Question about HP Compaq Presario V2000 Notebook
Compaq V2615 dial up connection
I was working on the internet one day & handed my laptop to a friend next to me as I stood up from the couch. When I did, the screen went away and was replaced by thick verticle lines. The only thing I could do was reboot the system to get it to come back on. After rebooting, everything seemed to be working fine; until I tried to go back online. The modem tries to connect but I get a no dial tone error. I live way too far out of town for wireless so, I'm not sure if it will connect any other way than dial up.
Thanks for the help
  • Jeana  C.
    Jeana C. Apr 02, 2008
    The other computers in the house are connecting as usual so I know it's not the phone line or the service provider. I tried un-installing the modem and reinstalling it and that did not work. I have a feeling that I am going to have to buy a new modem. No big deal, just confused about what happened to this one.
    Thanks for your help.
    Genius:
  • 2,785 Answers
Plz check your phone line. then u scan your pc for anti-viruse and anti-malware in safe mode. then uninstall the modem drivers and modem through safe mode. Reinstall the modem drivers if still u cannot connect then your modem may be out of order.try a new one.Still problem persist than u check it with your service provider n tell them to check for the data part of your phone line
Posted on Apr 01, 2008
  • Rajkumar Bordoloi
    Rajkumar Bordoloi Apr 01, 2008
    before scaning for viruses u have to disable system restor
My compaq presario 5240 w/ win 98 wont connect to the internet
make a menu on top toolbar right click in top toolbar
select menu bar this will add file edit view fav tools and help
click on tools then from the drop down list internet options connections tick in never dial a connection
then you will have to add your isp internet service provider
first you must have an ISP Internet Service provider contract which will provide you with a modem and leads you can choose either a dial up usb or
an ethernet connection to connect to the internet or
if you have a laptop you can choose a wireless usb modem
which can work on a desktop aswell once you recieve the modem just insert the disk provided and follow the prompts to set up your new internet connection
during the setup process you will be asked for a password I suggest you make a log of all pass words used outside of your computer incase of memory lapses
hope it helps
Jun 18, 2012 | Compaq Presario 5240 (353200-003) PC...
How do i connect dial up connection
If you want to connect your pc/laptop with a dial-up connection you need to make a dial up connection but you didn't mention your operating system.But no problem just go to control panel and there you find network connections in it you notice a create a new connection then new wizard will open press next then select which ever connection you want make then it ask how to connect to internet in it choose set up connection manually press next then choose appropriate option then its done. Your connection is just made up try to connect and you internet will start working.
Nov 19, 2010 | Acer Aspire One PC Notebook
I have a hp compaq nx7400 laptop with an agere systems hda modem.i have a dial tone and when i try to connect to the internet the modem sounds like it is dialing but the dial tone never goes away.is the...
The Agere systems HDA modem is a 56kbps modem typically found on laptops. View it in device manager.
Start->Control Panel->System->Device Manager->Modems
Should be listed there. See if there is an exclamation mark next to it.
Not very expensive or difficult to replace
Aug 14, 2010 | HP Compaq Business Notebook nx7400
I got a compaq evo d510 refurbished and I have ATT extreem internet service and 2 wire router conected to comp with erthnet cable, It will not connect after installing att cd. It keeps trying to use dial...
Since you are using the Internet I must assume you are using the Dial up settings. I may expect that this AT&T service is DSL. In Internet Settings there is a tab marked "Connections" and the Dial Up settings are set to "Always Dial My Default Connection". Click on "Never Dial a Connection" and this problem should be solved. Next thing is to ensure that the DSL connection is connected properly since if this is not setup correctly you won't even get online until you reset the "Connections" tab to the original setting.
Sep 16, 2009 | Compaq EVO D510 CMT P4 2.5/20GB/256MB...
My compaq laptop refuses to connect to dial-up & braodband (LAN)
please update ur driver immediately or contact vendor
Jul 24, 2009 | Computers & Internet
Wireless Internet for compaq Presario
Check out the wireless setup manual for your laptop here:
http://h10032.www1.hp.com/ctg/Manual/c00065819.pdf
Hope this helps!
Mar 28, 2009 | Computers & Internet
Compaq armada v300
If you have a router on your broadband, you need a RJ45 network cable - right next to the modem port on your laptop is a network port - this will use the correct cables you need to connect to your router.
If you don't have a router but only a broadband modem, just connect it to the USB port on your laptop, install the software and you should be good to go.
Feb 08, 2009 | Compaq Armada E500 Notebook
I have no idea on how to get the internet on my laptop. I have dial up service on home computer. Do I need a wire connection? Plus I'm going out of town in a few days and would like to know how to...
hey friend
If yr laptop have a modem built in so u can configar same dialup connection on laptop and just connect yr phone wire in to modem connector and dial it..
and if ur in hotel and u need to internet u have a cuppol of chioce.. life mobile office internet , dial up connection and if yr hotel mennagment provide a connaction that time hetle mennagment providea engineer to configar to yr laptop. and if u hace a yr own dial up connaction then just plug phone line in to yr laptop and tell menagar to give a diract dialtone ( some of hotle's give this facility ) and if yr Phone servise provider Life Vodaphone , IDEA Ext. give u a Mobile Office internet facility with give a wireless internet whenaver u go abnd it's good 4 u coz for this u don't need eny help just comnfigar yr mobile to yr laptop and configar mobile office to yr mobile simple..
Try this one. ..........;) don't forget to vote...:)
thanks for using fixya..
jo_chinmay...
Apr 03, 2008 | Computers & Internet
My laptop won't connect to the internet through wireless connection
I have a compaq laptop. we have wireless and my other laptops work fine. this laptop just will not connect. it did before, but now it wont. help me.
Feb 14, 2008 | Computers & Internet
HP Compaq Presario V2000 Notebook Logo
75 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
