posted by mr walter on Mar 31, 2008
I have a vermont grill, even when the flame is on high the flame does not get hot, it feels like it is on low and takes forever to cook the food.
Thanks
1 Other User Has The Same Problem
Comment by rhall1, posted on Jul 14, 2008
grill will not heat up over 299-300 degree's. manuel says to close all valves and reopne the tank valve 1-2 turns, wait 5 seconds and light one burner and it should fix the problem, I did this a few times and it did not work.
The grill is only a month old. Just changed the tank recently and started this problem
R. Hall
Best Solution
posted on Mar 31, 2008
If the propane tank is full, it could be the pressure regulator. Some regulators have an adjustment screw on the top.
If it's REALLY cold outside, the propane may not be evaporating fast enough to keep the pressure up. Also on a cold or windy day, heat is drawn away from the grill very quickly, and it may be difficult to keep the temperature up inside.
(And Happy Grilling!)
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Vermont Casting The Extreme VCS5005BI
Email this problem
Email this problem
Can you Help with these Grills and Smokers problems?
Grills and Smokers
Jenn Air lp grill won't light...
I replaced the ignitor and it's... Answer This...
Repair Service
Find Grill and Smoker Repairman Near You:
