Question about Toshiba DKT-2010 Corded Phone
Toshiba CIX 670 Phone system
I have several system cards that have faults on them. Where can i find the codes. It says that the line is disabled by fault:DO or :CR. Any help would be greatly appreciated.
I've been having problems with ports on the system giving me the DO error as well.
From what I understand on the DO it means that there is no device connected to it. I haven't seen the CR issue yet.
Posted on May 22, 2008
1990 Ford Mercury Sable airbag light won't stop flashing and gas gauge won't work how do I fix them is there fuses to check
The airbag has a fault and the airbag system is disabled (VERY BAD) The system must be checked for fault codes, but the most likely cause is the rotating contact coil under the steering has an open circuit to the steering wheel airbag. The system can severely injure you if not disarmed before the steering wheel is removed to replace the contact drum, so best left to an expert.
The gas gauge problem is almost for sure a fault in the fuel tank fuel level sensor float arm. That means you must remove the gas tank to replace the fuel pump module.
Mar 09, 2016 | Ford Cars & Trucks
Tip
?JCB FAULT CODES LIST
P0087 (flashing code 227) shared sump low pressure fault (for pump without pressure supply)
The main fault symptoms
• Engine severe vibration.
• idling unstable
• Output Fall
• exhaust smoke
• It may be too large output
P0088 (flashing code 118) shared the tank pressure is abnormally high (first or second stage)
• idle instability
• Output Fall
• channeling gas engine failure
• exhaust smoke
P0089 (flashing code 151) shared the tank pressure failure (for pump pressure supply is too large)
• idle instability
• Output Fall
• exhaust smoke
P0090 (flashing code 247) SCV drive system open, + B short circuit or shorted to ground
• Depending on the open / short situations, there may be an engine stall and / or launch
Machine channeling gas.
• exhaust smoke
• Output is too large
P0107 (flashing code 71) atmospheric pressure sensor circuit input low (open or shorted to ground)
Due to spare the equivalent altitude 2000 m (6562 ft)
• exhaust smoke at high altitude.
• insufficient output at low altitude
P0108 (flashing code 71) atmospheric pressure sensor circuit input high (+ 5V shorted)
• The high altitude exhaust smoke
• lack of low altitude output
P0112 (flashing code 22) intake air temperature sensor fault (low voltage fault, earth fault, short circuit)
• When cold starting, may exhaust white smoke.
More here http://truckmanual.weebly.com/jcb-fault-codes.html
on Dec 20, 2016 | Cars & Trucks
What does fault code P0497 mean for Honda Cr-v ?
Nothing for that code either. Are you sure you are reading the reader properly?
P1382 Cylinder Position Sensor No Signal P1456 EVAP Emission Control System Leak Detected (Fuel Tank System) P1457 EVAP Emission Control System Leak Detected (Control Canister System) P1459 EVAP Emission Purge Flow Switch Malfunction P1486 Thermostat Range/Performance Problem P1491 EGR Valve Lift Insufficient Detected P1498 EGR Valve Lift Sensor High Voltage P1508 IAC Valve Circuit Failure
Dec 30, 2015 | Honda Cars & Trucks
We have a Toshiba Strata DKT3512F-SD system in the office, only the main line actually rings the others just flash but we need to make them ring.. any advise would be much appreciated!! I'm lost!
On the old DK system, it must be done using key strokes from port 005. On the newer CiX system, it's handled via system programming using the Network eManager.
Dec 07, 2015 | Toshiba Lands Phones
Retrieve a phone number from earlier today from the caller id
If you're running on a CiX or CTX platform, you're dealer or system administrator needs to enter the amount of CID calls to be buffered on that particular phone. This can only be done via the System Administration Program. You'll also need to program a "Caller-ID Log" key
Sep 09, 2014 | Toshiba DKT3207-SD 1-Line Corded Phone
CHANGE THE DISPLAY NAME ON MY TOSHIBA DKT3210-SD PHONE
On a CiX or CTX, it's handled via the System Administration Program or Personal Programming Interface.
Sep 09, 2014 | Toshiba DKT3210SD - - Phone
Need to add a caller id scroll button on phone for toshiba cix 40 phone system
Your problem was posted in the printers and copiers section. Try posting it again in the correct section.
Dec 03, 2013 | Toshiba Strata Cix40 Cix 40 Complete Phone...
System diagnostic failure, fault alarm 0x0106.. what is the fault? how to fix? batteries are 3 months old
James,
The fault reads as an 'system overload'. You can fix this by resetting the network management card....Try a firmware upgrade, and make sure it's the right version for your card. In the process of this update, it will also reboot the NMC, which is another troubleshooting step you can get out of the way at the same time. A second self-test is also a good idea.
You'll also probably want to re-enable your emails, just disable the "recurring after every 2m" part. Go to: Administration > Notification > Event Actions, by group > Events by Severity, ensure all are selected, Next > E-mail Recipients, Next > select email address, Next > Uncheck the box next to "Repeat at an interval of..." Next > Apply
You can configure this for individual events also under Event by Actions, by event if you DO want to receive repeat email notifications about an event until it clears... like an overload for example.
If you need UPS, Surge, or Power Related help contact Daniel @ Power & Systems Innovations 800.260.2259 or go to our website: www.psihq.com
Sep 09, 2013 | APC Symmetra LX (syaf16krmt) UPS System
In my Volvo truck the TCS light is on all the time how to turn of
Hi there:
TCS is used to control wheel spin by utilizing the ABS system, I suggest scanning the module in order to know what fault codes stored there.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jun 27, 2012 | Cars & Trucks
Engine check light on while driving, already replace new fuel filter with regulator, clear fault using vw diagnosis tool, after driving several days, the fault occured again with the fault code p0441>
Your EVAP purge valve may be faulty. Also, check the vaccum lines attached to the valve for any signs of wear and tear. Should be located next to the coolant tank.
Nov 16, 2011 | 2009 Volkswagen GTI
Toshiba DKT-2010 Corded Phone Logo
1,201 people viewed this question
Top Toshiba Lands Phones Experts
george  peters
george peters
Oloyede Monsuru
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
