box for switching back and forth. The new flat panel TVs already have a digital receiver built-in, so in that case you would eliminate the DTV box.
Nov 08, 2013 | Daewoo DVN-14F6N 13" TV
Need to know how to change and setup for use of antenna
Purchase your UHF/VHF antenna. The antenna can also be purchased at most electronic and retail stores. Consult your list from Step 1 and see how powerfulicon1.png the over-the-air signals are for your specific address. Purchase your antenna based on the broadcasting power you need to receive a clear picture on your TV. You might be able to get away with an indoor antenna if your signal strength is strong enough. If not, you'll need to purchase an outdoor antenna.
  • 4 Install your antenna (or have it done professionally) according to the building codes of your area. If you must use an outdoor antenna, it is a good ideaicon1.png to have the antenna professionally installed. This ensures that it is properly grounded on your roof, not too close to electrical wiring and stable during inclement weather.
  • 5 Hook the converter box up to your television using the cable that came with it (F Cable). Hook your antenna up to the converter Box. Turn on your TV and converter box. Tune your TV to channel 3 and press "Scan" on the digital convert box. Allow the box to scan for your available channels.
  • 6 View your picture and adjust your antenna accordingly for the clearest over-the-air feed. You should only need to make adjustments once. If you are having a difficult time getting a clear picture, use a signal strength indicator to see where you receive the most powerful signal.
  • Read more: How to Replace Cable TV or Dish TV With Antenna TV ' eHow.com http://www.ehow.com/how_5228282_replace-dish-tv-antenna-tv.html#ixzz2RrACTyTI
    Mar 29, 2013 | Sansui 19 in. LCD TV
    I am trying to hook my pioneer vsx-455 up to my samsung dlp-hd tv and have no idea which pre-outs to use.any help would be greatly appreciated.or do i need to go through the cable box and if so how?
    Ok. Where does the TV programming originate? Antenna, TV, or (usually) the Cable Box. I'll tell you sight unseen, no TV ever adds to the audio experience. many of us watch on monitors so that would suggest that a TV can play absolutely no part in the high-end audio experience. It's specialty is video with basic audio capacity thrown in. A Cable Box is for all purposes a digital audio and video source with separate outputs for each. Keeping with my practice I'd run the BEST VIDEO (and minimum audio in case you want to use TV speakers for that source) from each video source to the TV (it has multiple inputs, right?) and the BEST AUDIO (no video) from each source to the receiver. One video connection from the receiver to the TV for set-up/control. This requires some switching on your part to watch different sources but it eliminates troublesome and unnecessary routing and handling of the individual signals.
    Nov 08, 2011 | Pioneer VSX-455 Receiver
    I need instructions for hooking my VCR to my TV set,
    using a scart cable, connect the tv socket on the vcr to the scart - in socket on the tv.
    good luck.
    May 10, 2011 | Philips Televison & Video
    Which end is the receiving end of a house tv areial
    peter_321
    One end of the coax cable is connected to your antenna. The other end connects to a coax port on the back of the receiver labeled "TV/Antenna Cable In". All DISH Network receivers have this port on the back except our "K" series receivers. These receivers require a module to plug into the back of the receiver. Connect the antenna cable to this port, "TV/Antenna Cable In", if the receiver has the port available. I hope this helps.
    Ray Calo
    DISH Network
    Mar 05, 2011 | Televison & Video
    I have a Sanyo DP32648 that keeps losing only one channel in the program. When the TV is turned off, that channel disappears from the program. I have to manually reboot the entire list. How can I solve...
    It sounds like there is some electrical noise interference that would not be "fixable". If though, we reconfigure the way that they are connected together, we may be able to avoid the noise.
    Instead of allowing the antenna signal to "pass through" the 625 we will skip it.
    After following the directions, switching between satellite and antenna will be done by selecting on the SANYO "Input 1" for satellite, and selecting "Ant" for antenna. K?
    Try this:
    From the 625 Tuner 1- using RCA cables (a.k.a. composite cables, or red, white, yellow cable), connect to "Input 1" on the Sanyo TV. To see composite cables go to http://www.wowvision.tv/settingsandconnections.htm
    Next, remove the coaxial cable between the Sat box and TV. (Sanyo "Ant. In" port and 625 "Out to TV" port) Set that cable aside.
    Now, remove the incoming antenna cable from the 625 "Ant. In" port, and connect it to the Sanyo's "Antenna In" port.
    Finally, scan for channels and check for the presence of CBS.
    Once verified, test the TV by turning off and on.
    Turn on the satellite receiver and switch Sanyo to "Input 1" to verify sat picture.
    I believe this solution will satisfy your needs. Please let me know if it doesn't work, and I will need to talk to you about signal strengths, again.
    God bless,
    Highdefjeff
    Jun 13, 2010 | Sanyo DP32648 32 in. LCD TV
    JVC AV-27D302 27" TV Logo
    313 people viewed this question
    Top JVC Televison & Video Experts
    Jaime Hernandez
    Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
