Question about Sanyo HT32744 32" TV
Sanyo ht32744 32" tv
Screen turns green after on for a while; then i give it a good whallop and everything works normal again. no more green screen. i am an elec. eng. and can probably fix this . how hard is it to access the crt board? does the back come off or does it pull out from the front? do I have to discharge the high voltage section for safety's sake? Thanks for your help. Pete
  • 2 more comments
  • Sanyosucker Aug 03, 2008
    Sanyo Model HT32744 Serial Number V5170278860999 has a green color to all flesh tone images. I have tried all settings allowed by the remote with no success. Intensity of green has increased over the last two weeks. I tried various input devices (i.e. VCR, DVD), but all produced the same green tint. I tried to get info from the Sanyo website with no success.
  • Anonymous Oct 18, 2008
    Picture has become green (lost red ) on the right 2/3 of the screen. Sometimes the whole screen is green, sometimes it becomes ok after warming up for hours.
  • Anonymous Oct 26, 2008
    My Sanyo shuts the picture and sound down, Just shaking it or touching it slightly will turn it back on. No spacific place to touch it. Sometime on the input panel. Help!
  • jholen29 Feb 03, 2012
    a loose or cold solder in the crt board..its simple you dont have to discharge the hi voltage for it will create more damage..just simply unplug the unit wait for a few minute to discharge it self..and also try resoldering the the connecting wires from crt to main board going to the what they called the jungle ic the crate the RGB signal..
    Problem Solver:
  • 11 Answers
I too had the same problem where my HT30744 TV would lose its color. My mom's HT32744 would have the same problem too. They both are refurbished models bought at Value City Dept store. If I gave the cabinet a good hit it would mostly fix the color, but it could also make the picture go fuzzy too, a clear sign of just a loose connection somewhere.
So after my wife telling me she was sick of this almost 2 year problem and she was going to buy a new TV on the weekend, I figured I had nothing to lose. So I took the rear cabinet off, unseated the card mounted on the picture tube, applied a little dielectric grease on the connector on the card and reseated the card, removed, re-greased and reattached the card. I have had no problem with either my or mom's which I did the same to since! This is an easy fix that anyone can do. The hardest part is moving the TV and reassembling the rear cabinet. Do not pull the cabinet back out more than you have to, to ease the reassembly of it.
Posted on Mar 05, 2010
  • peter heidt
    peter heidt Jun 01, 2014
    Anthony: i think i fixed the problem but i pulled the back out to far and now i have pulled a bunch of black wires off their connection. is their any way you know how i can fix this ? please help if you can
  • Anthony Butcher Jun 01, 2014
    If they were soldered on, the only way to get them back on is to have them soldered back on. But if the card came off with the wires, just re-seat the card. IF the wires came off of the card, then i am not sure which wires go where though.
    Scholar:
  • 170 Answers
After reviewing the info with the same tv sitting in front of me.
seems to be a connector problem in the video board that is connected to the crt. the connector between the video board and the signal board. remove this board, inspect the board and spray and clean the connectors. also try to ruffin up the contacts if possible. also resolder connectors, and check crt board for cracks. this is a known problem with these.
please report back if this helps you.
Posted on Apr 10, 2008
  • 398 Answers
The back of the set slides right off once you remove the screws and the CRT board is attached to the end of the picture tube, easily accessable. You do not have to discharge the high voltage. Look closely at the solder joints on the CRT board and you will probably find one or more cracked loose.
Posted on Apr 01, 2008
    New Friend:
  • 3 Answers
My set had the same problem; the picture went red, dark, and splotchy. When I hit the side, the problem went away but soon came back. Thinking that it might just be a loose connection, I took off the back. (A much easier task than lifting it off the shelf.)
The little board on the back of the CRT seemed to have come loose. When I pushed on it, it moved and clicked lightly back into place. I turned on the set and the color was back. I left the set on for 48 hours and the color remained perfect. The problem seems to be solved.
When I replaced the set on a shelf, I set it on a heavy duty but simple "lazy Susan" that I built to go under it. It makes connecting cords MUCH easier, and if I have to take the back off again, I will not have to take the set off the shelf.
Posted on Nov 27, 2012
What is wrong with my Sanyo TV?
T'Con board fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Mar 03, 2016 | Sanyo Televison & Video
Why is my sanyo tv flashing green, blue, and red ?
i turned it on nd it was still like that nd i gt more mad. i was gna throw the remote bt i presed the menu button randomly once or twice i dunno bt it came back(normal tv)
hope that helps
Apr 11, 2010 | Sanyo DS31520 31" TV
Green power light comes on, the turns right back off. No picture. Please help
I'm not sure what TV model you have. But, thing I can tell you is the most common problem.
Most of the time with flat panel TVs, the power supply for the screen fails. And the TV normally turns itself off to protect other parts in the TV from being damaged. Basically " Protection Mode".
You can try leaving the TV unplugged for 30 minutes so the TV can reset itself; then try again turning it on. If it doesn't work after that, it's time for the TV repair shop.
May 21, 2009 | Sanyo Televison & Video
Sanyo dp50747 Plasma HD TV
I just had mine fixed and the guy said " ITS THE POWER SUPPLY" tv nows works fine after repairs but my ps3 won't work on this tv any clue or is it just cheap engineering and I just get what I pay for!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Dec 28, 2008 | Televison & Video
sanyo recommends using the reset button with cable box on, vcr off and press the reset button 2x, then try pressing channel up button if no message appears on the screen. i have not trid it yet... but good luck
Sep 23, 2008 | Sanyo PDP-42H2W 42 in. HD-Ready Plasma...
Sanyo tv model ht27546
our year old tv plays wonderful then it will turn green an the after a while it will go back to normal .we were told that some stores put a chip in it so that after about a yr it will do that.the picture is great but then the screen turns green,what can we do to fix that?
May 03, 2008 | Sanyo HT27546 TV
Green Screen
my screen is green.  i can hear audio but no picture.
Jan 17, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Sanyo HT32744 32" TV Logo
528 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
