Harley fxstc 1999 sputters and dies after five ten min of riding
Ran bike out of gas died then two days later started acting funny and dies after about five to ten min of riding runs good except for the dying part has carb on it
not told how old the fuel is
and can be bad 1+ year old
compression good
good fuel
carb clean.
spark good.
filters not clogged.
electronics speedo or cable driving, no way cable can fail parked at 0mph, but if electronics to not work with dead or weak battery 10vdc is min 12.6vdc is good key off rested.
a good battery is first, the bikes generator may not run the biked proper if battery overloads any gen. so batter good is first on bike. (MC)
I HAD THIS PROBLEM. BIKE WOULD START AND IDLE NO PROBLEM. WOULD GET UP TO SPEED AND DIE. WOULD START AFTER SITTING. BIKE HAD BEEN SITTING FOR A PERIOD.
FIX:: REPLACED FUEL FILTER FIXED THE PROBLEM.
LOCATION::: TUCKED UP ABOVE VOLTAGE REGULATER RECTIFIER IN FRONT OF REAR TIRE LOOKING UP.
What u are describing is typical of a faulty ignition system, but could also be a fuel problem. I check by removing the aircleaner and rotating the throttle. If u see a nice spray of fuel, thats probably not the problem. Check for a spark at the plugs. I can explain how if you need me to. If you cant see a good spark, U have an electrical problem. I had a crank position sensor go bad on me. Dont do what I did (replaced the battery, ignition, and regulator as part of my diagnosis procedure)
