Question about Nikon D70s Digital Camera
Cobra DC6425 How do I clear the flash memory in this camera? It is locked up and will do nothing but turn on.....will not download or turn off.
  • 1 more comment
  • bobcat1960 Apr 03, 2008
    Thanks, but not possible.
    I have to remove battery to turn camera off. Have done this many times.
    Thanks for trying.
    I am sure this is correct and this is what I have tried to do many times, but camera will not respond to PC's efforts to communicate.
    Thanks!
  • 655 Answers
You should remove the flash from camera. use it in any PC and make format the flash and then use it with camera.
Posted on Mar 31, 2008
  • Nikon Master
  • 19,396 Answers
Try removing the battery and turning camera back on
  • 813 Answers
Hi friend
plug ur camera in ur pc load ur camera driver & earse ur all camera photos u can use ur cam as pan drive
SOURCE:
I bought a cobra camera at a yard sale and it has the cobra digital insignia in the view window and says it is busy. What is going on? Anything I can do to fix?
If you can get to the camera's menu do a factory default reset. Otherwise, if the memory card can be removed try another one and format it in the camera.
Nov 09, 2014 | Cobra Digital DC8000 8 Megapixel Compact...
Why does my tomtom keep going back tro demo mode
unfreeze tomtom sat nave
frozen tomtom
To fix the errors, you must run the TomTom Clear Flash tool. This tool clears the flash memory on your navigation device.
Select your operating system:
Windows To download and install the TomTom Clear Flash tool on your navigation device, follow the steps below.
Note: The download steps apply to Internet Explorer 8. The download steps may be different if you are using another browser.
  1. Download the TomTom Clear Flash tool: Note: The download procedure applies to Microsoft Internet Explorer 8. The download procedure may be different if you are using another browser.
    1. Click the Download button. downloadbutton.gif TomTom Clear Flash tool for Windows (EXE)
    2. Click Save.
    3. Select the Desktop and click Save again.
    4. Click Close.
    5. Connect the navigation device to the computer:
      1. Turn off the device.
        Note: If the device is connected to the computer, for example for charging, disconnect the device.
      2. If the device uses a memory card (SD card), insert the memory card into the device slot.
      3. Connect the device to the computer.
      4. Switch on the device. The computer detects the device.
      5. Run the TomTom Clear Flash tool:
        1. Double-click the file clear_flash.exe, which you can find on your computer's Desktop.
        2. Select the language. Read the Licence Agreement, then select I Agree. Click Continue or 1751_01.gif.
        3. Install TomTom Clear Flash is already selected. Click Continue or 1751_01.gif.
        4. Click Continue or 1751_01.gif.
        5. Click 1751_01.gifagain to start the installation.
          When the installation has finished, the message Installation complete is displayed.
        6. Click OK or 1751_01.gif.
        7. Click 1751_01.gifagain.
this worked for my device where NOTHING else would, the original problem seems to come from updates. My device does not keep its settings What should do
Aug 14, 2014 | Tomtom VIA 1605M GPS w/ Lifetime Maps...
Camera says out of memory won't let me take pictures. i cleared all the pictures out and still cant take pictures. What do you think the problem is?
I'm assuming you are trying to use an SD card in your camera and not the internal memory. I suggest you format the memory card if you are sure there is nothing on the card. Formatting the memory card deletes everything on the card and sets it up with a file system that your camera recognizes. Follow these steps to format your memory card using your camera. 1. Turn camera off 2. Insert memory card 3. Turn camera on 4. When the memory card is inserted in the camera, the [Format card] option appears in the setup menu 5. Choose Format to format the entire card. Don't choose Quick Format 6. Wait until your card is formatted
After formatting your memory card, try turning your camera off and on and you should now be able to take pictures to your memory card.
P.S. If you remove your memory card you can choose Format Memory from the setup menu to format the camera's built-in internal memory
Sep 01, 2011 | Nikon COOLPIX L5 Digital Camera
Memory card locked, already tried little switch on the side
It may have to be unlocked in the camera settings. My phone has a lock feature for photos, to prevent accidenta erasing.
Jul 17, 2010 | SanDisk 2GB microSD Memory Card
Locked Memory Card
I use a Nikon D300 and have Sandisk Compact Flash memory cards. i ahve not come across this problem but would suggest that you insert the memory card into your camera and reformat the memory card. This should clear any errors in the system BUT IT WILL ALSO WIPE ANY PHOTOGRAPHS YOU AHVE TAKEN when formating the memory card.
Oct 20, 2008 | SanDisk ULTRA II 4GB Compact Flash Card...
Nikon D40X quit working - memory card access lamp flashing??
As per the Samsung digimax range, internal memory seems to be faulty. Insert an external memory card and try to power up the camera.....
Oct 08, 2008 | Sony Cyber-shot DSC-S730 Digital Camera
Hi - I have a Rebel XT - and my built-in flash won't work - and i get an ERR 05 message. What can I do?
Dear joefrisco:
An ERR 05 message indicates that the camera's flash pop up mechanism has encountered a problem due to either an obstruction (such as your hand or something blocking it), a jam (impact damage), or an electrical failure.
Try the following steps, in order, to try and resolve the issue. If nothing works, the camera will have to be sent in for service (call Canon Tech Support @ 1-800-828-4040):
1. Turn the camera off. Ensure that nothing is blocking the pop
up flash. Turn your mode dial to one of the Creative Zone
modes (P, AV, TV. or M). Now turn your camera back on
and attempt to take a flash shot. You will need to manually
press the flash button to do so.
2. Turn your camera on and perform a hard reset by pressing the
MENU button, tabbing over to the Set Up 2 menu tab and
selecting the option "Clear Camera Settings / Clear All
Camera Settings" options, and then removing the camera
batteries, date/time battery, and memory card for a period
of approximately 2 minutes. Then reinstall all items, turn
your camera on, reset the date and time and perform step
number 1 above.
Hope this helps.
Sincerely,
HeavyDLB
Jun 02, 2008 | Canon Cameras
Cobra digital camera
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Feb 11, 2008 | Cobra DC4200 Digital Camera
Red flash and appears to be frozen
Yes, I get red flashing too occasionally.
turn the power off and on using the button under the screen.
reformat the card either via a computer of if possible via the camera menu item.
Remove and re-insert the card.
purchase a new and faster SD card.
Jan 06, 2008 | Sanyo Xacti VCP-HD2 Camcorder
COBRA DC5500
You can download the manual from the link below: http://cobradigital.com/manuals/1/DC5500.pdf Looks like you put the camera in capture mode (slider switch in the center) then press the left arrow key on the dial to select flash mode. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 16, 2007 | Cobra Digital DC5500 Digital Camera
Nikon D70s Digital Camera Logo
41 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
